Question about Lexmark C524 Laser Printer
There is a problem 120.10 Service Fuser Error
    Genius:
  • 1,087 Answers
This error normally requires a service call. The fuser is not receiving the right amount of power. But try this. Power the printer off, wait ten seconds, and then power the printer back on. If possible, connect the printer's power cord directly into a wall outlet. In rare instances, a surge protector or uninterruptible power supply (UPS) can generate false error messages. If problem is not resolved, printer needs to be serviced.
Posted on May 03, 2010
Call for service C 430
All error code soloution of fuser unit Fuser Unit Error Status Counter
Purpose
When a fuser unit related error (error code C41, C43, C44 or C45) occurs, the set value of the fuser status
counter varies, depending on type of error.
Displaying and checking the set value of the fuser status counter can analyze a cause for the error. If
any of "2 to 9" is set at the fuser status counter, the fuser unit will not be operated for safety reasons.
After the fuser unit related error is resolved, if "0" is set, the fuser unit will be operated as usual. If any of
"10 to 19" is set at the fuser status counter, the fuser unit will be operated as usual, even if "0" is not set
after the fuser unit related error is resolved.
C41: Thermistor or heater abnormality at power-ON
C43: Thermistor abnormality after abnormality judgment
C44: Heater abnormality after abnormality judgment
C45: Thermistor abnormality during printing
C46 to C49: Reserved
Description
When this code is used, the current set value of the fuser status counter is displayed. Only "0" can be
manually entered, in order to restore the fuser unit to its normal operation, after the fuser unit related
error is resolved.
For further reason why the counter value differs despite the same error code, refer to 5.1.7 or 5.1.8
[Fuser unit related service call] in the Service Handbook.
0: No error 10: C47 (Reserved)
1: C41 (Once) 11: C47 (Reserved)
2: C41 (Consecutively occurs) 12: C48 (Reserved)
3: C46 (Reserved) 13: C49 (Reserved)
4: C43 14: C47 (Reserved)
5: C44 15: C48 (Reserved)
6: C45 16: C49 (Reserved)
7: C44 17: C47 (Reserved)
8: C45 18: C48 (Reserved)
9: C44 19: C49 (Reserved)
* Default: 0
Setting Timing
Use this code to resolve the fuser unit related error (error code C41, C43, C44 or C45). Resolve the
error, and set "0" (or reset the counter), in order to restore the fuser unit to its normal operation.
Caution
Remember to resolve the fuser unit related error, and then reset to "0."
Dec 31, 2013 | Toshiba estudio 255 Copier
If problem persist contact dealer or service rep turn the main power on e301-0001
This is a fuser error, the fuser replacement for this machine is best done by a technician as there is moderate disassembly involved..
Your local canon warranty agent will be a good place to start.
This same printer engine is used in a few HP printers and multifunctions and the fuser is available from HP as well. Though HP are usually slightly dearer.
If you want to have a go yourself the part number is one of the following, depending on your electrical grid voltage un your part of the world
Canon imageCLASS MF4450 Fuser (Fixing) Unit - 120 Volt
RM1-7576-000
or
Canon imageCLASS MF4450 Fuser (Fixing) Unit - 230 Volt
RM1-7577-000
Oct 26, 2013 | Canon ImageCLASS MF4450
921 service Fuser error
921 Fuser Error indicates that the fuser unit failed to reach the standby temperature. Leave the printer off for at least 10-15 seconds before turning it back on. This gives the printer's engine board a chance to reset. Make sure printer is plugged in straight to the wall, bypass any surge device or power strips as this can cause a low amperage problem in your printer which can trigger a false fuser error. If this does not help, you'll probably need service on the machine since it deals with the LVPS, the fuser and the system board.
May 19, 2010 | Lexmark Optra M410 Laser Printer
Hi ihave a panasonic kx-mb781 and it say on
Fuser unit cannot heat up. Replace fuser unit.
Refer to CALL SERVICE 3 (P.120).
Mar 26, 2010 | Panasonic KX-MB781 All-In-One Laser...
Ir6570 with e000100-001 error
if you reading it right on the screen an e 000100 is a laser failure it also happens on this model if you run it with the toner assy out of position
Sep 09, 2009 | Canon imageRUNNER 5570 Copier
Error 58.04
This is from the service manual and should help you determine if you need to call in for service. If is in warranty I would anyways since the fuser would be covered if at fault.
58.04 ERROR To continue turn off then on. The low-voltage power supply has experienced an error.
1. Reinstall the fuser. Check the connector
(J1901) between the fuser and product.
Replace the cable or fixing unit if the
connector is damaged.
2. Reconnect the connectors of the fuser
control PCA (J303, J305) and the DC
controller PCA (J107).
3. Replace the fuser. See Fuser
on page 191.
May 03, 2009 | HP LaserJet 5200tn Printer
Lexmark C534DN. Getting eror 120-10. How to repair?
This message indicates that an error has occurred in the fuser. Turn the printer off. Remove and reseat the fuser. Turn the printer on again.
If the error continues remove the fuser again and check to see that the cam shaft follower ( on the right side) is properly in the groove. If it is above the cresent shaped groove, press it down into the groove.
If it is correcly in the groove, then the fuser will need to be replaced.
Sep 25, 2008 | Lexmark Office Equipment & Supplies
980: Fatal Error
From the Service Manual:
*Service call
980:Error
*Error by media
clinging to the fuser
*Media has clung to the fuser.
*Power OFF
Replace the fuser unit.
Suggestion -
Before you replace the fuser, take it out and check for a piece of stuck label, paper, etc. You can spin the fuser roller by turning the gear on the side.
Apr 07, 2008 | OKI C5800Ldn Led Printer
Lexmark C524 Laser Printer Logo
129 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
