Question about HP Officejet 5610 All-In-One InkJet Printer
Can you help me set up my hp scanner - HP Officejet 5610 All-In-One InkJet Printer
  • 4,041 Answers
Hi From Wales UK for you.
Not sure what one you wanted so I put the 2 there for you.
You can download a driver Software from my website then you can use the driver for setting up your printer.
Just click on this link and it will download for you, and it is best to save it on your desktop so you can find it.
This is for the
Link = XP http://www.4all2sell.com/driver/HP-Officejet-5610-XP-32Bit.exe
Link= Vista http://www.4all2sell.com/driver/HP-Officejet-5610-All-in-One-Vista.exe
Click LINK= http://www.4all2sell.com/pdf/HP-Officejet-5600-5605-5610-5610v-5610xi-Manual.pdf
Ones you have downloaded just double click and it will take you through the installing.
Try it you got nothing to lose it may work for.
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one and to go on helping.
All The Best: Pineworks
All files on my website are there only for a limited time
Posted on May 03, 2010
HP 2520hc scanner drivers
Which driver set did you install? Did you install the HP basic drivers, the full software or the Windows XP built-in driver? The Windows OS driver usually only is the printer driver.
If you connected the USB cable before installing the HP software, you will get the OS drivers. Disconnect the USB cable and then uninstall the printer driver. (Start > Control Panel > Printers and Devices. Then right click on the printer and select Remove Device.)
Install the HP software. If you want to launch a scan from the all-in-one's front panel button, install the full software.
Next open the scan software on your computer. (This is the HP Solutions Center for most models if you use the full software.) Attempt to launch a scan from the software. Adjust the resolution and other settings as needed. Then use those settings to adjust the destinations for the front panel buttons in the software. (Settings > Scan Settings > Button Settings)
If this doesn't work, try a different USB cable, a different USB port on your computer and a direct connection (if you are using a USB hub). Scanners require bi-directional communication with the computer and may fail when the printer works due to a minor cable issue. If you have the printer connected to a router or similar device to turn it into a network printer, again the scanner will not work. Again the direct connection to the computer is needed.
If you are still having trouble, can you use the all-in-one's copy function? If not, do you have any error messages? If the scanner mechanism isn't moving, the unit probably needs service. (This model doesn't have a scanner lock to protect the mechanism in transit.)
I hope this helps.
Oct 15, 2012 | Office Equipment & Supplies
I'm trying to scan an A4 size sheet(document). I was getting the same size of the scanned sheet, but now its shrinked its size so that I can not getting the same size as in the sheet. Please help me...
Hi
Try the HP software rather than the Scanner itself.
HP Solution Center > Settings > Scan Settings > Scan Document Settings > make sure it is set to Scan Document as Image (no OCR) > Apply > OK.
I hope this helps.
Aug 24, 2011 | HP ScanJet 2400 Flatbed Scanner
HOW TO SET HP LASERJET 1005 PRINTER SCANER ERROR 12
how to solve engine scanner error for hp laserjet p1005
Oct 10, 2010 | HP LaserJet M1005 All-In-One Printer
I need help setting up my hp scanner Officejet 5610 all-in-one
Put the disc in, follow the instructions, and plug the device in when it asks
Jul 22, 2010 | HP Officejet 5610 All-In-One InkJet...
Free driver for HP ScanJet 6300C
ftp://ftp.hp.com/pub/softlib/software3/sj675/sj-22000-1/sj675en.exe
Download the file above > unplug your scanner > install the file above > reboot your computer (if needed) > login into your account > plug the scanner into your usb port > it should automatically detect your scanner > goto device manager > imaging device > right click HP Scan Jet .... > Click on Driver Tab > Click on Roll Back Driver > choose to run the driver on windows xp compatibility mode.
Or use the compatibility wizard to set scanjet pro to run on windows xp compatibility mode
Jun 21, 2009 | HP Scanjet 6300c Flatbed Scanner
HP 3570 scanner not copying true colors.
Chuck the scanner (in my bin please) as the CMOS sensor is bad. Pick up a replacement at Goodwill for $10.00 and post for any help you need
Or sell it on Ebay for .99 + 20.00 postage.
Mar 27, 2009 | HP ScanJet 3570C Flatbed Scanner
Hp laserjet3050 scanner error:not set up on pc"
hp has a website that you can download your drivers for your printer/scanner for free
Feb 27, 2009 | HP LaserJet 3050 All-In-One Printer
Lost software setup hp scanjet2400
Hello there Please copy and paste the following address into your Web Browser, this will take you to HP's website where you can download the drivers for whichever version of Windows you use.
The address is http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&cc=us&product=297430&dlc=en&
Hope this helps.
Apr 09, 2008 | Office Equipment & Supplies
HP SCANJET 8250
Do you have the scanner set for "duplex" (two-sided) scanning? Check the switch near the front of the unit.
Feb 20, 2007 | HP Scanjet 8250 Flatbed Scanner
HP Officejet 5610 All-In-One InkJet Printer Logo
144 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
