Question about Craftsman 26 Hp 54" Deck Yard Tractor
Can i use a synthetic oil in a 26hp kohler engine garden tractor
If it helps, I have the same tractor and I have been using synthetic mobil 1 for 4 years. No problems, and the oil is always golden brown without changing... Seems to work great.
Posted on May 21, 2010
  • 2,100 Answers
Sure, why not? They make synthetic oil for everything now days. Regular oil is fine for tractors though. It's not like they are racing up and down the street. No high mileage. But it is up to you, remember to write down the date so you can remember when you put it in, it will never break down like conv. oil. Might be good for 15 years! Hope this helps.
Posted on May 03, 2010
When I try to lower engine rpm by retarding the throttle control to idle the engine speed does not change?
Your throttle cable is screwed up , you can probably fix it without buying anything. It probably just came unattached
Jul 02, 2015 | Kohler Cub Cadet LGT 1054 54" 26HP Lawn...
26hp kohler engine started smoking suddenly. still runs good.whaat would cause this problem.
Head gasket blown. This is a very common issue with these V twin Kohler engines. There is a kit you can order from Kohler that includes gaskets and new improved head bolts. Simple hand tools is all that is needed. You will need an inch pound torque wrench. Torque specs are included in the kit.
Jul 23, 2014 | Craftsman Garden
What would cause 26hp kohler engine to start smoking suddenly?
Could be many things. Are you using multi viscosity oil instead of sae 30? Small engines will consume multi viscosity oil. Were you mowing or driving on a hillside when this happened? Is the oil level over the full mark? Could be worn piston rings, worn valve guides also.
Replcement oil filter husqvarna model ltg2654
their are a few different filters for your rider --these are for the kohler 26 hp motor stores like home depot- lowes- sears- or small engine repair shops carry filters K&N PS-1002 http://www.sears.com/ayp-genuine-ayp-part-578416804-oil-filter-kohler-cou/p-SPM8242278631?redirectType=SKIP_LEVEL http://www.knfilters.com/oil_filter/all/kohler/sv735/26hp
Jul 10, 2014 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Lawnmower looses power. Sounds like it is running on one cylinder. Have changed spark plugs, air filter, gas filter, drain gas, pulled fuel cylinoid from bottom of carbarator and drained. Replaced and...
Hi, first check the oil. If it smells like fuel, change the oil. Secondly if oil smells ok, check the valve clearances and adjust if incorrect. Let me know if the oil smells like fuel and I will help with a fix to stop it happening again. Regards Phil.
Aug 05, 2011 | Craftsman 26 Hp 54" Deck Yard Tractor
DGS 6500 w/26hp Kohler Courage surging
i HAD SIMILAR ISSUES WITH MY 2500 SERIES CUB CADET....IT WAS THE CARB.....REPLACED, AND ALL HAS BEEN WELL...THINK IT WAS APROX 200.00
Jul 03, 2009 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
Craftsman mower with 26hp kohler smokes when i cut on hill, why?
what happens is the oil gets into the valves which will come out the exhaust when on level ground after a side to side or going straight down because the valve's are in the front of engine which is pointing to the front of mower you wont hurt the engine if it does that i would just check the oil often to make sure it doesn't run out
Jun 13, 2009 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
Craftsman 26 Hp 54" Deck Yard Tractor Logo
366 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
