Question about Teledyne Laars Laars Lite 2 Pool Heater 125,000 Btu / Propane Gas
I have a teledyne laars lite 2, it fires up fine but the flames are excessive and go outwards towards the wires, any ideas
  • 33 Answers
It would seem that this unit has had a conversion done from Nat to LPG or visa versa..the main gas valve and burners need to be adjusted
http://www.laarsman.co.uk
Miles
Posted on Jun 05, 2010
Teledyne laars leaks excessive water. is it dangerous?
if not leaking over flame ok to use but you need new heat exchange
Aug 03, 2013 | Teledyne Laars Laars Lite 2 Pool Heater...
Teledyne laars dr-400 cycles on and off
if only runs 7 seconds then turns off need new flame sensor or clean it up
May 26, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
My pilot turns on but the burners never start up after I turn on the switch on my Teledyne 2 Pool Heater. Any suggestions on whether the burners may be clogged or defective or if it is the switcÉ
You have a bad flame sensor or a bad burner graound... the gas valve porves the flame by passing a very small current through the pilot flame... yes flame does conduct electric...if the sensor is dirty or bad or the ground wire to the burner is corroded the gas valve does not sense the current and "see" the flame.
heatman101
Aug 13, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
I replaced the ignition transformer in my Teledyne Laars epc325 pool heater and cleaned everything. When I switch the heater on the burners all work fine but they only cycle on for about 10 seconds then...
This is probally your ignition wire is bad and not reading flame at the pilot or your pilot is bent or something so that when the pilot lights the flame isn't hitting the sensor probe at the pilot. When looking under the heater use a mirror so if you get roll out of the flame you don't get burned. Good luck and be careful.
Feb 26, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Burner cycles on and off within 2-5 seconds. What could the problem be? Model Teledyne Laars LLD250N
Sounds like the flame sensor. If the sensor doesn't see a flame, it shuts off. Good luck...Lee
Oct 31, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Laars 400k won't stay lit
sounds like dirty flame sensor,clean with fine emory cloth
Jun 17, 2009 | Teledyne Laars Laars Lx Pool Heater /...
Laars Teledyne Pool heater flames on for 2 seconds, shuts off
You have no flame rectification.....LLD series heaters check for a signal through the flame to ground; if the module does not detect this signal, it go through two more trials for ignition and then lock out the module. There should be a flame rod and it may need cleaning. I use steel wool.
May 30, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
pull out flame sensor and clean with sand paper or emmoring cloth then try again should work (small black wire with sensor sitting above burners)
May 05, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
MY Teledyne Laars is 20 year old +
check pressure switch (looks like space shuttle copper wire one side 2 wires other side) need 24 volts ac both sides if not need new
Dec 18, 2008 | Teledyne Laars Laars Lite 2 Pool Heater...
Teledyne Laars Laars Lite 2 Pool Heater 125,000 Btu / Propane Gas  Logo
172 people viewed this question
Top Teledyne Laars Pool & Spa Experts
paulcarew
Jay Finke
Jay Finke
Bill Jordan
Are you a Teledyne Laars Pool and Spa Expert? Answer questions, earn points and help others
