Question about Iomega 1TB Desktop USB 2.0 Hard Drive
Hard Drive not recognized by laptop
Hi, my hard drive is not recognized by my laptop (connected via USB). It was recognized 2 days ago, up until when I switched the power off on the drive. Now, when I switch it on, the power light comes on but there's only a clicking noise coming from inside the drive and sometimes a buzzing noise as well. I have checked the power and the connection which are both well connected.
    Problem Solver:
  • 16 Answers
The Hard Drive could have come loose from the SATA or PATA connection, or your Hard Drive could have simply died. If it is still under warranty; replace it. If it is out of warranty; open the external casing and check that the HD is connected and / or test the HD in a separate external casing or Desktop that you have. If it is connected and the external casing is working properly (or Desktop is booting properly and can read it), then you have a dead Hard Drive and will have to buy a new one.
Posted on May 03, 2010
  • lydiaawoll Sep 23, 2010
    is it possible to recover the data on such a hard drive?
My pc and laptop not detect my Maxtor OneTouch III Mini External 100GB USB 2.0 Hard Drive R01E100 what can i do please help me soon as possible
Good Day Anantsharma8!
If your PC and Laptop can not detect your external hard drive, I do suggest you check its usb cable. A substitute cable will confirm if your current usb cable is faulty or has an open wire.
Most common reason why the external hard drive is not recognize by PC or Laptop is due to loose connection of the hard disk inside the connectors of the enclosure.
Anantsharma8, if you have a small precision screw, I recommend you open the enclosure of the external hard drive. Remove the front face where usb and power plug connects, then slide it out to expose the hard disk also. You will see two connectors. These are the ones that always loosen. Please disconnect both the connectors and then connect it again properly. Put the hard disk back, close the enclosure and try to connect again with your PC or laptop via usb cable.
Good Luck! I hope that it will soon recognize your external hard drive.
Jun 10, 2011 | Maxtor OneTouch III Mini Edition R01E100...
MY HITACHI 1 TB HARD DRIVE IS NOT BEEN RECOGNIZED BY MY SONY LAPTOP. IT WAS WORKING WELL 2 WEEKS AGO , HOWEVER TODAY I UNPLUGGED THE HARD DRIVE DURIN TRANSFER SOME FILES. UNTIL THAT MY COMPUTER STOP...
hello, if the hdd is not being recognize by your Sony laptop, may be because the device is not responding any more, anyway this is still new you can have that Hitachi replace via the warranty, but your not suppose to tell them what happen cause that would fall for intentional damage. Just tell them it stop working. Thank you for using Fixya
Mar 06, 2011 | Hitachi 1 TB SATA Hard Drive
I have an Iomega external hard drive but my Acer Aspire One will not recognize the drive. It worked yesterday but today it is not recognizing the drive.
Hi
I guess that you have connected the external hard drive via a usb
have you tried plugging it into another usb
if it were not the case that it was working yesterday i would of said make sure the jumpers on the external hard drive are not set to master either take off completely or set to slave
hope this helps
Nov 18, 2010 | Acer Aspire One PC Notebook
Vista stops recognizing external hard drive
This doesn't sound like an OS issue. This appears to be more an issue of the connection to the hard drive. The USB cable likely isn't the culprit, nor the laptop USB inputs. If the drive was ever dropped or the cable gets removed and reattached often to the actual enclosure, you might be looking at a bad port on the enclosure. This isnt a lost cause. You can always buy a hard drive enclosure from newegg and move the drive from the IOMEGA to the new enclosure. You can get a new enclosure for $15. Just because the USB port is bad, it doesnt mean the data is gone and the hard drive cant be used.
Aug 26, 2009 | Iomega 33089 250 GB Hard Drive
My laptop HP zd8000 doesn't recognize Seagate external hard drive
hi..the reason for your problem is your extenal
hard drive has been affected by viruses.The best
solution to this problem is scanning your hard drive.
once you scan it u will be free of viruses and your
laptop will be able to recognise your hard drive.
try it out..
thank u..
rate me..
Feb 10, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
My PC is not recognizing my WD Passport 120GB USB external drive. I used just few days ago and connected the usb cable to my computer and the WD Passport drive and not recognized on my 2 laptop and 2 other...
I have the 80GB WD passport and it suddenly stopped working one day.  The unit lights up but nothing else.  Finally I cracked the case open and found, as I suspected, that the drive is simply a SATA laptop drive with a SATA-to-USB conversion card built in.  I suspected that the card was **** so I disconnected it and used a USB hard drive adapter (http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=3770&name=USB_Hard_Drive_Adapter) and I can read/write to the drive just fine.  Best part is that the adapter I use has its own power supply so I'm not pulling juice through the USB cable for a SATA drive.
Even though mine "works" again I don't recommend these drives to anyone.  They're just not sturdy enough or well designed.
Sep 09, 2008 | Western Digital Passport WDXML800UE...
Does you drive make any sounds like these? If yes you have a mechanical problem and you should get a specialist to work on it.
If not - try to remove the drive from the enclosure and connect it directly to the computer to recover your files.
Jul 30, 2008 | Western Digital Caviar WD2500BB 250 GB...
USB device not recognized
if it,s showing in the device manager as an exclamation mark. that means it,s found it, but can,t recognise it.
i,d suggest formatting and partitioning it, with some good software. also ensure that it,s powered via 2 usb cables to laptop, from 1 on the drive itself. some bigger hard-drives, need the extra power to drive them.
Mike @ compurepair.
Jul 25, 2008 | Western Digital 500GB My Book World...
External Hard Drive No Longer Recognized
hey im the same person who just posted above. i went to WD's website, and it said unplug the hard drive from the computer, and unplug it from the power source. then plug it into the power outlet, wait for it to spin up, then plug it in via USB/Firewire, whatever. it worked for me, so hopefully it will work for you.
May 11, 2008 | Western Digital My Book Home Edition 500...
Iomega 1TB Desktop USB 2.0 Hard Drive Logo
1,047 people viewed this question
Top Iomega Computers & Internet Experts
Owen Barnes
Martin Murray
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
