Question about Konica Minolta magicolor 2430 DL Laser Printer
I have some small pieces of paper stuck in the fuser unit from a sheet that got stuck - how do i get them out as I cannot see them?
  • peter_browni May 05, 2010
    It is not obvious how to start to dimantle the appropriate parts. Are there some assembly drawings available to show the disassembly secquence?
  • 1,219 Answers
Start to dismantling it untill you are able to see the paper and then with tweezers remove the paper carefully
Posted on May 03, 2010
Paper jam in fuser how to solve my problum
remove the fuser unit a check for small pieces of paper inside , use a small pliers to remove the papers. if not disassembly the fuser unit and get rid of any papers inside.
Apr 25, 2016 | Office Equipment & Supplies
Ml-2160. How can I remove small pieces of paper from inside?
Generally paper is stuck either in the middle section or at the back near the fuser. Remove Toner cartridge and open rear door, if it's stuck coming out of the fuser, pull paper through from the back. Make sure to let the machine cool down first as the fuser is very hot. Remove any small pieces of paper from the front if before the fuser.
Jul 01, 2012 | Samsung Office Equipment & Supplies
Copier keeps giving paper jam on A4 sheet feed although no paper is jammed. A3 Feed is no problem. Is tthere sensors that need cleaning etc??
please pull the tray out and check machine properly .may be there is any small piece of paper .remove it check machine from inside and fuser unit also..if the problem stills check all sensors by manually moving and cleaning ..problem will be solved
MIAN JEE
Sep 24, 2011 | Canon iR 2022 Printer
Printer problem
even a very small piece of paper (A small piece torn off a jammed sheet) can cause the sensor arm to stick in place giving a false paper jam. Double check the entire paper path (what is visible) using a flashlight.
Also, check for broken "flag" sensors. Basically a flag sensor is a small piece of plastic that is pushed out of the way when the paper is traveling through the unit. If one of these flags is broken it may display a paper jam error as well (The flag after paper travels through will drop back into the paper path.) If this is broken it will not trigger the sensor and thus the error condition exists..
Most likely you have a small piece of paper stuck inside the paper path somewhere.
Do not, I repeat do not use any sharp or pointed metal objects to remove any small paper from within the fuser unit, the fuser covers are very delicate and such poking and prodding will likely damage the fuser covers, causing bad print quality or drastically decrease the fuser life (a small tear will quickly render the fuser useless).
Hope this helps!
Aug 31, 2009 | HP Office Equipment & Supplies
Paper jams frequently. the top left corner of the sheet is often turned over
There might be a problem with the paper tray or there could be a piece of paper stuck in the paper path or fuser unit.
Jul 31, 2009 | Brother HL 5250DN Laser Printer
Hp laserjet 1320 folds corner of paper after it prints.
Open the back of the printer - make sure it is clear. Then remove the toner check throughout the printer - reseat the toner and try to print
Jun 18, 2009 | HP LaserJet 1320 Printer
How to remove the scanner unit on Canon PC1060
you sould not have to remove the scanner unit to clear a jam in the fuser
open all doors and remove anything marked green
remove the the cartridge assembly if it will come out
open the fuser section (usually a release that takes pressure off of the fuser rollers
remove the paper feed cartridge
you now should be able to follow the paper feed path from the time paper goes i until it comes out
if you are not sure of path take a piece of card stock and simulate it goig through feed ara
there are small microswitches/ poto eyes that sense paper lok for an small pieces also clean thes poto eyes with q tip and rubbign alcohol
reassemble
unlug from the wall then plug back in and turn on p roblem sould be solved
Jan 05, 2009 | Canon PC1061 Copier
Nec 860 laser printer fuser unit
remove cartridge and leave top door open, then remove two screws in back ; open front sheet panel to find two screws to remove then remove outer case carefully AND PLACE ON LEFT SIDE BECAUSE THERE'S A RIBBON WIRE ATTACHED.
there are 4 screws holding the fuser unit in place, remove AND LIFT OUT BY ROLLING TOWARD YOU to reveal 2 screws to access the red roller assembly!
In my case there was a very tightly wound piece of paper stuck in there not visable without removing the screws on the fuser unit!
Dec 18, 2008 | NEC SuperScript 860 Laser Printer
Paper jam 580
You know what I would try, look in the fuser unit and see if any paper ripped off and got stuck in there. Wait until it's cooled down, but usually if you have to pull paper of of there, little pieces can get caught in there. Also, you may have a full sheet in there, I've had people leave and entire sheet in the fuser all scrunched up and the machine print fine for another 100 prints and then have an error and the paper coming out looking like it almost caught fire.
That's where I would look first if there isn't anything in the print path under the toners, etc.
Oct 27, 2007 | OKI C5100n Laser Printer
Paper Jam Message
Where is it saying the paper jam is located? Do you have a service code? It sounds as if either a paper pass switch is stuck in the down position (meaning it thinks there's a piece of paper there), or you may have a sheet of paper stuck in the fuser or behind a guide plate. Check on these and let me know!
Apr 10, 2007 | Sharp AL-1655CS Laser Printer
Konica Minolta magicolor 2430 DL Laser Printer Logo
169 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
