Question about Amana AFD2535DES French Door Refrigerator
Maytag Washer model# mah3000aww
Hi
I just replaced the wax motor for the door lock in the door. but the door lock still doesnot work and the spin cycle is not working because of it. I have power to the wax motor and I have tested the micro swithces on both sides of the latch and the door lock litghts up and the spin cycle works. help
any ideas
Michael
    President:
  • Amana Master
  • 2,651 Answers
Out of curiosity why did you replace the wax motor?? did you also replace the machine control board behind the console??? usually thats the issue with this machine is one or the other goes bad and recommend fix is to replace both.A quick visiuall check will determine if htis needs replacing as well, theres athermisotr the blows out). you say you get power to the wax motor, so it should then energize pushing forward into the next to switches, firs one locks door and put on indicator light, the second is actually the spin switch that needs to be activated for the machine to enter a high speed spin
Posted on Mar 26, 2008
SOURCE:
Tip
Maytag Neptune Front Load Washers No Spin Problem
A class suit was filed in the State of Illinois, USA and then later on won against Maytag in 2004 due to the high failure rate of the wax motor used in the door lock mechanism of their Neptune Front Load Washers. The wax motor is used to activate the door lock switch by extending its shaft when a voltage from the machine control is applied across its terminals. Its failure then leads to the breaking down of components in the expensive machine control board. This is the fact that angered the customers which led to the filing of the class suit.
The obvious symptom of a failed wax motor is the inability of the washer to advance to the spin cycle and the door lock lamp is not turned on. The washer stops momentarily at the end of the wash cycle then continue to tumble as the machine control checks the activation of the door lock switch. The control will not allow a spin speed higher than 51 revolutions per minute (RPM) unless the door lock switch is activated by the wax motor. It is a safety feature of the washer to prevent accident due to accidental opening of the washer door during a high speed spin.
Customers who purchased the Neptune Front Load Washers in the USA after April 1, 1997 and before August 9, 2004 are Class members and eligible for the repair reimbursement, replacement cost, or purchase certificate depending on the length of service of the machine. Call up Maytag at 1-888-MAYTAG (1-888-629824) for more information.
The models included in the class suit are as follows: MLE2000AYW, MLE2000AWW, MLE2000AZW, MLG2000AWW (Gas Stack Unit), MAH3000AAW, MAH3000AEW, MAH3000AGW, MAH3000AWA, MAH3000AWW, MAH3000BGW, MAH4000AWW, MAH4000BWW, MAH4000AWQ, MAH4000BWQ, MAH5500AWW, MAH5500BWW, MAH5500BWW, MAH5500BWQ, MAH55FLBWW, MAH55FLBWQ, MAH6500AWW, MAH6500AWQ, MAH7500AWW, MAH7500AWQ, MAH7550AAW, MAH7550AGW.
on May 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
Model MAH3000AWW won't spin
As giving info it seems it needs new control board and door lock .as I could see this is very old model and parts are very expensive
May 06, 2014 | Maytag Neptune Washer Door Mah3000aww
The washer door lock light and lock does not work on my Neptune Model # MAH3000AWW. also the cloths don't spin dry they are very wet after the spin cycle.
NEPTUNES HAD A PROBLEM WITH THE WAX MOTOR THAT LATCHES THE DOOR, DISCONECT THE POWER, REMOVE THE SCREWS ON THE TOP OF THE COUNSULE. TIP THE COUNSULE TWARD YOU AND DOWN. YOU WILL SEE THE MAIN BOARD LOOK FOR THE R-11 RESISTOR AND SEE IF ITS BURNT.IF IT IS YOU NEED A NEW BOARD AND DOOR LATCH WAX MOTOR. IF NOT YOU HAVE A PROBLEM WITH THE LATCH ***. GOOD LUCK!
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Jan 16, 2010 | Maytag Washing Machines
Maytag neptune MAH3000aww washer, will not work on spin cycle. Over 10 years old, is it worth fixing? What will this cost to fix?
NEPTUNES HAD A ISSUE WITH THE DOOR WAX MOTOR SHORTING OUT BUT IT BURNS OUT THE MAIN BOARD.IF THE DOOR LOCK LIGHT DOES NOT COME ON REMOVE POWER THEN REMOVE SCREWS OFF THE TOP OF THE TIMER COVER AND TIP IT FOWARD. LOOK ON THE MAIN BOARD AND SEE IF YOU NOTICE A BURNT RESISTOR P-11 POSITION I BELIVE
Jan 12, 2010 | Maytag Washing Machines
Hi just got a set neptune model mah3000aww the
your main control board and the actual lock,
open the three screws on the top of the control board..
you will see the machine control
without disconnnecting the wires , inspect the board as closely as uou can your looking for physical burn on the board,,,, this usually takes place on the lower left area of the board
there you will see a burnt resistor, r-11
you will need to replace that control http://www.appliancepartspros.com/partsearch/model.aspx?model_id=46137&diagram_id=692382#d692382
the board is 138.00
you will also need to replace the wax motor lock above the door
but is sounds like you just bought them
do you have a wrrenty of sdome kind
if you wish to make the repai let me know i will walk you through it it prety easy but can be tricky
Oct 28, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune mah3000aww spin problem
there are 2 wires going back to the board. They connect to a blue harness. Make sure their is continuity thru the harness. It connects to 3 out of balance swithches. Also check to see if lock light comes on.
Jul 07, 2009 | Maytag Neptune Washer
Maytag neptune washer MAH3000AWW
order the wax motor kit and replace parts from the internet. there are plenty of videos how to do this. it does require minor soldering and a little mechanical aptittude.
Dec 30, 2008 | Maytag Neptune Washer
re original issue, see if R11 is burned. if so, need to change R11 resistor and associated triac, and probably wax motor so it won't do it again. temporary fix just cut out R11, door won't lock. if your model won't spin that way, depress actuator for microswitch from door wax motor. instructions on web.
Jan 19, 2008 | Maytag Neptune Washer
Amana AFD2535DES French Door Refrigerator Logo
80 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Steve Allison
Steve Allison
Thomas F. Schneider
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
