P52926 52 in. Rear Projection Television: Hello. I am trying to find out what tube I need...
Hello.\r\ni am trying to find out what tube I need for a rca P56926.
  • 4 Answers
Look on back of tv for make and model. get online and go tothe manuel of that brand look up parts and it should tell you
Posted on May 03, 2010
Samsung HCN5529W 55in Rear Projection can't Perfect Focus
hello What you have is a convergence problem. There is 2 modules inside your set that aligns the colors to have the same geometry and superposed . It is a common problem in rear projection tvs ,
You don`t have to worry about your blue tube , i`m sure it is perfectly fine, it just needs to be aligned through the convergence circuit.
Most often the problem is with those convergence modules that are faulty and need to be replaced.
Hope this will help good luck
Dec 07, 2009 | Samsung HCN5529W 55" Rear Projection...
Blue lines in screen
Follow the steps below after verifying that the issue is occuring on other channels and other video sources.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved, service may be required.
Sep 22, 2009 | Sony KP-51HW40 51" Rear Projection...
How would you replace the coolant for a philips 50p8341 50 in rear projection television
you have to remove the picture tube, drain the fluis through the drain plug, then take the lens cap off, clean out all the crud, then fill it up with new fluid, don't try to do it while it's still in the set, you could spill fluid on the board and cuse major damage, also, if you remove the tube, usually you will need to re-adjust the convergence of the tubes, usually only the blue and green tubes need this, pretty major repair, i don't recommencd doing it yourself, but getting a qualified repairman to do it.
Sep 08, 2009 | Philips 50P8341 50" Rear Projection...
HELLO OUR 53" PANASONIC REAR PROJECTION TV JUST WENT RED LAST NIGHT AND THEN WENT OFF AND IT WILL NOT COME BACK ON ANY IDEAS. IT TRIEDS TO START UP WITH A BLINK AND THEN OFF AGAIN
This model TV has a gasket on the red picture tube that faces down. The coolant leaks from between the picture tube and the lense assembly. When this happens the red tube over heats and shorts out internally and usually cracks the glass.You will probably find coolant all over the circuit board if you open the back panel of the TV.
Call a good TV Tech to repair this. It will cost over $500 if the picture tube is still available.
Jul 30, 2009 | Panasonic PT-53WX53 53" Rear Projection...
SONY PROJECTION TV (42 inch)
most sure your tv is getting sick, just kidding
probably convergence problem you may need to call a tv tech
Aug 06, 2008 | Sony KP-51HW40 51" Rear Projection...
Philips 43PP925 rear view television
Can you describe what you mean by "funny with colour" please? That will help to determine the problem circuit.
Thanks,
Dan
May 23, 2008 | Philips 43P8341 43" Rear Projection...
KP 48V45 TUBE
The only part available is the Red CRT for this model. This Red CRT itself produces the Red Light. Please see below for a link to this item.
Sony KP-48V45 Red CRT Replacement
Apr 10, 2008 | Sony KP-48V45 48" Rear Projection...
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
