Washing machine stops working halfway through a cycle. The drum rotates a little bit,but not at a high rate. The pump works. But it just stops. It never finishes a cycle.
  • 2 more comments
  • nick_wolfe May 04, 2010
    Hi,thanks for responding.
    My washing machine is a front loading servis 1100rpm,model m6115s, 4.5 kg.
    Thanks again.
  • nick_wolfe May 05, 2010
    yes u can manually select the spin cycle,but it only turns a couple of times and stops.The pumps works for a while until all the water is drained and then the cycle stops.The out of balance fault!whats that,because the drum has a lot of movement, and when the machine used to work it used to really bang about.
    Cheers nick.
  • luisa_sgro May 11, 2010
    does it drain the water completely? can u manually select the spin cycle and it goes thru? could b drain or out of balance fault. please reply 4 more help
    what is the make of the unit? is it a top or front loader? please reply 4 more help
  • Washing Mach... Master
  • 713 Answers
Hi nick, 1st open door of unit and see if u can move the steel drum where the clothes go gently up and down. these drums should have no movement because they r fixed at the back with bearings. when most front loaders have bearing faults the machine makes a banging noise on the spin cycle. please reply and i can help u more.
Posted on May 06, 2010
Indesit WDG1295W. Why doesn't it drain?
The pump and connecting lines could be choked with debris the filter didn't catch.
Dec 26, 2015 | Washing Machines
Code c9
Reset using Off-2-Off.
Tested with Gentle rinse: water OK, but no drum rotation. Tested Short Spin: Pump OK but no rotation.
Opened door (first time) and rotated drum by hand - smooth.
Shut door carefully and tested short spin: OK.
Suspect: door safety switch.
or I suggest you look at your instruction manual (or take the link below) and look at the fault bit of the book.
You could perhaps try to follow instructions for the "The washing machine doesn't work" .
Are you able to actually programme the machine? i.e. The display will still show you the programme length etc
It may sound silly, but is the door closed properly etc
Is there a way of resetting the machine, or maybe turn it completely off for a little while, and turn it back on?
If all this doesn't work, i suggest you phone either AEG, or the person/company you got the machine from, and get them to have a look at it.
Also, was it working properly, before it stopped working - i.e. Would it drain properly ?
I hope all this helps you. Source(s): http://www.serviceforce.co.uk/pdfs/U0346...
May 17, 2011 | AEG Lavamat 74640 Front Load Washer
Half way through the cycle we get the E20 message. We drain the machine and check the filter. The rotating bit at the back of the filter keeps coming off. We put it back and then the machine works for one...
The rotating bit at the back of the filter is the drain pump/motor ;-0)
Don't try to glue the impeller blades back on, believe me it won't work. There is only one cure- have the pump replaced!
Cheers,
John C
Mar 05, 2011 | AEG Lavamat 16810 Front Load Washer/Dryer
Maytag Neptune. 10 years old.Slow drum rotation
The problem may be with the bearing of the washing machine is spoiled due to leak please try to change two inner bearing along with the washer it will work for another ten years
Dec 24, 2009 | Washing Machines
Hello i have a hotpoint wma40 the machine will go
Hi, i have a wma40s had it for 7 ears now same thing happended would start a cycle but then stop halfway through make the noise but the drum would not spin etc. i bought some carbon brushes of ebay for 7 quid and it works better than its worked in years bit nosiey for first few washes but after it settles it is as good as new.
Jul 06, 2009 | Hotpoint WMA40 Front Load Washer
Started having a noisy rinse & spin cycle, then stopped.
Open the washer door and spin the drum by hand, if it feels rough or noisy and rumbling, then the main drum bearings have failed. There should be little or no noise when you spin drum
This is a major repair, and I would not recommend a D.I.Y solution.
Other possibility is there is something in the pump, but you would only hear this when the pump is working.
Plz rate my comments.
Thanks.
Jan 07, 2009 | Hotpoint Aquarius WF210 Front Load Washer
Machine dosent seem to drain model #lat8840b maytag
my machine had a pair of kids underware stopping the water from entering the draij pump,you may have clothes inbetween the drum and outer wall stopping the normal rotation
Aug 25, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Zanussi fj1254w washing machine
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Jan 04, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
PE235 gets stuck on draining and won't go to spin
what you have is whats called a magnetic pump it should feel jerky to rotate but should be free without locking up, this pump is designed this way to avoid little things getting blocked in it. if the pump is free from blockages and works electrically, then the pump is not a problem, the problem sounds like the motor or the motor control board pcb which is located at the side of the timer (i think on that model) first check the motor carbons for wear, the armature for signs of burning or sparking, then the module for any signs of scorching etc, difficult thing to diagnose without test equipment but you now have somewhere to start from when looking hope i have helped a little
Sep 28, 2007 | Hoover PE235 Front Load Washer
Washing Machines Logo
125 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
