Question about Zanussi ZWF1440 Front Load Washer
Hi, no display on any led. 240v to machine sounds
Hi, no display on any led. 240v to macchine sounds like the door latch is chattering then goes quite.this is a zannussi zwf 1440w, prod no, 91451751601. type p6858448
  • 269 Answers
It does sound as if the door latch may be at fault but it also seems as if it has caused the main control P.C.B. and control Interface to fail.This machine was manufactured in April 2005 from the Prod. no.This is covered under the major parts warranty (not the door latch).Also make sure if the power to the controls is off check for any loose connectors on the main p.c.b and interface.Also have a look at the body of the door latch and if there is a brown discolouration that is a good sign that is the culprit.
Posted on May 03, 2010
Testimonial: "brilliant, really quick response, and a great pointer to my problem once again thank you very much, i really am suprised at the swift response brill. eddie."
Lg front loader wd-8050fh door wont lock
Hi just read your posting.Sounds like the door lock switch is faulty.Do you get any error codes on the display?Check the door latch that is attached to the door.It is the little hook that latches into the door lock switch.The tension on the hook should be quite firm.Please reply with answers to the question and the condition of the door latch.Looking forward to your reply.
Jul 14, 2012 | LG Washing Machines
WIL103 WAHING MACHINE
Try to power off you unit for about 5-10 minutes then plug it back in. Did the technician touch the control board?
Oct 22, 2008 | Indesit W 123 Front Load Washer
Hi my door on the Miele W487 is not closing, the latch wont hold. Any suggestions?
Hi there - mmm the door locking mechanism may be crook - the only other possbity is the mechanical latch could be faulty - give this a quick try close & hold the door in and initiate a cyle to see if it locks - if it locks then the latching device is busted which may or not be field serviceable.
Miele item #4747471 is the latch unit & #4842085 is a 220/240V door lock not sure about a 110/120V part number.
Cheers
Jul 16, 2011 | Miele W487 Front Load Washer
F22 code ?? duet locks but will not run
"F22" is a door latch failure error code. At the beginning of the wash cycle the door will attempt to lock several times. If the latch fails to lock, the washer shuts down and the error code is displayed.
In some cases, the error code can also be displayed if the CCU goes bad. There is a door latch relay on the board that controls the door locking mechanism. The CCU is not serviceable and must be replaced if defective. In addition, make sure all the connector plugs between the CCU and door latch are connected and snug.
Thank you !!
Jul 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What is code F22 on sport duet washer? The locking mechanizm buzzes a little, and when you push start it's locked and stays locked, and you have to stick your hand up in it to unlock it.Thanks.
Thank you !!
Jun 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Door will not open has a code 22
Apr 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Won't spin
I replaced the door switch/latch assembly. It works!
Sep 03, 2009 | Kenmore 43142 Front Load Washer
We cant get the door opened kenmore he2 plus we got it for free and for some reason the door wontt open
Unplug the the machine for a couple of minutes. This should unlock the door. If not, you should remove the lower panel under the door. Simply unsrews 3 hex nuts. Pull the door tab (latch) from underneath. Is there any code error displaying on your LED?
Apr 22, 2009 | Kenmore HE2 Plus Front Load Washer
Indesit wie157 washing machine. led displays error code "door", ive bought a new interlock and replaced it but it still wont work, what is wrong? thanks paula
Make sure the door is positively latched in.,some times a weak or broken door spring or striker is the cause of the problem, if you are satisfied these are o/k, then it is probably a control board problem, and you will probably have to call an engineer.
Plz rate my solution.
Thanks.
Jan 09, 2009 | Indesit W 123 Front Load Washer
Zanussi ZWF1440 Front Load Washer Logo
223 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
