Question about Cobra 200 GTL DX 4-Channels Base CB Radio
Cobra 200 Hello, could you tell me the wire Diagram on a cobra 200. I need to wire a 2018 on my radio. Thanks, Jim
Hello Jim. These radios do not work well with any power mic including the power echo mics because they have good modulation boards in them. But if you still want to try then check http://www.cbtricks.com/radios/cobra/200gtl_dx/index.htm
Posted on Apr 06, 2008
6ya staff
SOURCE:
No problem just need wire diagram for 4 pron mike on cobra 29 night watch sound tracker
go to cobra web site click on contact us tell them what you need and thay mite be able to send it to you
Jan 03, 2011 | Cobra 18 WX ST 40-Channels Base CB Radio
Can recieve but not transmit
The mic wires are soldered incorrectly. Get another cobra mic for that radio or have a qualified radio tech correct the wiring.
Apr 15, 2009 | Cobra 29 LTD CB Radio
Wiring diagram
Hello birdhunter, no the cobra 200 has the same pinout as the 29's and such, but the color code might be different.
Daiwa EM-500
Cobra CA Series
1- Shield & Black
2- Red
3- White
4- Blue
STOCK Pinout Let me know how you get along with it,,,, Mechanic
1- Shield
2- Audio
3- Transmit
4- Receive
Sep 14, 2008 | Magnum DeltaForce CB Radio
Cobra set up
Hello John;
You can ground both the antenna mast and the antenna. your best bet is to place an 8ft grounding rod in the ground from radio shack or local two-way radio shop. Then connect the grounding rod to your mast. You can get a polyphaser from your local two-way radio shop this will connect between your antenna and the radio. it will also be grounded to the grounding rod. This should leave you in pretty good shape.
Happy DXing
Pat N5SLI
Apr 03, 2008 | Radio Communications
Cobra 200 GTL DX 3rd edition Installation
Hello John. A good earth ground for your antenna is more important than for the radio. Using the closest possible point to the antenna pole, preferably within a couple of feet, you need to ground the antenna pole to the earth. Go to a hardware store and buy a copper grounding rod which will be eight foot long and buy, as little as you can possibly get away with, some of 10 gauge wire and some kind of clamps that will attach the wire to the antenna pole and to the grounding rod. Google "antenna earth grounding" may help also.
Apr 03, 2008 | Cobra 200 GTL DX 4-Channels Base CB Radio
Talkback on a cobra 200 gtl dx
This procedure is not as simple as just cutting a wire. Note that you can possibly mess your radio up if any maintenace is not done properly. I do suggest taking your radio to a proffesional to have the talkback removed, but, if you really want to do it yourself, go to ghe following link and basically reverse what has been done.
http://www.cbtricks.com/radios/cobra/150gtl_dx/tsb/cobra_200gtl_dx_tsb_10041.pdf
This is the service bulletin for the addition of talkback to the Cobra 150GTL DX and the Cobra 200GTL DX.
As long as the talkback was added correctly, this can be put back origional.
If this does or does not help, please reply on here or email me at [email protected]. I look forward to hearing from you.
Dean
Rollin CBs
Mt. Vernon, TX
Feb 13, 2008 | Cobra 200 GTL DX 4-Channels Base CB Radio
Cobra 200 gtl dx
Could the battery be dead? Other than that, it may be a bad solder joint inside the mic.
Geno
Jan 24, 2008 | Cobra 200 GTL DX 4-Channels Base CB Radio
Mic wiring diagram
Want to wire cobra mic to a uniden washington radio
Nov 20, 2007 | Radio Shack TRC-447 CB Radio
Cobra 200 GTL DX 4-Channels Base CB Radio Logo
160 people viewed this question
Top Cobra Radio Communications Experts
Chris
Ernest Taylor
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
