Sounds like you have may have it run on startup. Just to see you can use msconfig to temporarily disable it by following these steps:
That usually means that a program that starts when Windows starts
isnt functioning correctly, You can test it by
clixking Start > Run > type
Msconfig and press enter. After that click the
startup tab. Here you will see programs that load when Windows starts.
If you recognize the program
thats causing the issue, simply click the box to the left of the item to
uncheck it and click OK. You will then be prompted to restart.
As the machine restarts, check to see if the issue has disappeared.
If so, great. Be aware that you that you will be prompted with a "System Configuration Utility"
dialog that lets you know you are using
Msconfig. If you d
on't want to be warned of this, click the box that says "Dont show this message..." and click OK.
If not, run
Msconfig again, and
uncheck the next suspicious program and repeat the process until the problem disappears.
Below is a link with information on using
Msconfig. It also has other links that include information of some of the programs that you might see in the
startup window of
Msconfig.
http://www.netsquirrel.com/msconfig/msconfig_xp.htmlNOTE:
There's is a "Disable all" button under the
startup tab. But I
wouldn't suggest using that initially. It is better to
uncheck them one at a time so you can see what is causing the issue.
Hope this helps. Please remember to rate this information.
Thanks
