Question about Kitchen Ranges
KESA907P Electric Kitchen Range: Oven comes on but the off button will not work. H...
Oven comes on but the off button will not work. How do i turn off the oven? kesa907p
    President:
  • 1,015 Answers
It sounds like it could be a stuck off/cancel button on the touch panel. When you push the off/cancel button does it feel like the other buttons or different. Usually when these buttons get stuck the proper repair is to replace the touch pad. Some of the newer ranges will produce an error code on the display when a touch panel button is stuck but not always. Unplugging the power to the range might work for turning off the oven but is not recommended. If everything else is functioning properly except for the off/cancel button then it sounds like the touch panel may need to be replaced.
Posted on May 03, 2010
Model KESA907P - During self clean, lost power and won't start. Door is locked and totally cooled down. Display is blank w/o power.
I had a similar problem. Got the answer from Macmarkus. Check the HI-Limit Safety Thermostat.
See the thread of our conversations.
Aug 08, 2011 | KitchenAid KESA907P Electric Kitchen Range
Oven panel buttons will not turn on oven. Stove top works fine.
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Feb 06, 2011 | Frigidaire Gallery GLEFM397DS Electric...
Frigidaire Electric Range Model FEF355ESB
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
May 07, 2010 | Frigidaire FEF355 Electric Kitchen Range
Inglis Niagara oven not working since power outage
try pushing cook and hold button once until lock comes on, then push cook and hold button again. The lock should be removed.
Aug 13, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Turn oven on Red self cleaning light comes on
You oven latch handle is either bent or the switch that attaches to the last assembly is bad. More likely you have a bent latch. You can get to it after unplugging the range, lifting the cooktop up (3 or 4 screws under the front lip) then the panel under the cooktop has to be removed to see the latch.
Dec 17, 2008 | GE Spectra JBP78 Electric Kitchen Range
Maytag electric gemini,model mer6755aaw
Hello bigboy1666,
Welcome to Fixya,
You said, Oven does not show any displace and does not work. When you try to turn on the top oven, the displace shows h3 132 and the clock shows 12:00 .
You try to turn the upper and lower oven, none of them work. The light in the oven comes on okay.
Lets try to reset the system.
trun off the range.
Now trhow the breaker in the electric box off for 5 minutes.
after waiting 5 minutes turn the power on and try the range!
Let me know how she works.
Huuum at your service.
Please remember to leave a rating!
Oct 06, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Oven does not come on
First, reset your circuit breakers. This is generally a pair of breakers with at least a 30 ampere rating. It is not your kitchen breaker. Turn them both off and back on. If this doesn't do it, you've got to look at the heat element. Does it look damaged, deformed, discolored? If so, remove it and bring it to the appliance guy to get it tested. Generally this is a couple of screws. Make sure power is off when dealing with this. Not the element? Then you've got the control board.
Nov 22, 2007 | Frigidaire FEF336BC Electric Kitchen Range
Magic Chef electric range model # 3888VRA
Sounds like the oven control needs to be replaced.
Sep 24, 2007 | Magic Chef CER3725AA Electric Kitchen...
Kitchen Ranges Logo
209 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
