Question about Dryers
DWSR463EGWW Electric Dryer: The dryer drum won't turn. I can turn it manually ...
The dryer drum won't turn. I can turn it manually when it's stopped but it won't turn when I start the cycle. It just hums.
It sounds like the belt that drives the drum may be broken
Posted on May 03, 2010
Dryer drum stops turning mid-cycle
The belt may be in need of replacement.
Dec 02, 2013 | Frigidaire GLEQ2152ES Electric Dryer
It stopped working tonight. When I go to turn it back on, it will make a noise like its on, but as soon as I take my hand off the button, it stops working. Ideas?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 13, 2011 | GE DWSR463EGWW Electric Dryer
GE dryer (PVXR363ED) can start (turning) with starter but stop right away after releasing stater
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Aug 20, 2010 | GE DWSR463EGWW Electric Dryer
Ge dryer is not heating up and so is not drying. Is this a heating element problem?
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 17, 2010 | GE DWSR463EGWW Electric Dryer
Dryer turns on does not turn
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Jul 06, 2010 | GE DWSR463EGWW Electric Dryer
The dryer drum will not turn, even manually with the belt removed
Sounds like something became wedged against the drum. Maybe a bearing?
Feb 20, 2010 | Frigidaire GLEQ2152ES Electric Dryer
GE DWSR463EGWW electric dryer takes forever to dry clothes. Heating element comes on but then goes off. Where do I locate the thermal fuse if that is the problem.
The thermal fuse only shuts off the elements if the proper air flow isn't acheived. If the clothes are hot but still damp after the drying cycle then you have a blockage in the dryer exhaust either at the hose at the back of the machine or in the lint filter area. Check both and clean and your problem should be solved.
Hope this helped you
Dave
Jan 14, 2010 | GE DWSR463EGWW Electric Dryer
I have a GE DWSR463EG2WW dryer 3 months out of warranty. Heat element comes on but does not start up and drum turns. There is a slight buzzing type noise. But no turn of Motor ?
sounds like your motor start capacitor is defective, its usually mounted on the motor case and is cylindrical in shape and will have two wires coming out one end,unplug the unit and then take an insulated screw driver and short the two terminals of the cap before touching in case it still has some residual charge remaining
Sep 16, 2009 | GE DWSR463EGWW Electric Dryer
Change belt
do you have the belt route right, on them models they have a safety switch the idler hits and if it is not activated it wont turn
Jun 24, 2009 | GE DWSR463EGWW Electric Dryer
Dryers Logo
124 people viewed this question
Top Dryers Experts
