Question about Intel D865GBF Motherboard
D865gbf intel motherboard sata hdd compatibility
I have bought a 500 gb sata HDD and my mother is intel D865gbf . I want to know whether the new HDD will be compatible with the mother board.
Thanks,
Atanu
You have to update ur bios
Posted on May 03, 2010
  • 8,404 Answers
Check with Intel ... www.intel.com/support ... look up your board, specs, and it will tell you what you can and cannot use.
Can't setup OS in SATA HDD in Intel d945gccr
Hi.
XP will not install until you go into the BIOS and find the menu page (probably by moving across the top level of tabs) where the SATA hard drives are configured. On that page you will see the ports and at least one, maybe all, will be Enabled. Close to that will be the port mode, usually setable individually for each port. Choices may include IDE (or PATA) Emulation, SATA, AHCI. Set your port to IDE emulation. Now look at the bottom for the key to Save and Exit - often the F10 key, press that key and select OK, the computer will restart and you should now be able to install Windows XP without any problems.
To get into the BIOS you have to press the Del or Esc key when you first turn the computer on.
Regards.
Feb 04, 2013 | Intel D945GCCR Motherboard
Hello I had one question in regard to 865GBF motherboard intel can 2 sata port will support 2 TB of harddisk storage please let me know the ans for this. presently I am using 1.TB stoarge of sata...
most motherboards natively (now adays) support up to 1.5 tb on a single disk. with most bio's now being upgraded to support upwards of 3tb on a single disk via a bios update you just need to update your bios from intel's website and be good to go!
Mar 22, 2011 | Intel D865GBF Motherboard
My motherboard is intel d845gvsr tell me how can i install sata hdd with this mother board and how many gb sata support
For sata HDD Your can connect your sata HDD using IDE to SATA cable. Intel 845 can support upto 320GB only.
Mar 17, 2011 | Intel D845GVSR Motherboard
500 Gb sata hdd not detected on k8mm-v motherboard
Find in your BIOS if you have an option that says configure SATA as IDE, AHCI and raid. Set it at IDE and try again to install the OS. After intaling do not switch back because it will not work.
Apr 06, 2010 | Computers & Internet
Not ditect SATA HARDISK
Hi
I know what is problem,some of mother is made only SATA HDD data transfer rate 1.5 GB per second.Now all are SATA HDD data read rate 3 up to g GB per second .Follow the instruction label on the hard drive.
If you use your Motherboard 3GB data read hard drive you can customise setting jumper source of data rate 1.5 then MSI Motherboard detect SATA hard drive.
Good Luck.
Nov 26, 2009 | Intel Motherboard
Suport hdd sata intel d865gbf?
The Intel D865GBF motherboard.
Supports 2 Serial ATA (SATA) connectors, see page 39 in your manual.
The serial ATA SATA ports will support Version 1.5GBs SATA drives not 300GBs
If you no longer have your manual, download it from Intel. Click on the link below;
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=%22d865gbf%22
Mike
Oct 15, 2009 | Intel D865GBF Motherboard
Hello
As i search about what you need to know about the 500GB SATA HDD can support in MOBO, i say YES!
865GBF Desktop Board
Two Serial ATA connectors
If there any question just add comments.
If i am helpful to you, please rate me.
Thank you.
Yboyandrei
Aug 18, 2009 | Intel D865GBF Motherboard
Finding Intel 845GVSR & 915GLVG Compatible Motherboard & Proc
you can use intel dg41 mbd , dualcore processor,1 gb ram,160 gb hdd or use intel atom for support contact 91-9645071021
Aug 11, 2009 | Intel D845GVSR Motherboard
HDD compatibility
if your m/board has sata slots then YES
Jun 14, 2008 | Intel ASUS TUEP2-M Pentium III mATX...
Intel D865GBF Motherboard Logo
302 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
