Question about Dell Dimension 3000 PC Desktop
I have a Dell Dimension 3000 that I need to hook up to a Verizon Wireless situation. It has a Netgear card in it, plus the antenna for the back. The NetGear info. on the screen shows it has a Very Good connection, but will not "turn green" to give the connection. Any help is appreciated - we called Verizon and they were of no help. Thanks.
  • Mihajlo Jerkovic May 11, 2010
    Is this verizon fios or dsl? What windows are you running? How far from router? What kinda router (model) Is this the only computer that cant connect wireless?
    Sergeant:
  • 356 Answers
Have you installed the Netgear wireless card driver already?
If you did, then go to the network connections on Control Panel and right-click the wireless icon then select "View Available Wireless Networks".
On the left hand side of the window, click "Change advance settings". A window will appear and see if you have a wireless tab. If you don't have the wireless tab, do these steps:
Click Start, then Click Run. Type services.msc and click ok.
Scroll down all the way to the bottom and double-click Wireless Zero Configuration and set it to automatic then click the "Start" button to start the service. Close the window.
Again, go to the network connections in control panel and right-click the wireless icon. Click the Change Advance Settings again and now you'll be able to see the wireless tab. Click it and put a bullet-point to "Let windows manage wireless connections" Click apply and Close or OK.
Right-click again the Wireless icon to view available wireless networks. Wait until the window populates and click the name of your network. Click connect and enter the password if prompted.
Happy surfing!!! ^_^
Posted on Jun 13, 2010
How do i access wireless internet on a dell dimension 4500s computer to a actiontec m1000 router
To RESET the Netgear, power up the Netgear then press and hold the RESET button at the back of the router until all the LEDs flash. Connect a LAN cable from the Netgear to the LAN port on your computer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = password You can now change the default admin password and configure the wireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2 encryption.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Oct 03, 2012 | NetGear WGR614 Wireless Router
Where is the wireless switch on a Dell dimension 3000 desktop
HelloIt doent have wireless card by defaul, you may install wireless or wifi card then it will work on wireless
Apr 13, 2012 | Dell Dimension 3000 PC Desktop
I use to use a netgear wireless network adapter on my Dell Dimension 3000 which i no longer use. I plug the LAN wire from my netgear router (which is working with multiple other appliances) and it doesn't...
Sorry to read about your problem, I hope this helps you out.
somewhere along the line you turned off the on-board network card. you should goto the network settings and remove the netgear wireless as you network connection, and run connection manager again.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 03, 2011 | Dell Ethernet Card Network Adapter
How to connect a netfear router to a dell computer
I assume the Netgear is a wireless router and you want to connect to the router using a wireless connection.
Make sure the DELL computer wireless card is installed with the latest wireless card driver.
The Netgear router needs to be configured with the wireless settings ie SSID and encryption etc.
Next the wireless card needs to be configured with the wireless router's settings, ie SSID and encryption etc.
For instructions on securing and configuring the wireless router and wireless card please click in this link :-
Dec 23, 2009 | D-Link Air Plus DP-G310 (dpg-310) Print...
Wireless router with dimension 3000
It seems that you have Dell Desktop computer, unless you requested a wireless card to be put into the computer, it would not come with one. Just like stang_1 mentioned, you should check your network adapters to see if your wireless card is listed. Also since it is a desktop, you can check the back of it to see if you have an Antenna sticking out of it. That would indicate that you have a wireless card on the PCI slot. And if that is the case and you do not see it listed in the network connections, check the Device Manager and make sure that the drivers are installed properly.
Apr 14, 2009 | Dell Dimension 3000 PC Desktop
Wireless internet
you need to get a PCI Wireless card or a USB Wireless adapter, if you are talking about an 802.11 wireless router.
If you are talking about Sprint wireless Broadband or the link (WWAN service) you'll need a USB WWAN adapter which are available by all major Wireless vendors (Verizon, Sprint, ATT etc(
Jun 25, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
CARDS FOR Dell Dimension 3000 PC Desktop
Dimension 3000 accepts only regular PCI cards according to the Dell site.
Dec 24, 2007 | Dell Dimension 3000 PC Desktop
Dell Dimension 3000 PC Desktop Logo
132 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
