Samsung LS19CFEKF-933HD tv. Will not turn on
I have a Samsung LS19CFEKF-933HD tv. The power light on the tv is red, but will not switch on from either the remote or direct on the tv. As the power light is on I guess that the power cable is ok. Any suggestions please?
  • 5 Answers
SOURCE: Power to TV, cant power on, red light flashing
The repetitive blinking light is a trouble code which is used to determine which series of boards may need to be replaced. How many times does the red light blink?
Posted on Aug 30, 2009
roety
  • 585 Answers
SOURCE: my samsung 330 lcd-tv wont turn on. the red power
Hi my name is Roety,
I can help you with your issue ,
Most common issue is the power supply capacitors, check and replace any that look swollen like this
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Posted on Oct 28, 2009
  • 610 Answers
SOURCE: my samsung tv LE32S73BDX/XEU will not turn on red
sounds like the power supply board has failed and should be replaced. most common problem for all samsungs.
  • 55 Answers
SOURCE: how to do a manual channel tune on a Samsung 933HD TV
in every remote there is a button that leads u to the digital setup. you have 2 options in it. manual or automatic. go for automatic. rest is done automatically. good luck!
Posted on Nov 01, 2009
lightnbaby
  • 36 Answers
SOURCE: hi my samsung lcd tv model le40s8, it won't switch on
if you can do soldering work, replace two 1000uF10v bulging capacitor with 1000uF 16v or 25v in powersupply board. you will save $200.
Posted on Nov 12, 2009
My TV randomly switches itself off and the red light flashes continously and i have to pull out the plug. its getting more frequent
Samsung TV Keeps Shutting Down - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - When I turn the TV on for the first time each day it shuts itself off within 30 seconds. ... green light flashing red light is [standby term] green light is [lamp]flashing. samsung plasma 850 picks up other remote signals?
Jun 12, 2015
Samsung LED UN55B7100 turns off on its own.
Jun 11, 2015
Volume goes automatically to 0 on my Samsung LCD TV
Jun 10, 2015
Why TV turns off by itself?
Jul 12, 2012
More results from www.cnet.com
Easy fix for new Samsung TV switching on and off power ...
? 4:41
https://www.youtube.com/watch?v=H0cG3lzjuw8
Sep 15, 2012 - Uploaded by alwaysafix
My tv turns on and off by itself the minute I plug in the cable. .... Samsung E6030 led tv hv blinkin red light ...
Dec 25, 2015 | Televison & Video
Where can i get the living solutions jumbo universal remote code for the samsung syncmaster 1701 mp tv
You should use the search remote code feature:
  1. Hold the device button you want to program for 3 seconds & release.
  2. Push & release the power button & the red light will remain lit.
  3. Push the CHANNEL UP button over & over slowly until the device turns off.
  4. When device turns off press OK button.
Hopefully that works for you.
Jan 07, 2015 | Samsung Televison & Video
I am trying to retune my mother-in-law's tv, and don't have a manual. If I go into the menu, and try and open the "Satellite dish" icon - it won't let me. The curser just goes past it.
Sometimes, the manufacturer removes the user manual from their website in the case of older device models. If this is the case with the Samsung 933HD, you can find a backup here:
Samsung Syncmaster 933HD manual
Jan 28, 2014 | Samsung 933HD 19 in. LCD TV
Samsung 933hd tv. . .once i plugged it it turns on and it gives the sound but the whole screen turns white. . .any suggestions?
The screen turns white because defective T-Con. Mostly 19 inch model doesn't have PCB T-Con. My suggestions is , call samsung cervice center.
Mar 14, 2011 | Samsung 933HD 19 in. LCD TV
We have a samsung 933hd. when we switch on, we get a picture and sound but lose picture after 1 second. Can't get anything on screen even using remote. Switch off then back on and same again , sound ok but...
This is a power supply problem. If the set is under warranty, exchange it.
If you warranty is expired, you can take it to a repair shop and get an estimate to see if it is worth fixing.
Feb 10, 2011 | Samsung 933HD+1 19 in. TV
NEED A OWNERS MANUAL
http://www.nodevice.com/user_manual/samsung/monitors1/933hd.html
Jan 28, 2011 | Samsung 933HD 19 in. LCD TV
What is the sky remote control for Samsung
Hi
Samsung
4 digits: 0060
3 digits: 065, 584, 037, 245, 476, 398, 516, 292, 318,037
Samsung (6000 series)
4 digits: 1340
As you used 0060 and it didnt respond please try to programma with the other 3 didgit codes.
If still you cannot programme it follow the below instruction:
1. To control your TV firstly switch on the TV set, point the Sky remote at the TV,
2. Press the "TV" button on the Sky remote, then press and hold the "Select" and "Red" buttons together until the red light at the top of the Sky remote control flashes twice.
3. Continue with this process by continuously pressing "TV" then "Standby" then "TV" then "Standby" etc until the TV set switches off. This will start using the inbuilt codes to programme the remote.
Thanx
Jul 27, 2010 | Samsung Televison & Video
Samsung 933HD TV and the blue light comes on when the TV is off
Look at the power supply first; look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find
Dec 15, 2009 | Westinghouse LTV-27w6 27 in. LCD HDTV
How to do a manual channel tune on a Samsung 933HD TV
Nov 01, 2009 | Televison & Video
TV not switching on
Can you hear the sound of turning on?
I think that you need to replace the main board.
Oct 18, 2008 | Samsung LNT3242H Television
Televison & Video Logo
244 people viewed this question
Top Televison & Video Experts
Electro Med Services...
