Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Problem HI I HAVE A PROBLEM WITH LINEING UP THE COLOR CROSS LINES. THAT LINES UP TO MIDDLE
  • Philips Master
  • 8,617 Answers
Your convergence ICs will need to be reolaced there are two of them they cost about 10.00 each.
Posted on Mar 26, 2008
6ya staff
SOURCE:
TV HAS A COLOR LINE WHEN IS ON IN THE MIDDLE OF SCREEN
if it runs across the screen its a buffer board usually. Can you paste a picture of the line?
Mar 10, 2013 | Sanyo DP50747 50 in. Plasma TV
What heigh do you set the headlights when adjusting them?
park the car about 1 mtr from a wall and mark the wall with a chalk line level with the middle of the headlight and an upright line also in the middle of each lamp (a cross) with dipped lights only, the main part of the light should be under the line to the right of the upright line ----------------
- 0
IF THEY ARE TOO HIGH YOU WILL GET A TICKET.....
Jun 26, 2010 | 2005 Chevrolet Malibu
It prints fine using the new hp 15 black ink cartridge. But when I print with the new color 17 cartridge, it comes out with uneven 'cross lines' of color, like sliced sideways. The printer seems fine and...
it prints fine using the new hp 15 black ink cartridge. But when I print with the new color 17 cartridge, it comes out with uneven 'cross lines' of color, like sliced sideways.
Jan 16, 2010 | Apple HP DeskJet 840c InkJet Printer
My Toshiba 42H83 has developed a color problem. The color blue is about an inch off the other colors, the picture looks like a 3d movie without the glasses. I have used the touch focus button on the...
Alot of rear projection t.v.'s have a convergence option in the menu on the t.v. There you can set the try to set the colors back how their supposed to. Mine has a cross in the middle of the screen and you just have to try to get all 3 colors to line up. Unfortunately, the actual lens inside mine has to be aligned so it doesnt work. Just something to try though, hope it helps.
Jan 05, 2010 | Toshiba 42H83 42" Rear Projection...
Colors seperate and picture bent
THIS is a convergens problum .pls. prees menu key and see convergence menu select and see cross line on center the screen select one by one colour line to meching and cross line is white see the pictur is ok.
Oct 03, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Hitachi 53SBX10B-color and horizontal lines issues
with the original Hitachi remote go into the customer menu and select convergence---you should get a cross in the middle of the screen--look to see which color will not move either up and down or left and right---sounds like bad convergence IC and this is not uncommon in most rear projection sets---if this is the problem the set uses two convergence output IC chips that both should be replaced and then the set adjusted in the Technical menu----the convergence mode can be engaged by removing the front grill and an inspection plate behind it and pushing a small micro switch located on the front of the board; when the switch is engaged with the set turned on a grid of lines will appear on the screen and then the set is adjusted with the remote---hope this was helpful---if you need direct assistance you can contact me : [email protected]
Aug 11, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Red/Orange horizontal lines
it could be that the tv convergence circuit is going bad. One shure way of finding out is to go to the tv feature menu(picture,audio etc.) and select the customer convergence setting, you should get a cross hair pattern(cross in middle of screen). that cross should be white and by aligning the red or blue colors they should move left, right, up or down
Jul 27, 2009 | Akai PT5492S 54" Rear Projection...
Camera problem
Hi there! Just checking is it a line or a cross in the middle? If it is a cross it's normal. It is used for aligning the photo to center. You can always change it before taking a picture on it's setting. This is how: settings>metering mode>normal. If it is a line it could be a software or hardware. You need to take it over to the store where you purchased and ask for assistance.
Jan 28, 2009 | Sony Ericsson K550i Cellular Phone
Convergence
You need sevice code to enter convergence.
Mar 27, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Three colored lines across the middle...
Sounds like the vertical control IC has gone out. Replace IC N301 (TDA8351) and check or replace R370 (1ohm), R371(33ohm), and R380(1ohm). This shouldn't affect the sound but once you get video you might figure out what is wrong with the sound (control setting). The TDA8351 crosses to NTE7156 and shouldn't run you more than $10.
May 28, 2007 | Apex Digital GB5108 51" Rear Projection...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
20 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
