The problem is even with new plumbing I have to buy filters to put on the drain hose so it does not overflow from a build up of lint (this I have never had to do with any other washer I have owned). It still over flows from time to time. I just want you to know (although I feel this will do nothing except I got to vent) we are in the process of remodeling our bathroom. If this continues, which I'm sure it will, and we continue on the bathroom our money will have been wasted. It has already ruined the drywall, flooring and wood. We have had a plumber out 3 times. The last time they told us we needed to buy the filters for the drain hose. We have done that. I just put a new one on and after 3 loads of laundry it overflowed again. I am deeply disappointed with your product and we purchased it because it was a GE appliance. If I could I would gladly get rid of it tomorrow. Needless to say I won't be buying another GE product. Thank you for your time and I'm sure I won't be getting a response, there is really no general complaint department I could find. I wonder why that is. Oh and also it does not always spin the clothes to be damp enough to dry. They are soaking wet and yes I followed the trouble shooting tips. My washer is not off balance and I just have to run another cycle of drain and spin.
  • ju3514s Mar 26, 2008
    Hope you got to read the original complaint and problem.
    President:
  • Washing Mach... Master
  • 2,651 Answers
You would be better to vent your frustration's to a G.E. representative,( Although yes it does apprear to be your drainage issue, and would happen regardless of manufacture of washer.
Posted on Mar 26, 2008
I just purchased an LG Front Load washer (Model WM2140CW). Best buy installed it. When I went to use it today, the floor flooded. Water was gushing out of the drain pipe (backing up). The LG drain hose...
You may have a drain line restriction causing it to back up. Pull the drain hose up about 6 inches and try it again. If it does overflow again, you will need to call a plumber to clear the drain line out in your plumbing.
Jun 16, 2011 | LG WM2140CW Washer
Dishwasher wont drain even after running rince cycle is there steps to reset system ;ready to overflow
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Oct 26, 2010 | GE 24 in. GLD5860LSS Stainless Still...
I have a Sears Kenmore washer, model # 110.28922791. I bought it approximately 10 years, give or take a year or two. I know it does not have a lint filter but is there any way to clean whatever processes...
HI- Washer really don't have a lint filter so to speak. Some of the front load washers have a filter in the drain pump but that basically just keep the quarters and bobby pins from ruining the pump. Is it possible to have someone extend your standpipe with a larger diameter pipe that you could place a screen into, or place the screen on the drain hose and then put them both into the larger pipe. A plumber should be able to figure something out. It would be about $1000 dollars cheaper than buying a front-loader and probably more effective. Good luck.
Sep 24, 2010 | Washing Machines
F 09 ?
Hi There
Just want to say is merry x-mass and a happy new year. I found the codes for you so you can read it. I hope this helps and put you in the right direction.
/09 Overflow Condition
If the Overflow contact on the pressure switch is Closed for more than 60 seconds and Overflow condition will occur. In an Overflow condition, the Door will remain locked, and the Drain Pump will run constantly, even if PAUSE/CANCEL is pressed twice and the Display is cleared. Unplug the unit to service.
  • Check the drain hose and make sure it is not plugged or inked.
  • Check Wire Harness connectors to the Drain Pump, Pressure Switch, and Central Control Unit (CCU)
  • Check/Clean Drain Pump Filter of foreign objects
  • Check for Drain Pump Failure
  • Check the Inlet Valve for proper shut off
  • Check the Pressure switch for proper operation
Thank you for writing to fix ya.
Best Regards Richard
Dec 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Vent hose is too short
Yes you can connect 2 together, obtain 1 longer hose or use a fixed rigid pipe suitable for hot water etc - similar to drain pipe. All these shouled be readily available from your local plumbing supplies store.
Oct 05, 2009 | Dryers
Washing machine drains; then drain pipe overflows
Try some drano other chemical drain cleaner. If there is a build up lint or other biodegradable material in the drain pipe the drano should remove it.
BTW how long has it been doing this..... did it just start?
Jul 07, 2009 | Kenmore Washing Machines
When draining water overflows out of drain in wall?
Pick up a drain auger at your local hardware store or plumbing supply house. A general-purpose hand-operated one isn't expensive. Run it down the drain and it should clear out the clog that is causing the backup. It's likely just lint that's builtup, unless someone is missing a sock.
Jun 02, 2009 | Tecnik TKL9260 Front Load Washer
Water builds up behind heat exchanger
I don't know if there is a cure for this. Bosch never answers my calls or my e-mails, but I have found that by blowing in the hose to disengage the lint collecting there and then sucking out the line will remove nearly all of the build up amd drying will resume.
Jul 08, 2008 | Bosch Axxis WTL 5410 Electric Dryer
Hose overflow
its plumbing problem your stand pipe that the hose goes in needs to be unpluged
Feb 25, 2008 | Washing Machines
Water Backs Up in Drain Pipe and Overflows
the pump will pump out at a continuos rate that wont change, the problem will be with the standpipe. You dont have to have a total blockage in the pipe, sometimes the diameter of the standpipe reduces due to scale build up and it just cant cope with the rate of flow.There will be a restriction somewhere.
Jun 25, 2007 | Whirlpool LSB6200KQ Top Load Washer
Washing Machines Logo
46 people viewed this question
Top Washing Machines Experts
