Question about Sony Playstation 3 (PS3) Console
Every time i turn on the console the system tries to update but gets to 99% then stops
    President:
  • 1,469 Answers
try the steps below. Its from PlayStation Forum:
1. Turn off Playstation®3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION®3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION®3 System
If the above steps still does not solve the problem, then I think will have to update your Ps3.
Update your PS3 (in the settings menu the 1st option).
Go on the internet browser on the PS3 then go on the menu press triangle then on one of them there are delete cookies and the delete the others as well as cookies.
You could also try this as well: put the PS3 on then press the eject button (with no disc in) then hold it and switch the PS3 off at the back with your finger on the eject button still holding it, then put it back on and the fan test should be working this may cool it down. It might be over heating.
If after trying the above options and it still does not solve the problem, then maybe the lens is weak and that's why it cannot read any disc.
But if your problem is not still solved, then maybe you should call sony for further assistance.
Good luck.
Posted on May 03, 2010
How do i get a system update for the 3ds
Welcome to Fixya. Please follow the step below to perform system updates
How to Perform a System Update
To get the latest available features as well as the most current enhancements to the Nintendo 3DS system's performance, we recommend downloading the most current System Update.
(For the latest information on Nintendo 3DS System Updates, click here!)
Important! Your Nintendo 3DS must be connected to the Internet to perform these steps. (How to)
What to do:
1. Turn on your Nintendo 3DS and access the System Settings by tapping the wrench icon.
2. Tap "Other Settings."
3. Tap the right arrow three times to reach page "4."
4. Tap "System Update."
5. Tap "OK."
6. Tap "I Accept."
7. Tap "OK" to begin the update.
Important Note:
It may take several minutes for the System Update to download. If you feel the update has stopped downloading, you can safely turn off the Nintendo 3DS and repeat these steps to try again.
You can also refer on the link below.
3DS system updates
Thanks for using Fixya.
Dec 17, 2011 | Nintendo 3ds Handheld Game Console- Cosmo...
Ps3 froze installing system update
Cut it off. This should not mess up your HDD. Then i would just try again.
Dec 01, 2011 | Sony Playstation 3 (PS3) Console
I was doing a system update and it stops at 99% I called sony we tried to get it in safe mode but when it starts back up it starts downloading update again and it freezes at 99
you called sony and they let you off the phone with no solution, I would try it on another network somewhere to see if the problem re-occured. If it did I would not let them off the phone until we reached some form of resolution.
Rylan
Dec 17, 2010 | Sony Playstation 3 (PS3) Console
I attempted to update the system from a game and now it's stuck. when i turn it off its just starts the update again and every time it gets stuck on 99% and it just stops. i tried getting to the restore...
If the power button hold doesn't work...try this...,
Take the clip out that holds the drive. Take the screw out but leave the drive inside.
When the update begins, pull your drive out. You will get an error message and it tells you to restart your system to try again. Instead, let the time run out, and your screen will go blank for about 30 seconds until it starts back up telling you that you need to reformat the drive. (If you don't get this message after 30 secs the first time, YOU HAVE TO REPEAT IT till it does. Then put your drive back in again making sure your controller is plugged in (wired in with USB) and press the PS3 button on the controller. It will then ask you to either press start and select at same time OR PS3 Button PRESS START and SELECT. Do not agree to any user agreements!! Make sure you hit cancel and it will reset to the startup screen.
* Just wondering....did you recently open your ps3?
Dec 14, 2010 | Sony Playstation 3 (PS3) Console
Hello i am trying to update my ps3 and it gets to 99% and jamms i try turning it off and then back on but it just happens again , i also tryed to put it into safe mode but it does not go into safe mode it...
First of all turning off your Playstation while it was updating was a bad idea because it might run part of the installation. Second the last 1% of the download usually takes the longest time because this is where your system installs the software it has downloaded. My guess is that it wasn't jammed and was still installing.
Oct 24, 2010 | Sony Playstation 3 (PS3) Console
My ps3 is stuck on the system update screen on 99%. When I turn it on, it automatically goes to the system update screen. It sits at 99% for about a half hour before it gives me error code 8002f318. I've...
Your PS3 hard drive may be corrupted. Do you know, send back to game shop is too expensive and waste your time. Learn the repair skills and fix it by yourself is the ultimate method. Here is the repair guide for you to learn :
DIY PS3 Repair Guide
Not only hard drive problem, you can repair other red and yellow light issues as well. After you purchased the product, you will be guided to the step-by-step videos and ebooks for you to work with.
Jul 20, 2010 | Sony Playstation 3 (PS3) Console
Download freeze
Is this when you try a second and third time to download the same movie? Try a different one. Update to version 2.2 (came out last night). It has upgraded reliability for the internet. Hopefully that helps. Good luck!!
Mar 16, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
42 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
