Question about Crate FlexWave FW15 Guitar Amp Combo, 15 Watt Single 8 Speaker
Crate TX50 DB has noisy DSP circuit when rotating the DSP pot!
This is the battery operated Limo. I get a high frequency continuous tone when the rotary dsp pot is turned to by-pass. Get static when rotating thru the effects. Can someone point me to a suspect part? I have reflowed the majority of large solder joints on the pcb's. Any suggestions?
  • Crate Master
  • 5,603 Answers
When you are changing the DSP effect on the fly, static or noise is NORMAL !!! The DSP is changing the data and having to recalculate on the fly and doesn't mute itself while doing so which results in "garbage sounds out".
The bypass setting should NOT get any tone UNLESS you have feedback going on. If your guitar can "hear" the speakers in the amp, the strings can vibrate and get feedback going.
Unplug the guitar and see if high freq tone is still there on bypass. If the tone is in the musical range, then there is a problem if nothing is plugged in. If it is a VERY weak, very high frequency tone, this may be the digitizing noise from the DSP. On bypass, the audio is likely to still go through the DSP, just not be modified by it.
Posted on May 03, 2010
Testimonial: "Concise and timely response to my question...Thanks!"
I have a crate 16 channel mixer and when i power it on i cant usually get sound through the channels when i hook up a mike sometimes the low z input works and sometimes not. the regular line in for the mic...
If you have already spray cleaned the pots and switches then the problem is almost surely bad solder connections on the board. This happens often if unit travels a lot with no case. Resolder all pots, switches and jacks and check copper trace for breakage at these places. In case of broken trace hard wire across breakage.
May 11, 2017 | Kustom Deep End 200HD 200 Watt Bass Amp...
Loud crackling on several pots
Sounds like your pots are dirty. You need to spray a cleaner such as Deoxit in the pots then rotate them a few times..This has to be done with the power off and the amp unplugged from the wall...Remove the knobs, get some food grade plastic hose which will be a snug fit when shoved on over the shafts of the pots...make sure to cut a piece off the hose about one inch in length...spray the cleaner into the hose and then with the hose still shoved down over the shafts rotate the shafts back and forth a few times...Then power up the amp and recheck...This will only work if the pots are not gone beyond the point of no return..Outside of that, they will need to be replaced which means you will have to disassemble the unit...
Jan 12, 2014 | Crate CA125DG Telluride Acoustic Guitar...
Crate flexwave 120 tuner and all effects stoped working
Hi there,I have the same problem with my flexwave 120. I opened the amp to measure several capacitors on the small effect circuit board. If one of this capaciters have internal short circuit, wich will effect the others causing effects to fail. I removed them one by one to find possible short circuit. All capacitors were ok. I think the problem is in the processor wich is to diffucult to replace. I think it's easier to replace the effects circuit board. But where do we find this board??10_29_2011_6_25_35_am.jpg
Aug 07, 2011 | Crate Flexwave Fw120h 120 Watt Head Dsp...
While moving, the equalizer slides / controls broke off . Where can you find them and are they replaceable? Crate Telluride Accoustic amp.
Yes, the pots are replaceable. Removing them from the circuit board requires solder removal tools. DO NOT atttempt to remove these with solder wick. The new high temp solder (ROHS) will surely cause the board to be damaged. I use an Ungar powered solder removal system. The parts can be found at DigiKey.com or Mouser.com. The part value is marked as is the taper which will likely be an "A" or "B" suffix. Search for potentiometer, slide. You have to exactly match the circuit board pin layout. The distributors have links to the manufacturer's spec sheets to compare. First thing is to measure the travel, then find ones with the right mounting, then the resistance and finally the taper suffix. The parts are typically between $1.50 and $3 each.
Jun 08, 2011 | Crate CA125DG Telluride Acoustic Guitar...
My crate FW120HS has suddenly started giving me loads of reverb, and i have no idea why. Iv not changed any effects or my set up. Its just suddenly happened. Any Ideas?
This has a digital reverb unit. The settings are subject to get clobbered I suspect. I don't know if you are using foot switch for the reveb control... You may also have a cable that has come loose...
Here is a link to schematic for your unit:
http://elektrotanya.com/crate_flexwave_guitar_amp.pdf.pdf/download.html
Notice that the reverb is set by DC voltages from teh setting pots that go to the DSP chip. These setting pots receive voltage from a 16 volt ZENER regulated source. First thing is to CHECK that voltage. If the Zener has opened and you find much over that 16 volts, that is your cause of the problem.
The circuitry is on page 1 in the 3B to 3D lower left of the page.
Feb 14, 2011 | Crate FlexWave FW120HS and FW412 Half...
CRATE GX- 212 HUMS WHEN TURNED ON AND CHIRPS WHEN SHUT OFF. NEED SCHEMATIC AND ADVICE TO ISOLATE THE BAD CAP IN WHICH CIRCUIT THAT IT IS OSCILLATING.
Witth an oscilloscope analyze the ripple voltage across C67, C70, C14, and C12. Pay close attention to the last two of these which are on +/- 15 volt lines.
The "chirp" when shutting down is LIKELY normal and would probably be from teh DSP effects unit as it goes down. The voltages go out of the operating range and the device essentially goes nuts for a second or so.
Sep 16, 2010 | Crate FlexWave FW15 Guitar Amp Combo, 15...
Dirty high switch on a Crate practice amp
NEVER use switch cleaner such as DeOxit on pots !!!!!
I have used CRC226 available at Home Depot electrical dept.
I SUSPECT that the resistance element in that pot is cracked. This is common if the knob sustained a hit. Replacing the pot is the only cure if the element is cracked.
Reviewing the schematic, ALL audio passes through the wiper on the HIGH tone pots. If the wiper is intermittent, so will be the sound.
If your unit is solid state amp, the pot looks like a 10K ohm LINEAR taper.
If you have a tube type, then the pot is a 250K ohm LINEAR.
Note that the other tone pots in the units are AUDIO tapers, but the high is a linear taper.
Get repair parts from either DigiKey.com or Mouser.com
Mar 23, 2010 | Crate Music
Have a crate limo tx50 d some times the effects stop working and or get a buzz from the unit
An educated guess is that you have a cracked circuit board or a bad solder joint. OFTEN the boards crack or traces get lifted or solder broken near pots such as volume control, etc.
Another place to look is the connections where jacks are soldered... those are chronic failure points.
One other problem is the bypass switches on the effect insert jacks. The contacts of the switch part of the jack get oxidized or bent.
Feb 16, 2010 | Music
Crate FlexWave FW15 Guitar Amp Combo, 15 Watt Single 8 Speaker Logo
526 people viewed this question
Top Crate Music Experts
rjivaro
Michial Gueffroy
Ben Armstrong
Are you a Crate Music Expert? Answer questions, earn points and help others
