Question about Microsoft Xbox 360 Console
I'm experiencing the ol' "Open Tray" syndrome. I've tried three new disks, I've sprayed compressed air into the unit hoping to remove some errant dust, I've disconnected and re-connected the power source... no joy. Any suggestions prior to whipping out the Magnum loaded with hollow points?
  • 3 more comments
  • nomorebikes May 03, 2010
    Sorry Gbooze, but short of swapping out hard drives (no spares lying about) I tried the other suggestions long ago. I appreciate your interest in trying to assist. Have a good week!
    I'm experiencing the ol' "Open Tray" syndrome. I've tried three new disks, I've sprayed compressed air into the unit hoping to remove some errant dust, I've disconnected and re-connected all cables, I've used small tools to access the laser reader through the open tray bay and attempted to clean it. The hard drive has been removed and reinstalled. No actions as of this writing have proved fruitful.
    Hi,i think you should try this solution;
    The inner ring on the dvd contains a decoding boot record just
    below where it says xbox in hologram on the dvd. Clean this inner circle
    below the xbox hologram so it will match up with the tag calculation
    and start up the .xbe file.
    I am sure this will definitely fix the problem
    As I mentioned, I've tried three (now SIX) new disks and none of them are accepted. With all due respect, I don't think it's a dirty hologram.... six times.
    Thanks again for your input!
    This is the third time now I've been required to "Describe my Microsoft problem". It hasn't changed. I simply have not received reasonable or effective "fixes" for my problem! Here it is one more time....
    When I try to load a game, any game, into the drive, I get a response on the screen to "Open the Tray". Multiple openings and closings don't fix it. Pulling power/data cables and reattaching doesn't work. I've attempted to clean the laser reader, but this has proven unsuccessful. I've sprayed compressed air throughout the device... again without success. The first "Expert" suggested pulling all the cables and cleaning the holograms on my games - though entirely simplistic, they were some of my original attempts. The second "Expert" is suggesting I open the system up, voiding any remaining warranty. Please tell me there are actually people there who are familiar with warranty's and such AND who can offer a real, viable solution to this vexing dilemma. I would be ever so grateful!!!
  • 1,284 Answers
Hi, i have read quite a few problems floating around in the Xbox 360 section where lot of Xbox 360 users encounter Open Tray Error here are some common troubleshooting steps you can try to solve this issue:
First some basic steps to troubleshooting
1) Restart your console.
2) Check for loose cables.
3) Pull out all the cables, and get them back in.
4) Take out the hard-drive, and put it back in. Repeat this 4 times.
Try to use several similar Xbox 360-compatible discs in the console to determine whether the disc that you are using is causing the problem. To test whether the problem is caused by a specific disc, use a disc of the same type, such as a game disc, DVD movie, or music CD. If the problem does not occur when you use other discs, that specific disc might be the cause of the problem.
If you suspect that the Xbox 360 device could be causing the problem you can follow these steps
1. If you have access to another Xbox 360 console, try to play the disc on the other console. Or, if the disc is a CD or a DVD, try to play the disc on another device, such as a CD player, a DVD player, or a computer that is equipped to play CDs or DVDs.
2. If you have an Xbox 360 Hard Drive (HDD) or Memory Unit (MU) attached to the console, turn off the console, and remove the HDD and any attached MU. Then, turn on your console, and try the disc again. If this seems to resolve the problem, turn off your console, reattach the HDD and MU, and then delete any saved games for the game that is causing problems.
If this does not resolve the problem but removing the hard disk does, clear the hard disk drive cache
To clear the cache, follow these steps:
1. Move to the System Settings section of the Xbox 360 dashboard.
2. Select Memory.
Highlight a storage device.Do not press the A button, Press the Y button to view the Device Options screen, Select Clear System Cache, and then select Yes to clear the cache.
I presume you do not have a hacked version of Xbox 360 because this problem is prevalent with Xbox 360 dvd drives which are hacked.
if the above steps do not resolve your issue, please send your Xbox 360 to Repairs, call up MS support and check for the charges of Repairs in case your Xbox is not covered under warranty.
Take care
Posted on May 03, 2010
  • Shehu Pro
    Shehu Pro May 03, 2010
    Hi, this is a video clip on how to fix it..
    http://www.youtube.com/watch?v=OvLnU-pNy...
    Take care
    President:
  • 3,278 Answers
Hello.
Your responses indicate swapping the "hard drive". You may mean the CD drive, for that's where the problem lies.
If you haven't replaced the CD drive, you may need to. But, there may be a workaround, so give this a try:
Power off the system.
Disassemble the console.
Disassemble the CD drive
Take the covers off
Plug in the drive and put in a disk, so the top of CD drive is open.
Turn on console and while it's reading, spin the disk by hand until it moves on its own.
Wait several seconds to be certain it doesn't stop
Turn the console off with the controller and re-assemble.
Hope this helps.
  • NinaE May 03, 2010
    Let me try a second time ...
    Hello.
    try:
    Disassemble the CD
    drive
    Take the covers off
    Plug in
    Turn on
    Hope this helps
    Ah, well since it's under warranty, then I'd recommend that you return the system for service or replacement. Contact Microsoft support.
  • 713 Answers
Hi,please follow the solution provided below carefully to help you fix your open tray problem;
STEP 1 The first thing that you want to do is restart your console. If you can't restart, simply unplug your console, and plug it back in.
STEP 2 The next thing you want to do is check all the cables on the back of your Xbox. If you have to, pull out each one, and put them back in place.
STEP 3 The next step you'll want to try is by removing the hard drive, and putting it back in. If you have another one laying around, try placing that one instead to see if that works.
STEP 4 If you've been trying the open disk error with the same game, try putting in a newer game. It may be the game's problem.
STEP 5 The last thing that you want to try BUT keep in mind that it's going to void your warranty, so do it at your own risk! You'll want to open up your Xbox, clean out the dust on the inside, and clean the DVD lenses with a Q TIP, or a cotton bud.
Thanks and take care
  • Oyelade Gbenga May 03, 2010
    The inner ring on the dvd contains a decoding boot record just below where it says xbox in hologram on the dvd. Clean this inner circle below the xbox hologram so it will match up with the tag calculation and start up the .xbe file.
How do I fix the xbox360 open disk error I replaced the eye and I still keep getting the error Please help!!!!
I've experienced this problem too. these following steps helped me to solve it: 1: blow air in the xbox while the tray is open to remove dust. 2: put disc in tray and open and close it like 5 times. 3: You probably heard this before, clean the disc;) 4: Maybe sounds weird, knock on the xbox while its reading the disc. Hope this helps u
Sep 21, 2013 | Video Game Consoles & Games
My dvd drive is not recognizing any cd or dvd. it is since 1 and 1/2 months. even i cannot erite any dvd and cd. plz sir tell me some solution for it.
Make sure the light on the drive is coming on when you insert a disk. I am assuming that drive tray opens and closes when you press the button and that you are not opening the tray manually or forcing it open. Try to spray some compressed air into the drive with the tray open incase anything is interferring with the laser. Has anyone been inside the computer lately that may have disconnected a cable from the back of the drive? Not to be funny, but make sure you are inserting the disk right side up. You may just have to buy a new drive.
Mar 08, 2011 | HP Computers & Internet
Our xbox 360 elite keeps telling us to open tray drawer after inserting a disk. We tried 3 diff disks get same thing. Worked fine last pm
This is one of two problems, both involving your laser.
1: the laser is dirty, get a laser lens cleaner and run it through your xbox a few times and see if that helps. You can also get a can of compressed air and carefully spray it into the open tray slot.
2: Your laser has died, at which point your only option is to call Microsoft and ask them for a repair order. Sorry :(
Aug 13, 2010 | Microsoft Xbox 360 Elite Console
Sprayed xbox with cleaner now only says open tray
It sounds like you have blown air into your disk drive, doing this spreads the dust which can end up over the lens, try a cd cleaning disk, this should remove any dust that has settled on the lens.
Jun 27, 2010 | Microsoft Xbox 360 Console
When i put a game in my xbox 360 it says reading then open tray
I found a solution that works for me after a long period of time with this problem.
Get an air spray canister (just compressed air), open your Xbox's game tray, take the disc out, then spray the air along the tray, moving side to side inside the Xbox. You may want to spray into the vents, too, just to be sure.
This worked for me, and it was the only thing that worked for me. I had already tried hitting the console with the controller (gently), and doing the stuff Microsoft recommends etc.
If that doesn't work, you could try gently knocking the top of the Xbox with your conroller, when you put the disc in, as I've heard that works for some people.
Another thing that works for some people is taking the disc out, closing the tray, then when it goes to Open Tray, open the tray, put the disc back in and then closing the tray again.
Jun 19, 2010 | Microsoft Xbox 360 Console
My xbox will not read discs it just says open tray
Jun 17, 2010 | Microsoft Xbox 360 Console
My USB Sony- dvd writer (enclosed in casing) has stopped reading
Try using a can of compressed air with the tube on the end. Open the disk tray and spray the compressed air liberally inside the drive area, sweeping the tube from side to side. If this does not fix the problem and you feel comfortable with removing the drive and removing the top cover, you can try cleaning the optic lense inside (very gently) with a cotton swab and some rubbing alcohol.
Jan 26, 2010 | Sony DWU18A DVD RW Write DVDRW 8X...
The disk tray won't open. this is brand
Just got mine out this morning. Googled this for two days with no success! Finally, out of despiration I took the screwdriver to the top cover. (four screws in the back, and two screws on each side) Lifted up the rear section of the cover which the released the front for removal. The input pc board is right on top of the dvd tray so little could be seen, so I removed the screws and clips holding the pc board. Make sure that you you disconnect the power before doing this however. Once you have removed the three screws, (two of which have attached grounding clips) you will need to disconnect the HDMI cable which plugs into the back of the board if you had not already done so. Now carefully plug the unit back into ac power, and while holding the board in your hand careful not to allow it to touch anything,press the open button on the front of the unit, and as you move the board slightly while pressing the button, the tray mechanism will start to try to release. Press the button several times till the tray opens completely and stops. Now comes the tricky part: Unplug the AC power plug while the tray remains open. (Otherwise the tray may close again and you'll have to go through the wiggle routine again to get it to open) Once it is open, remove the DVD Disk if there is one in there. OK, so now if you have followed these instructions so far the tray is open and empty, and there is no power to the unit, you can begin reassembly. Put the three screws and two clips back into the PC board loosely at first till you have all three started, then proceed to tighten each one. Replug the cable into the back of the PC board and then replace the top cover and the screws following the same procedure. Plug the unit back into the AC receptacle, and turn the unit on, then press the open/close button, and the tray should open and close as normal. I think what caused the problem to begin with is that I had left a DVD disc in the player for an extended period of time in the start play mode, and it either jumbled the programming or damaged the disc. I have not tried to put the original disk back in the unit to find out! I want to use it for awhile first! PS I would also suggest that onec you have it working, you might want to blow out the tray mechanism with an air cleaner spray.
Oct 24, 2009 | Toshiba DVR620 DVD Recorder/VCR
My ps2 game disc says disc read error, but there is nothing wrong with the disc
Most disk read errors that are not caused by the disk itself are caused by having a dirty lens in the drive you put that disk into.
Two easy ways to clean that lens are either buying a cd lens cleaner (cd with brushes on the underside of it) or by using a can of compressed air to blow the debris off the lens.
If you go the route of compressed air in a can, there is an extension that comes with the can...it usually looks like a mini red sipping straw. You can reach the lens by open up the drive tray and pulling the power to the console when it is open. The reason to pull the power is that you can now move the tray halfway closed without it auto closing on you. When you have access to the lens from positioning the tray, stick the extension into your console and place it right at the lens and press the nozzle to spray the air. Do this a couple times and try reading your disk again.
Hope this helped.
Sep 14, 2009 | Sony God of War for PlayStation 2
Xbox 360 unplayable disks
What you have to do, is clean the "eye" the thing under the disk tray that reads the game, you probabley got that dirty or damaged somehow. Try spraying compressed air into the open disk tray to get any quick dust off. if that does not work then try finding other ways to clean it or call 1-800-4my-xbox and have microsoft check out the system to see whats wrong with it
Jan 15, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
