Question about Cameras
Photosmart M425 Digital Camera: want format my new 4gb higdh speed memory car...
Want format my new 4gb higdh speed memory car
No format for memory card
Posted on May 15, 2010
My camera says the card has wrong format but then unable to? so i switched cards and it still does it?
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. Please note that your particular model camera is not capable of working with 4GB or higher cards. You'll need to use 2GB or less standard SD cards. These are relatively inexpensive, and may be purchased on Amazon if your local store no longer carries them. There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here.
Sep 27, 2011 | HP Photosmart M425 Digital Camera
Lans error.m425-11 ..............m425-21
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success.
Jan 17, 2011 | HP Photosmart M425 Digital Camera
I just changed my memory card and it said can't format the memory card wouldn't stay down what is the problem and where can i get it fixed in windsor ontario
Don't understand what you mean by won't stay down, but is this new memory card a 4GB or larger SDHC card? If so, it will not work with your older camera. You will need to use 2GB or less standard SD card only. Fortunately, these are relatively inexpensive these days. Recommend checking on Amazon.com.
There are several possible causes for "memory card locked", "memory card error", or "no memory card". Some include trying to use a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Dec 29, 2010 | HP Photosmart M425 Digital Camera
Would not format memory csrd gigaware 4gb
The M425 works with SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and will not work. You need to use SD cards, 2GB and smaller.
May 15, 2010 | HP Photosmart M425 Digital Camera
New 4GB SanDisk card won't format in my Hp M425 digital camera!
First be aware that a 4GB card may well exceed the capability of this camera as older cameras have a max capacity of 2GB because of the filing system that is used which is known as FAT.
A 4GB card is FAT32 and this causes problems because older cameras cannot recognize that system.
However please have a look at my FixYa Tip on the subject which gives a complete breakdown on the issue.
In some cases you can format a card with your PC and it may work with the camera.
Thanks for using FixYa.
Jan 01, 2010 | HP Photosmart M425 Digital Camera
If the memory card says card has wrong format and unabe to format is the camera broke?
If anything is broke it's the memory card. You need to get a new memory card.
Oct 21, 2009 | HP Photosmart M425 Digital Camera
Wrong format on HP M425
Just fixed this problem on a M525 camera (same physical construction).
Do a search with M525 and format.
Feb 10, 2008 | HP Photosmart M425 Digital Camera
Sd card formatting
Does SD card work in PC? HP R707 will not work with SD card larger than 2GB.
Oct 22, 2007 | HP Photosmart R707 Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
