Question about Arnold Corporation Arnold Corp OEM19A218 Lawn Tractor Weight Kit
Will the Arnold Corp OEM19A218 Lawn Tractor Weight Kit work on my Sears/Craftsman (model# 28925) Lawn Tractor? Will the hitch pin hole still be available to pull attachments (e.g., a small utility cart) when Arnold Weights are added? Thanks!
  • shamilton177 May 03, 2010
    It seems to me that for the fee I paid, you could at lest spell "properly" correctly. Does not enhance trust in a supposed "guru".
  • 370 Answers
No the weights will be in the way of hooking up anything to the hitch and if you can get a hitch in there you will not be able to turn proporly.
Posted on May 03, 2010
  • Dave Martin May 03, 2010
    if you need to put weight to the tractor, if it where me I would go buy a wheel weight they bolt right to the inside of your rear rims and you can remove them easaly.
    Thank you for using Fixya.com
Sears craftsman lawn tractor stops as soon as it gets warm, and starts right back up when cools down. down anyone else have this problem?
It could be that there is too much oil in the engine. When it heats up it may slosh around covering the overfill hole in the upper casing. I'd check the oil level make sure it's perfect and use 30 weight oil. MJ
Aug 22, 2015 | Craftsman Garden
Problem for Craftsman 20 hp 42 in. Deck Lawn Tractor - ca model wheel alignment: both wheels point outwards
the bar connecting the wheels is bent. this is easy to change. just pull the pins out on both sides and lift the rod out. you can straighten it in a vise or order a new one through sears. cost about $12. our local repair shop keeps them on hand.
May 20, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
HOW DOES THE CABLE ON A SEARS CRAFTSMAN RIDING LAWNMOWER LT2000 17.5 HOOK INTO THE DECK
ON TOP OF THE SMALL IDLER PULLEY THE BOLT IS LONG AND IT HAS A HOLE IN THE SPRING GOES ON THAT BOLT AND THEN A WASHER THEN A PIN THAT HOLDS IT IN PLACE
Nov 19, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Model # 917256563 19.5 hp Craftsman. Ran fine until the front tire fell in a small hole. I heard a poping noise from rear of tractor I lifted the wheel out the hole and now the tractor will only run if I...
If the tractor stopped abrubtly, you may have bent something pertaining to the frame or the clutch pedal assembly if you caught your weight on the clutch when it stopped. Sears parts.com has en exploded view if you enter your model number
Aug 21, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Need instuctions on how to put plow on.
There is a fairly new sears site (as of 4-11-08)that includes all manuals for all sears products:
http://www.managemyhome.com/mmh/prod...Display.action
Make sure that Scripts are enabled in your browser.
Enter lawn or garden tractor manuals as:
Type of Product:
lawn mower (or tractor)
Brand:
craftsman
Model no.:#
(example: 917.276081)
make sure if the model has a suffix (like 917.276081 or 917.276082) to use it. This also works for all attachments, and add-ons.
May 18, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Loss of drive in a Craftsman Lawn tractor
I also have a Craftsman tractor with the same problem. Sears repairman said it needed a new transmission and it would cost $1,400 to install. A new one is about $1,000. Anyway, if you remove the battery and the battery tray under the seat it will expose the transmission fill hole (hex). I opened the top and it looked empty. I had a bottle of 90 weight gear oil in my shop and filled the transmission to the top. I have not had any problems with it since. $4.00 bottle of oil verses a new tractor is worth a try.
Mar 30, 2009 | Craftsman Garden
Arnold Corporation Arnold Corp OEM19A218 Lawn Tractor Weight Kit Logo
Top Arnold Corporation Garden Experts
Dennis Key
Dennis Key
john h
Are you an Arnold Corporation Garden Expert? Answer questions, earn points and help others
