Question about RCA HD52W59 HDTV Projection Television
Rca hd52w59 when power is on and tv is running there is a high pitch sound comming out along with the reg. sound the high pitch seems to come from rear of tv. if you tap on back of panel or shake cables it will stop for a little while then start up again. i have removed all cables and tried all combos. even with no cables at all still has high pitch sound have had tv for over a year problem started about week and a half ago.
    Genius:
  • 1,030 Answers
Ok does the set show a picture durring this whinning
i have ran into this problems .. sometimes it has to do with a coil that is oscillating...ll037 or ll029...the fix for this is simple if it is the problem. dampen the coil with silicon.
Posted on Mar 26, 2008
High pitched ringing sound from my tv
It most likely is coming (based on model number listed here) from the high voltage transformer---ways to silence that up to and including replacing that part.
Jun 16, 2012 | RCA HD52W59 HDTV Projection Television
RCA R52WH74 HDTV Television MAKES NOISE POWERING ON
Thats the classic sign of a failed deflection board. You can get the ITC222A deflection board which comes with warranty and installation instructions from www.tvrepairworld.com its listed as the ITC222A remanufactured deflection board under the RCA CRT Projection Circuit Board catagory
Apr 01, 2012 | RCA HD52W59 HDTV Projection Television
I hane an RCA HD52W59 rear projection TV. When
The FBT,the flyback transformer is dead.Some the transitors in the deflection board is dead also.U know how to used a Ohm meter,and know soldering.Tries wesite like Tv repair World.com will help u to find the cause and replacement parts.
Apr 23, 2010 | RCA HD52W59 HDTV Projection Television
High pitched buzzing sound. This sound is real high pitched but not very loud. Some times it gets louder.
Sounds like the flyback # 270125 you can get a replacement at www.tvrepairworld.com which includes the CD with instructions and the two associated Capacitors.
Nov 07, 2009 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 power light on for 10 seconds then off
Possibly the HV splitter as that set is also famous for bad splitters.
Sep 29, 2009 | RCA HD52W59 HDTV Projection Television
Tv will not power on. Hear a high pitched sound
the horizonal output transistor is shorted-replace it also resolder coil near transistor-if output shorts again flyback transformer is bad
Sep 15, 2009 | RCA F36673ET 36" TV
Rca hd52w59 making a high pitch buzzing sound
is this just a whine since you describe no problem with the picture it dosent jump or change color or flicker. there may be an easy fix this sounds like some coils oscillating and i tell you what can be done you can take some silcon and put on these coils to dampen then vibrations. now ther may be other problems but without looking this is my first gues ...where are these coils? ll037 on the power supply deflection board
Jun 17, 2009 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 makes a high pitch internal squeal sound
coil LL0037 resolder then with a glue gun glue top of coil and down.OR replace coil.
Feb 17, 2009 | RCA HD52W59 HDTV Projection Television
High Pitch Sounds
In this model the horizontal drive coil vibrates and makes a high pitch squeal. Most times it is intermitent. Touching on the coil with something (non electrical, like wood) will make it stop or change it's pitch. The fix my shop uses: It's not to technical, but, we put fingernail polish around the coil. It's a remedy I've used for decades and has always worked. Some shops use a hot glue gun. With the back open you can hear the coil to locate it. When fixing the problem have the set unplugged. When a technician is working on a television while it's plugged in. He uses only one hand and stays away from the high voltage.
Jun 25, 2007 | RCA HD52W59 HDTV Projection Television
High pitch ringing noise and picture distortion
Sounds like the capacitor that goes bad just before the hIgh Voltage transformer goues bad. If i were you I would call an authorized RCA repair Shope and see if this is going to cause more damage to your set in the future.
Aug 25, 2006 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 HDTV Projection Television Logo
139 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
