20605 Washer - portal door hinge is loose - so door vibrates and bangs loudly in the spin cycle... literally tearing itself apart. Where can I get the replacement hinge parts, including the clips, and how do you get at those back plate clips?
    Sergeant:
  • 351 Answers
Its a big job the door comes as a kit,you have to losen the front panel that the door sits on thers two bolts on the back of the front panel you get access from inside take off the back panel use 60 cm extension then remove door seal and ring the screws for the door are behind the hinge you will have to move the front panel forward and stick screw driver handel between so you can get access,but the kit does have instuctions.it will take about 1 hour or so.hopethis helps. model 20605 is an asko
Posted on Mar 26, 2008
Wash machine won't spin all the time and makes a loud banging noise.
Check to make sure that your clothes are not piled to one side causing the load to be off-balance. If that does'nt fix it then, It may be that your machine has a balance stabilizer on it that has worked its way loose or even off.
Jun 11, 2012 | Frigidaire Affinity ATF7000E Front Load...
Drum is making a loud banging noise during spin, it is brand new
Some banging or knocking during the ramp up to spin speed in this washer is normal. It is difficult to determine whether your washer has a problem or not based on your description. This banging lasts for varying amounts of time until the load is balanced and the washer ramps up to the full spin speed. If the load can not be balanced on the first attempt, the washer will ramp down and then tumble and attempt again to ramp up to speed. This may be the same thing that you are hearing when your washer ramps up to spin speed. Since the washer does spin at the full speed, there is not likely a problem with the washer. The components are designed to withstand repeated vibration and reasonable banging or knocking. The washer will vibrate to some extent at high speed. If you feel that the vibration is excessive, I recommend that you check the stability of the leveling feet. Press down on the diagonally opposing corners of the washer to check for play. If the washer rocks at all when conducting this test, I recommend that you adjust the leveling feet to eliminate this play even is the washer is not perfectly level after making this adjustment. This may help reduce the banging and vibration. Other than that if it is brand new call the people who you purchased it from so you don't void any warranties by taking it apart.
Sep 08, 2011 | Washing Machines
The tub inside of the washing is very loose and bangs very loud when washing especially on yhe spin cycle
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Oct 13, 2010 | Frigidaire ATF6000ES Front Load Washer
Loud banging noise on spin cycle
something is loose, i would take apart and check for loose objects, or call a pro to do it for you., it can be a tedious job.
Nov 06, 2009 | Zanussi ZWF14070 Front Load Washer
Washer FTR630ASO Fridgedaire - inside tub is loose and loud
we've got this exact washer. we had a very similar sound/problem. it turn out to be the shock absorbers. easy replacement. under $100.
Oct 08, 2009 | Washing Machines
Kenmore washer loud bang in spin
Great!! Thanks for the followup -- I mean really, thanks!!
May 02, 2009 | Washing Machines
Washer spin cycle extreme vibration and loud bang when it stops
check the vibration damper rods for breakage - especially the mounts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 17, 2009 | Kenmore Washing Machines
Spin cycle very loud,
spin surpport defective,,,this part is under warranty,,lifetime warranty..contact whirlpool for replacement of spin basket,,onthejopb
Feb 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Loud sounding like loose parts when draining
possibly a coin or hair clip in the pump if not the propeller on the pump may be loose try locating the pump under the machine and try to romove it
Nov 11, 2008 | Kenmore 43052 Front Load Washer
Excessive vibration during spin cycle
If this is the only problem be thankful ,its capable of a future of problems. I my self would not recommend putting 1 more dollar into this machine.Your next concern is a high dollar repair that may be soon coming ,that is a circuit board problem.
Please rate this !!
Jun 09, 2008 | Washing Machines
Washing Machines Logo
120 people viewed this question
Top Washing Machines Experts
