Windows XP Professional SP2: strt is not working.. what to do...
Strt is not working.. What to do
  • maxcastle255 May 11, 2010
    Please mention the problem with some detail.
Dipu007
  • 2110 Answers
SOURCE: Explorer.exe Application Error in Windows XP Professional SP2
Bring a bootable XPSP2 cd & boot from it ....when installling choose C: & format ..
Posted on Nov 29, 2008
SOURCE: genuine microsoft software
software counterfeiting
Posted on Dec 05, 2008
  • 20 Answers
SOURCE: find windows xp professional sp2 product key
If you bought it directly from Dell or an authorized reseller, there should be a Certificate of Authenticity sticker on the bottom, assuming you didn't remove it.
If you did, unfortunately there is nothing anyone will be able to do for you, Dell included(I've worked Dell CS).
If you are able to load into windows, you may be able to recover your product key through windows, google is your friend.
Posted on May 31, 2009
SOURCE: I want to open my windows xp professional sp2.but
Dear Sir,
If you have the box of the Windows Xp CD you can find in it the product key of it. take this product key and call microsoft in your country or any partener of microsoft and give them the product kwy and ask them for the activition code.
Posted on Oct 13, 2009
  • 45 Answers
SOURCE: Required Windows XP Professional sp2
You need to download utorrent and install it.
Just use the seach string "Microsoft XP Professional and key torrent" in google
Make sure you have your virus protection up to date and running as per normal when you download.
thepiratebay.com is a great site to get it from
If you have any problems let me know.
Cheers,
Dave
Please vote for me
Posted on Nov 26, 2010
My treadclimber 5000 treadils stops runing when I get step on the right one
Recalibrate the machine if speed is not registering, belts stop turning or the display readout shows an "err, LS, OS" on the face. Calibrate the Bowflex TreadClimber 5300 by plugging it in. Stand on the foot platforms, or floor mat. Do not stand on the walking belt. Insert the safety key. Press the "start" key when "CAL/PRSS/STRT" shows on the readout. If readout fails to show the "CAL/PRSS/STRT" symbol, turn off machine and turn it back on. Press "ENTER" and then "DOWN SPEED" at the same time until "CAL/PRSS/STRT" shows up on the display. Belts will start and stop during the calibration; do not be alarmed. Do not make any adjustments or interrupt the display of numbers as the unit goes through the calibrations. When the machine is finished calibrating, the readout will display "CAL...PASS" and you can press the "POWER" key to get out of the calibration section
sincerely.
Nov 25, 2011 | Bowflex Treadclimber
I ve installed it but when i strt,a black screen appears
What version of windows do you have?? It only runs on windows 2000 and windows xp. If you are on windows vista or windows 7 try..
Right click the shortcut for the game.
Then select properties.
Click the compatibility tab.
Select "Run this program in compatibility mode for:" box.
Select windows xp.
Click the "OK" button.
Try running it again.
Mar 05, 2011 | EA Sports Cricket 07 for Windows
Gateway desktop wont boot up into OS XP just blinks with cursor on black screen
try this strt the pc when you see setup on screen press F8 key a few times then you will see options like safe mode and safe mode with networking and you will see an option to boot from last known good configuration use keyboard arrows to select this option your pc will reboot if this doesnt sort it the repeat these steps and on the screen select safe mode and hit enter key or return key let the files load on the screen when th pc goes into safe mode the screen will look different clik on strt then select alll programmes then select accessories then select system tools then select system restore ....select a date when your pc was last working correctly and clik next let the computer do its work when it restarts it should be working correctly (NOTE) any progrmms you downloaded from the date you selected will be eresed but not your documents or downloads like movies ...hope this helps
Dec 19, 2010 | Gateway GT4016 Desktop PC
New plug. New gas. Tried quick strt fluid.
If you are getting gas, then there is no spark. (likely a bad coil)
If you have a good strong spark, then you are not getting gas into the cylinder due to gummed up or faulty carberator
Apr 12, 2010 | Garden
Hi this is randie from philippines!! i would like to ask about trouble shooting diagram and codes!! my problem is it cannot strt the engine. theres spark and gasoline!! but it doesnt strt at all!!ps anwer...
you need to find out how much fuel pressure your pump is putting out,with a fuel gauge you can check pressure at the reed valve on the fuel rail,you will need at least 55 psi to fire the engine.
Dec 26, 2009 | Hyundai Motor 1996 Elantra
I know how to reset my cronograph seconed hand to 12 o' o'clock position. How do I set the minute hand to the 12 o'clock position
It depends on the movement or model. On some you have to pull the stem out to the second position and press the start button. On some you have to pull the stem out, push it back, then pull it out again in succession then press the strt button to set the minutes. Yet others you have to pull the crown out and press both strt and rst button to move the minute hand. In either case one of those combination's should work.
Sep 20, 2009 | Invicta Watches
CAR CRNKS - WNT STRT - DRVR GEAR FLSHES WHILE IN PARK - HELP!!!!
Get the codes for trany obd2.
Push reset fuel line swich shut off.
Check fuel presure should be 40psi
Disconect batery for 5 hours and try again.
Vitally
Apr 27, 2009 | 1995 Honda Accord
2nd Strt light
From my understanding it is as a result of you pushing the 2nd start button near the gear lever - ? it means the car takes off in 2nd rather than 1st
Mar 24, 2009 | 1999 Toyota Land Cruiser
Suzuki rmz 250 2005
if its making a rapping noise its the valves ,possibly contacting the piston
Nov 14, 2008 | 2005 Suzuki RM-Z 250
Computers & Internet Logo
11 people viewed this question
David Payne
David Payne
