Question about Texas Instruments Office Equipment & Supplies
TI-89 Calculator: installation in progress, do not interrupt...
Installation in progress do not interrupt
SOURCE: Ti-89 calculator problem
try hitting 2nd + left + right + on... worked for mine
Posted on Feb 03, 2008
SOURCE: TI-89 Titanium (hardcore reset)?
Hi, i was having the same problem.
I wanted to upgrade my Ti 89 titanium OS, so i run the Upgrade check inside the Ti Connect App. It downloaded the OS to a folder. Then i tryed to upgrade with that OS, and in the 99% it fails.
I guess something was wronge since the progress bar in the windows downloader app was out of sync with the calculator percentage. I downloaded myself the OS from Ti, and removed all batteries (including the backup). After plugin in the batteries again, i started the Os downloading with the new file, and the progress was perfectly synced with the calculator percentage.
it finished flawleslly and now it is working :)
please excuse my english, im spanish
Posted on Jan 28, 2008
onomou
  • 24 Answers
SOURCE: steps in solving matrix on my ti 89 calculator.
I assume you are speaking of solving a system of equations with a number of unknowns. If not, please correct me. Here's an example in practice:
If you have a system of 3 equations with 3 unknowns, you would set up your matrix so that the coefficients of each variable for a particular equation are on one row. So, given equations x + y + z = 0, 2x + 3y - 4z = 1, x + -z = -1 you would type the following into your calculator: [[1,1,1,0][2,3,-4,1][1,0,-1,-1]] and press enter to make sure you typed it correctly. notice that in the third row there is a zero, since we have zero time y for the third equation. Then row-reduce the matrix (2nd > 5 > 4 > 4 or in the CATALOG as rref). You should get out the matrix [[1,0,0,-1][0,1,0,1][0,0,1,0]]. This says that x=-1 y = 1 z=0 since my first column contained the coefficients for the x variable, the second for the y variable, and the third for the z variable. The last column contains the solution, the part on the other side of the equals sign.
Hope this helps! For more reading (from someone else; I just made this one up), check out the Wikipedia articles on Gaussian elimination and Systems of linear equations
Posted on Oct 03, 2009
onomou
  • 24 Answers
SOURCE: cannot connect ti 89 to computer
Check to make sure TI-Connect is looking on the right port, whether USB or serial. If you have a serial cable, you might consider using Ti's Graph-Link software to connect. I have had trouble getting it to work right with TI-Connect. You can find Graph-Link on TI's Education site under Downloads > Connectivity Software. I personally prefer the free program TiLP, which runs on Windows, Mac, and Linux and supports whatever cable you want. Hope this helps!
onomou
  • 24 Answers
SOURCE: TI 89 problem
Try doing a hard reset (hold simultaneously Left + Right + 2nd + On). If it just isn't wanting to display properly, but does turn on, that might help. I think you can do the same thing by taking the four AAA's out and the spare CR1616/CR1620. Otherwise, the battery acid probably ate one of your components and it's time to repair/replace your handy-dandy.
I have the Ti-89 titanium calculator and will not turn on after I changed the batteries. I pushed the green button with the star and held down +. I also tried taking out the backup battery. What should I...
Hi 1945779,
Pressing the green button and, the plus sign is to raise the contrast. Keep doing that process because, if the calculator comes on and, the contrast is to low you'll never know the calculator was ever on. You should also make sure the ports are clean and nothing inside them causing the calculator to short out.
Your only suppose the have all the batteries out for 5 minute but, I had a Ti 85 that I had the batteries out for 20 minutes and, it came on. Leave them out for 5 minutes at the start of this process.
Make sure the batteries are in correctly? The batteries alternate negative/positive, positive/ negative and so on. The first time I put the batteries in, I didn't have them in correctly. I know if it happen to me that anybody could make the same mistake. The small battery should have a plus sign facing up when it is installed properly. And of course, the calculator will never come on if the batteries aren't in correctly.
Setting up the computer and, calculator for new OS installation.
  • Make sure TI Connect software is installed on the PC.
  • Connect the TI Connectivity cable to the Ti89 titanium and the computer.
  • Do not start the TI Connect software, just have it ready and, on the desktop.
  • Download the Ti89 Titanium v3.10 OS to the PC's desktop.
Reset the RAM first. If the calculator still won't turn on goto the next paragraph and, set of instructions. On the Ti89 family, press and hold the [2nd] [Left Arrow] and [Right Arrow] keys. then press and release the [ON] key. This should reinitialize the operating system, in which you should see a progress bar or, "Installation in Progress" displayed on the screen.
Hold down the APPS key and, take one AAA battery out of the calculator. Put the one AAA battery back in while still holding down the APPS key. Release the [APPS] key and, be ready to install the new OS v3.10, ASAP!!! The (older Ti89) may need to press [ALPHA] [9] or, just [9] when the calculator display's, "Press to install..." and, then they need to install the new OS, ASAP!!! You have to do this process in the right sequence because, the calculator will be destroyed if you do not.
You can either drag and, drop the new OS into the TI Connect icon (pictured below), on the desktop.
Or click, Start and open Programs, then open TI Tools, then open TI Connect, then open TI OSDownloader. Then just follow the instructions the software gives you. The best way is to drag and, drop the OS into the TI Connect icon because, you know your installing the latest OS. TI OSDownloader might not give you the latest OS version.
If this procedure doesn't work and, is still under "Warranty", I'd see if I could get a replacement from Texas Instruments. Even if out of "Warranty", I'd would still seek replacement with Texas Instruments.
If you have any question just post a comment and, I'll respond quickly.
Jan 21, 2011 | Texas Instruments TI-89 Calculator
I get a pop-up ballon that says "USB device not recognized"
How do I fix Error: TI-89 Detected, but could not get status with the TI-89
using the TI Connect software for Windows?
The Operating System (OS) will need to be updated on the TI-89 in order for the TI Connect™ software to detect the status. Try the following procedure to install the OS from the TI-89 Boot Screen. Make sure TI Connect 1.6 is installed on the PC.
• Connect the TI Connectivity cable to the TI-89 and the computer.
• Do not start the TI Connect software.
• Download the TI-89 v2.09 OS onto the PC's desktop.
**Force TI-89 into "Boot screen" (See instructions below**
• "Press I to install..." ([ALPHA]. [ 9 ]).
• Click on Start >> Programs >> TI Tools >> TI Connect >> TI OSDownloader.
• Follow the on-screen directions to install OS version 2.09.
The download should begin.
**Steps for Boot Screen:**
• Take one AAA battery out, press and hold down the Apps key while reinserting the battery to force device into the Boot Code screen.
• "Press I to install..." will appear.
Once the OS has completed installation, the TI Connect™ software will be able to detect the TI-89.
Mar 01, 2008 | Texas Instruments TI-89 Calculator
My TI-89 Titanium's screen froze. Well actually, the cursor kept blinking but none of the buttons worked. I got it to restart using the (-) and ) button trick, but rather than going back to normal it went...
Hi kelsers,
You need to re-install your calculator's OS. After this process your Ti 89 Titanium will operate properly. If you do the process below make sure you use new batteries.
Warning!!! If you do this procedure make sure that your computer and, calculator are connect. Use Ti Connect software and, make sure you can install the OS on the calculator without any interruption. At any time even at the very beginning of this process, if your computer or, calculator gets interrupted or you have a power failure during the installation of the OS, your calculator will be destroyed. So not attempt this procedure during a thunder storm.
You can use the Ti OS Downloader but, you will have no idea what OS is stored by the Ti OS Downloader. So, I suggest following my instructions and, installing the newest Ti 89 Titanium OS 3.10v.
Procedure to installing the newest Ti 89 Titanium OS 3.10v.
You can also get the latest copy of Ti 89 Titanium OS 3.10v by going to the Texas Instruments web site. You can get to that site instantly by clicking, "Ti 89 Titanium OS 3.10v." Once your at the Ti site click the Download Item, Ti 89 Titanium OS 3.10v. Next you can login or, click "continue as guest". I'd would click the "continue as guest". Once you have click, "continue as guest" the Ti 89 Titanium OS 3.10v. will download to you. Click, "SAVE". And then a folder will pop up. It is probably a folder that you download too. If so, you may want to change it and, "Save as" to this folder, "My Documents \ My TI Data \ Downloads". You can also go back and, download the Ti 89 Titanium guidebook too, if needed.
Link your computer and calculator with the USB cable or, Direct Black Link cable that came with the calculator.
Remove one of the AAA batteries. Press and hold the [APPS] key, and while holding the [APPS] key, replace the battery and turn the unit on. On the older TI-89 you should see "Press I to install code...", and you should press the [9] key to continue. But, on your Ti 89 titanium it should say, "Waiting to receive..." or, "Waiting to received OS...". Now you need to follow the instructions in the paragraph below to restore the calculator's operating system.
Next, drag the Ti 89 Titanium OS 3.10v. that you copied earlier to "My Documents \ My TI Data \ Downloads" out of that folder and, drop it in the "Ti Connect" icon on the desktop. Next the OS Downloader Warning will pop-up. Click, "OK" to continue and, the new OS will begin to install. The Ti Device window should pop up and, click on to the port where your Ti 89 Titanium is located, USB1 cable or Direct Black COM1. Just click, "Select" and, the OS will continue to download. Upon completion the newest Ti 89 Titanium OS 3.01v. will be installed.
Jan 10, 2011 | Texas Instruments TI-89 Calculator
Ti 89 detected but couldn't get status
Here is what the FAQ and Knowledge Base area of the TI site has to say about the problem you are having. Hope it helps.
How do I correct the error message "TI-83 Plus or TI-89 detected, but could not get status" using the TI Connect software for Windows®?
The Operating System (OS) will need to be updated on the TI-83 Plus family or TI-89 calculator in order for the TI Connect software to detect the status. Try the following procedure to install the OS from the TI-83 Plus and TI-89 Boot Screen. Make sure TI Connect 1.6 is installed on the PC.
If using a TI-89 calculator:
• Connect the TI Connectivity cable to the TI-89 calculator and the computer.
**Force the TI-89 into the "Boot screen" (see instructions below)**
• "Press I to install..." (press the [9] key).
• Take one AAA battery out, press and hold down the [APPS] key while reinserting the battery to force device into the Boot Code screen.
Once the OS has completed installation, the TI Connect software will be able to detect the TI-89.
Oct 31, 2009 | Texas Instruments TI-89 Calculator
OS failed now installation screen stuck
I suggest you interrupt the installation with [Esc] or [Diamond][QUIT]. Then download the OS on your computer and drag and drop OS on the open window of TI Connect to transfer it to calculator.
Press the [Diamond][QUIT] several times. If it refuses, all that is left for you to do is remove main batteries and restart the installation as described above.
Hope it helps.
Sep 30, 2009 | Texas Instruments TI-89 Calculator
Stuck on Software Installation screen after failed OS instal
You do not say if the installation proceeded to some degree or did not start at all. It seems to be hung because the website was too slow.
Hope it helps.
Ti 89 buttons won't work
Well, I just waited a few more days and now it works! I'm so happy...
Jan 14, 2009 | Texas Instruments TI-89 Calculator
when i hit 2nd+left+right+on then i saw 'installation in progress' on skin. what i have to do? please help me.
Nov 18, 2007 | Texas Instruments TI-89 Calculator
Hey guys,
Do this it will reset your calc and get you out of your busy state
2nd - left arrow - right arrow - on
It will reset your calc no matter how frozen it is.
Nov 16, 2007 | Texas Instruments TI-89 Calculator
485 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
