Question about Belkin (F5D7231-4) Wireless Router
It sometimes drops connection to my ipod touch
    President:
  • 524 Answers
Hello, Belkin usually will have an Idle Time (Minute) > setting, which can be found in the WAN setting menu option.
Check your idle time and adjust as needed.
One other problem I had worth mentioning was that I was not able to access certain section of certain websites for eg Yahoo mails 'view email'.
This is sometimes the result of bad MTU settings.
In my case the router defaulted to an MTU value of 1456. I changed that to 1400, which did the trick for me.
Please let me know if you have any further questions or concerns.
Thanks.
Posted on May 09, 2010
My ipod touch 4th generations says ipod disabled connect to itunes, but screen is locked
Like all electronic devices, iPods sometimes freeze and become unresponsive. Sometimes iPods lock up when they're dropped on the ground or come in contact with water, but less destructive accidents may also cause them to stop working. All versions of the iPod have a way to reset their hardware should they stop playing music or refuse to turn off.
Check the "Hold" switch on the top case of your iPod to be sure it isn't activated. An iPod will appear frozen and unresponsive if this feature is activated. A lock symbol will appear on your iPod's screen if it is in Hold mode. Switch the "Hold" button on and off once. Place one finger on the "Menu" button and another on the center button. Press both buttons at the same time and hold them for up to 8 seconds. Release the "Menu" and center buttons once the Apple logo appears on your iPod's screen. Try releasing the buttons and pressing and holding them a second time if the logo does not appear, as it can sometimes take several tries to reset a severely frozen iPod. Press and hold the top button and the center "Home" button on a frozen and unresponsive iPod touch to reset it. Hold the buttons for at least 10 seconds and wait for the Apple logo to appear on the screen, then release the buttons. Connect your iPod to its powerblock or a computer if it is still frozen. Wait 5 minutes and then try to reset it. Sometimes an iPod can appear frozen when its battery runs out and just needs a few minutes of power to start working again. Hope this helps.
Jan 19, 2013 | Apple iPod touch 4th Generation MP3 Player
Tip
How to unlock an iPod Touch if you forget the password
<p>If you have an iPod touch, you have the option of a password that Apple calls an access code, protecting your data set. Someone trying to access your iPod, after unlocking it or put it, the access code required to do so. However, if you forget your password or the wrong type, you will eventually see a warning that the iPod touch has become disabled. In order to unlock the iPod touch after you forget the password and still access your content, you must connect to the computer that was last synchronized. <br /> <p><br /> <p>1. Connect your iPod touch to the computer the last time you synced the music. Open iTunes if it does not open automatically. <br /> <p><br /> <p>2. Select your iPod touch in the Devices list and click the "Summary" tab in iTunes. Click "Restore" and when prompted, click "Back Up" button to make the backup to store your iPod touch in iTunes. <br /> <p><br /> <p>3. Click "Restore" when prompted, after the backup saved. After the restoration, click "OK". <br /> <p><br /> <p>4. Choose the most recent backup from the drop-down in the "Set up Your iPod" screen. Click "Continue" to restore your iPod touch. <br />
on Jul 21, 2011 | Computers & Internet
How do I fix my frozen e reader
Jan 19, 2013 | Apple iPod touch 1st Generation (8 GB) MP3...
My 32G iPod Touch won't stay connected to my Home WIFI
go to settings,general,wifi, turn on wifi
if that didnt work go to the apple retail store and theyll help you for sure
if not they cheack the warrenty and give you a new one
Dec 31, 2009 | Apple iPod touch
My Ipod touch 16G first generation. wont respond to my touch even to turn it off. its at the screen where it says slide to unlock and it wont respond to my touch.i havent dropped it and its in excellent...
1. Plug the iPod into the primary computer linked to that iPod, the first computer you synchronized it with unless you have designated another computer as the primary computer.
2. Open iTunes and sync the iPod as normal.
3. Remove the iPod, following the normal removal procedure. The iPod unlocks automatically as you remove it.
Oct 31, 2009 | Apple iPod touch
Visual land v-touch keypad locked
  1. Connect your iPod Touch to the computer you usually sync it with. When you disconnect your iPod, it should now be unlocked.
  2. If Step 1 does not work, you have to restore your iPod Touch. Be advised that restoring your iPod Touch returns it to the original factory settings. This means that all your songs and files will be deleted and lost. You can resync your files to your iPod from iTunes once you have finished restoration. Connect your iPod to your computer and open iTunes. Make sure you have the latest version of iTunes before proceeding.
  3. In the left navigation panel in iTunes, select your iPod under the "Devices" section. Click the "Summary" tab and select "Restore."
  4. When iTunes prompts you about backing up your data, click "Back Up." In the following window, click "Restore."
  5. After the restore process completes, you will see the Apple logo on the screen of your iPod. Leave your iPod connected to your computer until it shows up again on the iTunes navigation panel.
  6. Your iPod touch is now unlocked. In iTunes you will be able to setup your iPod. Select the backup you made in the drop-down menu to restore your data files. Click "Continue" to finish the restoration.
Sep 25, 2009 | Apple iPod touch Second Gen (8 GB,...
I entered in the wep code correctly, and it says that it is connected, but when I try to get on the internet, it says that it isn't connected. (i am talking about an iPod touch 2G by the way)
as An iPod touch user i have noticed that sometimes the wi-fi takes a min or two to connect even after it says its connect this how i fix mine and will hopefully work with your so connect your iPod touch as normal then go to the home screen but don't go to the internet instead go back to your wi-fi settings and just let it sit there it should show the wi-fi and now you should be connect for real
and the other option would be to manually enter your routers name and choose your secerty level then the ipod touch should re request the password and that should connect you
Jul 26, 2009 | Apple iPod touch
The light on my ipod touch dose not turn on?
hold the sleep button for about 5-6 seconds and restart it. Try that a few times, and then if that does not work, connect it to the computer and hit the 'restore' button and see if it will restore the light. Try to charge it also, sometimes that will help.
Jul 15, 2009 | Apple iPhone Smartphone
Ipod touch has low wifi signal and will not assign an IP
Sometimes, usually happens when it's put together wrong though; happens sometimes. Be carefully taking it apart, the iPod Touch is snapped together, so be patient with it.
Nov 29, 2008 | Apple iPod touch
IPod Touch
Try this - connect your iPod to computer --> double-click on My Computer --> double-click on the icon of the iPod --> double-click on the music folder --> drag and drop the msuic files to a folder/desktop of your own choosing
Is it a Fixya?
-Tha Mp3 Doctor
May 26, 2008 | Apple iPod touch
Belkin (F5D7231-4) Wireless Router Logo
245 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
