Question about Motorola Mobility H350 Wireless Headset
Option to disable the blue headset status light?
The package for the bluetooth says that you have the option to disable the indicated light, how do you do this.
I think thay this will extend the battery life and usage
  • Anonymous May 22, 2008
    I just find the blinking light to be annoying blue beacon on my head and especially distracting while driving at night. Also, if anyone knows how to disable the audio tones (not sure its even possible), I'd like to do that as well.
Holding both volume buttons for about 4 seconds shuts the blink off, but it comes back if powered off and back on again, making it hard not to look like a cut price extra from Dr. Who (Torchwood)
Posted on May 27, 2008
6ya staff
SOURCE:
I lost my ear piece for my Plantronics Voyager 500A so I am trying to pair a new earpiece. How do I do this?
1. On the base, press and hold both speak volume fine adjust buttons until the blue talk/on line indicator light and red power indicator light (on the front of unit) start to flash.
2. On the headset, press and hold the listen volume adjust + button and call control button until the status indicator flashes red and blue.
3. Pairing is complete when the talk/on line indicator on base illuminates solidly, and the status indicator light on headset flashes blue.
Important: Make sure your headset is not connected to any other Bluetooth device when attempting to pair.
Good luck from Headsets Direct!
Jul 13, 2011 | Plantronics Voyager 500A Deskphone Adapter...
How to pair phone to samsung bluetooth headset wep301? I do not have my user guide.
Bluetooth Headset
Pairing Instructions
1. When you turn on your Samsung Bluetooth
headset for the first time, it proceeds into pairing
mode immediately.
2. If you have paired the headset with other
Bluetooth devices, make sure that the headset
is off. Press and hold the Multi-Function button
until the blue indicator light stays solid blue after
blinking.
3. Set your Bluetooth phone to discover the headset
by following your phone's guide. Typically, the
steps involve going to a 'Setting', 'Connection',
or 'Bluetooth' menu on your phone and then
selecting the option to discover Bluetooth devices.
4. Your phone will find the Samsung headset and
ask if you want to pair with it. Confirm this by
pressing the Yes or OK key.
5. Enter a passkey or PIN, 0000 (4 zeros), then
press the Yes or OK key.
6. If pairing was successful, the indicator light will
flash in blue 10 times rapidly before going to
flashing every 3 seconds. If unsuccessful, the
light remains on, and you will need to re-attempt
pairing.
7. When you turn on your headset after pairing
with the phone, the headset is automatically
connected to the phone.
8. When you turn on your phone after pairing with
the headset, the phone is connected to the
headset by pressing the Multi-Function button.
Jun 01, 2011 | Samsung SGH-U600 Cellular Phone
Hi, I have purchased Samsung Galaxy ACE S5830 whether it is possible to connect Samsung Bluetooth Headset WEP 450. Kindly inform me how to do it.
1 Enter Pairing mode. • Turn off your headset and press and hold the talk button until the blue indicator light remains lit after blinking. • If you turn it on for the first time, it proceeds into Pairing mode immediately.
2 Search for and pair with your phone --> turn on the bluetooth with the widget on the home screen or in the settings. (Bluetooth PIN: 0000, 4 zeros)
• If the pairing is successful, the blue indicator light will flash 10 times rapidly before entering Standby mode. • If the blue indicator light remains lit, retry pairing.
Mar 13, 2011 | Samsung WEP450 Bluetooth Headset - Retail...
How to pair to the phone
Please follow this procedure:
  1. In the headset press and hold the call control botton until the indicator turns red and then turns off, press and hold the call control botton until the indicator light continues to flash red and blue, the headset is now in pairng mode.
  2. In your phone, go to bluetooth conectivity and select scan for devices, select de Plantronics bluetooth headset from the list, enter 0000 for the passkey and OK/accept to bond them.
Mar 01, 2011 | Plantronics Explorer 240 Bluetooth Headset
Earbud will not connect to lg env2
Pairing will create a unique and encrypted wireless link between two Bluetooth enabled devices, such as your Bluetooth phone and Bluetooth headset.
  1. Ensure that the headset is off (see Turning the headset on/off).
  2. Press and hold the Multi-Function button until the indicator light turns on in blue (approximately 8 seconds).
  3. Set your Bluetooth phone to discover the headset by following your phone's guide. Typically, the steps involve going to a 'Setup', 'Connect', or 'Bluetooth' menu on your phone and then selecting the option to discover Bluetooth devices.
  5. Your phone will find the Samsung WEP200 headset and ask if you want to pair with it. Confirm this by pressing the Yes or OK key.
  6. Enter a passkey or PIN, 0000 (4 zeros), then press the Yes or OK key.
wep200-5.jpg If pairing was successful, the indicator light will flash in blue 10 times rapidly before going to flashing every 3 seconds. If unsuccessful, the light remains on, and you will need to re-attempt pairing.
Dec 04, 2010 | Samsung WEP200 Headset
Trying to connect Plantronic 220 headset to Pantech phone. Can't find the right option on the phone to engage the bluetooth device. I think the headset needs to be flashing red/blue to pick up device and...
1.First switch on the bluetooth in mobile phone.Keep the headset switched off.
2.Now press the call button for 2 seconds if you are paring this headset for first time,If this head set is aired already with another mobile press for 8 seconds until the headset status indicator begins to flash blue then red
3.Now search the bluetooth by your mobile device.It detects and you can pair it
Thank You
Nov 10, 2010 | Plantronics Explorer 220 Bluetooth Headset...
Trying to set up my motorola h350 bluetooth to my samsung s30 phone.
Turn your H350 on by pressing and holding the black "Talk" button on the side of your headset. Hold it until the blue status starts to flash. To turn the H350 off, simply hold the talk button until the headset turns off.
Pair your headset with your cell phone by entering into your cell phone's bluetooth menu--Menu > Settings > Connection > Bluetooth Link > Setup (see Resources below).
Put your Motorola H350 into pairing mode by holding the "Talk" with the device turned off. Hold the button until the status light on the side of your headset begins to flash, and turns back into a solid blue.
Back in your phone's bluetooth menu, choose the option to "Search/Discover" bluetooth devices. And when your phone recognizes your H350, select the headset and enter "0000" as the passcode.
Thank You
Sep 05, 2010 | Motorola Mobility H350 Wireless Headset
Head set not pairing with sony erricson k750i
The solution for paring the explorer 240 is found in the bottom of the product page for the embedded link on the User Guide Link. I have also provided the instructions below. I hope this helps
How to Pair Your Phone With Your Headset for the First Time
1 Turn on the Bluetooth feature on your phone.
For most phones, select Settings/Tools > Connections >
Bluetooth > On. See your phone’s user guide for more information.
2 Turn the headset on.
Turn on your headset by sliding the Power Switch toward the microphone. Wait until the indicator light flashes red then blue.
If you don’t see the red then blue flashes, turn the headset off, then turn it on again. Press and hold the Call Control button until you see the red then blue flashes that indicate pairing mode status.
3 Set your Bluetooth phone to ‘discover’ to locate the headset.
This usually involves going to ‘setup’, ‘connect’ or ‘Bluetooth’ menu on your phone and selecting the option to ‘discover’ or ‘add a device’.
4 Once available headsets are listed, select your headset (for example 2XXPlantronics or 3XXPlantronics). If prompted for a passkey, enter 0000.
When pairing is successful, the indicator on your headset flashes blue. Your phone will also confirm when pairing is complete.
John M
May 06, 2010 | Plantronics Explorer 220 Bluetooth Headset...
H500 bluetooth
AFTER CHARGING headset hold down big button in center of headset until BLUE INDICATOR LIGHT REMAINS SOLID BLUE
tHEN TURN THE BLUETOOTH OPTION ON YOU CELL ON
GO IN TO MENU UNDER BLUETOOTH OR CONNECTIONS SELECT ADD DEVICE YOUR CELL WILL SARCH FOR DEVICE WHEN IT FINDS IT THE NAME OF THE BLUETOOTH WILL APPEAR ON DISPLAY CELL WILL THIS ASK CONNECT OR BOND WITH DEVICE SELECT YES IT CELL WILL ASK FOR PASSCODE PUT IN 0000 THEN AFTER THIS BLUETOOTH HEADSET SHOULD START FLASHING INDICATING HEASET HAS CONNECTED
Dec 31, 2007 | Motorola Mobility H500 Headset
Status light
Hi twistedgurl
When the headset is on, hold both volume keys down for approx 3 to 4 seconds and the light will go off, do the same again and it will come on again.
Tripple M
Sep 22, 2007 | Motorola Mobility H300 Wireless Headset
Motorola Mobility H350 Wireless Headset Logo
64 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis Webber
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
