Question about Car Audio & Video
Directed dv2005 model
I'm having trouble installing my system. My car was recently broken into and the system was torn out.
  • Tone1990 Mar 28, 2008
    INSTALLING A CAR DVD SYSTEM AND MONITOR...
  • Anonymous Apr 08, 2009
    need wiring diagram so i can install
What exactly do u need help with! installing subs or amp or cd player unit!
Posted on Mar 27, 2008
Daily starts not programmed
you need to take it to the remote start system installer - they may be able to change the coding of the signal to avoid this proplem or they may (worst case scenario) have to disable the remote starting part of the system until the cause can be identified and corrected.
Apr 05, 2014 | 477A Automate 2Way Replacement Remote ...
I cant start car with my phone
Smart Start not working?! Was the unit tested for signal strength and proper operation after installation? If so, and the unit works, did you receive confirmation from Directed Electronics with a link to set up your account? Did you activate your account with Directed Electronics? After activating, did you download the app through your phone?
If you have done all of the above and the Smart Start still does not work, your next contact should be made with Directed Electronics and the installer.
**Please Note** Downloading the app without activating unit does nothing. Installing the unit without following the setup and test procedure does nothing.
Jan 29, 2013 | Viper SmartStart Module
Can i run system mechanic and norton 360 together
You can reinstall system mechanic but it will still cause conflicts with Norton.because Norton also offers a similar product to system mechanic called as Norton utilities.If u still want to install it without causing any troubles.Then u have to disable real time scanning of system mech. Go to>options tab>select dashboard>make tune updefinition status to hide permanently and save.Also SWITCH OFF IDLE TIME OPTIMIZER IN Norton. Then both will exist without any problem
Apr 29, 2012 | Symantec Norton 360 Premier Edition Full...
I recently purchased a used 98 isuzu rodeo. It didn't come with the remote. I purchased a used remote and tried everything to get them to work. I also have followed all the steps to get the truck to...
It might not be a factory installed system. Your best bet is to look around under the dash near the steering wheel and to the left for a black box with a bunch of "obviously not factory installed" colorful wires leading to it. It should have a brand and model number, with which you should be able to find the appropriate remote. Common brands are Clifford, UltraStart, Viper, Directed, Bulldog and others.
Jul 01, 2011 | 1998 Isuzu Rodeo
I have a remote starter installed in my vehicle as well as a security bypass for the passlock 2 security. I could not get the ohms reading to set the system. I tryed a combo of resistances with no success....
http://newrockies.ca?ap_id=judd0081
----- With this fix, you can take that whole Vats, passlock, passkey garbage system out of your car all together. I know it seems like a risk at 200 bucks, but seriously i had no happier day than when i finally got that thing out of my car. I'd been dealing with a "sometimes starting" car for a year. Trust me, this exactly what you need. They have a 100% money back guarantee+shipping, a support line, and pictured instructions,I couldnt be happier and i KNOW this will help ya. Took me about 45 minutes to locate the part in my car, and 10 minutes to install the bypass. LOL
Eliminate it, instead of using that resister as a bandaid
Jan 11, 2011 | Directed 24921 DIY Basic Remote Car...
I have a Directed D2400 amp and my red ESP is on
ESP ties the amp into your vehicle's alarm system. If the amplifier is working normally you can ignore the light. Note that this is NOT the protection LED for the amplifier.
Nov 04, 2009 | Directed 2400d Car Audio Amplifier
VIPER 160XVL remote start stopped working
sounds like the unit has lost power. i can't tell you where the relay is located for that device but it may have failed.
Oct 19, 2009 | Viper 160XVL Viper 160XVL Remote Start...
Toshiba 2060 jams (accordion/fans the paper) at the fuser unit. Torn Paper now stuck next to the roller/drum and now jams every time. How do I remove the torn bits of paper to keep it from jamming?
sounds like a broken fuser drive gear.The fuser operates a nearly 400 degrees Fahrenheit and the drive gear cracks and falls off.Lots of trouble for a 50 cent gear.They are mad of fiber or plastic.take a few of the covers off near the fuser and disconnect the cables and the fuser slides out
Jan 11, 2009 | Toshiba 2060 Copier
Recent trouble with downloads
I suggest you use System Restore, to remove Trend PCillin. (any files and folders will not be affected by this procedure).
Run system restore as follows:
Start, Programs, Accessories, System Tools, select System Restore. Choose a restore point on a date before you installed the problem program. The procedure should take about 15 minutes.
Jan 04, 2009 | Computers & Internet
Car starter not working
look under the dash for a small silver toggle switch....this is a disable switch for the remote start portion of the system..you may have kicked it / bumped it with your foot, causing the remote start portion to be deactivated. Just flip the switch the opposite way and try again..
Also, there may have been a pin style switch installed under the hood...Check to see if it is bent or broken, if it is, simply disconnect it and insulate the wire that was going to it.
This wire is used as a safety to keep the vehicle from remote starting while the hood is up..to keep people from being injured if the remote start is activated while the engine is being worked on.
Have whatever shop installed the system replace your pinswitch if that is the problem.
Dec 16, 2008 | DEI Valet Keyless Entry System
Car Audio & Video Logo
157 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
