Question about Panasonic TOUGHBOOK CF-18 Tablet PC
My Panasonic Toughbook T2 was shut down properly and kept for about a month. now it does not boot. Even inital BIOS check function is not performed. Though HDD movement can be heard. Checked RAM by replacing with other.Scree remains blank/dark. HELP
    Novelist:
    Scholar:
  • Panasonic Expert
  • 105 Answers
It sounds too simple but try to remove the battery pack
from your Toughbook, and make sure the TB is unplugged.
Leave the battery pack out, and plug back in.
Try to start the unit. ALL Toughbooks have the problem
that is the battery goes too low then the unit will not boot.
If it works, then you have solved a complicated problem
with a very SIMPLE solution.
Good Luck!
Regards,
Richard - Montreal Based
Panasonic Canada Authorized Dealer since 1989
Posted on Feb 15, 2016
    Novelist:
  • 113 Answers
Is there any chance the video output is switched to feed the rear VGA connector? ie the screen is black due the video being routed away from the screen. Try hitting F5 key.
Can you hit the Delete key to try and enter the bIOS screen? (it may be another key such as F1 or F2. See your Toughbook manual)
Can you have someone make you a bootable USB thumb drive and try booting up with that?
Its also possible that the hard drive has failed, but usually the BIOS POST check will initiate and indicate a failed hard drive or bad RAM etc
Can you remove the 2.5 inch hard drive? Usually its accessible under a removable panel under the laptop.
Feel free to ask more questions.
Cheers,
Steve
PS have you tried the discussion forums on the Panasonic website?
Posted on May 03, 2010
Panasonic toughbook cf-74 blue error screen loop
Which OS do you have? Have you tried booting to safe mode?. Restart the computer. Immediately after the BIOS post ends, start tapping the F8 key repeatedly. when Windows Advanced Options menu appears, select safe mode and see whether it boots completely without blue screen(BSOD)
Apr 22, 2014 | Tablets & eReaders
My company uses Panasonic Toughbook CF-18. We have ones that are over a year old, over 6 month old, and even just a few months old. In the past few weeks we started experiencing a problem where the units...
The battery interface has broken away from main board at the limit stop. Requires trained tech to repair. You mentioned these are new.. Cf 18 have been discontinued for years. Are these cf19's
Sep 08, 2011 | Panasonic Toughbook 18 CF-18NDHZX-VM...
Bought used toughbook on ebay, no hard drive or OS. using my old hard drive from broken one. get to bios screen, but will not boot up into windows. I'm guessing some drivers may be jacking me up, how do I...
reformat the had drive and install a fresh copy of OS from the compact disc.... once the installation is complete, boot up the computer again... if it works, then every thing is perfect....you can go ahead and install the drivers for your devices in the compter...
please clarify if you have any further troubles in installing the OS in your computer...
May 07, 2010 | Panasonic TOUGHBOOK CF-18 Tablet PC
Toughbook cf-18 cannot boot thru window. it come out with a start using safemode, then go into window , then blue screen with "a problem has been detected and windows has been shut down to prevent damage...
Yu possibly have a virus
You will need to format the hard drive and reload Windows if this doesn't work you will need a new hard drive.
Try to "defragment the hard drive 1st. check the disk for errors.
Apr 27, 2010 | Panasonic TOUGHBOOK CF-18 Tablet PC
I bought a used toughbook cf-t2 and it does not have hdd or operating system. What do I do now ?
If you want to keep it, you will have to buy the hard drive and op system, unless you go Linux. You can purchase them at Best Buy. The problem I see is that you really don't know if the computer works, and is worth the investment of getting it up and running. You can take a chance that it will function with the hdd and windows, or you can opt to sell it on ebay to try to recoup some of your money. You might try to get your money back, don't know if you can. That's about all I can think of. Good luck.
Apr 13, 2010 | Panasonic TOUGHBOOK CF-18 Tablet PC
Trouble booting!
You could attempt to boot to safe mode, and run the Start> System Recovery > PC Recovery Application.
Otherwise, I'd boot to safe mode, select start, run, type: msconfig, select the startup tab, remove any unwanted startup items that may be causing the system crash.
Hope this helps.
Jan 08, 2009 | Panasonic TOUGHBOOK CF-18 Tablet PC
Cf-18 toughbook
The BIOS may not support the larger drive at all; I suggest you look for a Toughbook forum and repost there and check Panasonic's site for a manual download and possibly a BIOS upgrade if the unit is equipped with a flash BIOS.
Aug 27, 2008 | Panasonic TOUGHBOOK CF-18 Tablet PC
NUM Lock
I solved this on a toughbook. The numlock was activating while windows started even with the regkey set to have it off.
(http://support.microsoft.com/kb/154529/en-us)
All I had to do was restarting the PC waiting for windows to activate the numlock again during the shutdown process and then hitting the numlock once before windows was done.
Next time the Toughbook started the Numlock kept off!
Aug 12, 2008 | Panasonic TOUGHBOOK CF-18 Tablet PC
Setup password
i think the computer is asking for bios pc if it is bios then you have to open the case and remove the bios battery for five sec.before this you have to remove the power plug.after five sec. just resit the battery and put the power plug back and switch it on.
plz post your findings
Apr 23, 2008 | Panasonic TOUGHBOOK CF-18 Tablet PC
Panasonic TOUGHBOOK CF-18 Tablet PC Logo
489 people viewed this question
Top Panasonic Tablets & eReaders Experts
Paul Wang
Mike
Are you a Panasonic Tablet and eReader Expert? Answer questions, earn points and help others
