Question about Measuring Tools & Sensors
Ideal Vol-Con Xl Voltage/Continuity Tester: Where the heck is the "encapsulated screw on the b...
Where the heck is the *encapsulated screw on the bottom of the base* so that I can change the batteries??
  • 299 Answers
Encapsulated means that it won't drop out of the shell when you loosen it. There should be a screw that loosens so you can change the battery.
Posted on May 03, 2010
How do you replace the batteries
Staight from the manual:
• Remove test leads from tester.
• Loosen the encapsulated screw from the
bottom of the case.
• Remove battery cap.
• Replace the batteries with (4) new 1.5V
button-type batteries (IDEAL# 61-201,
IEC #LR44, or NEOA# 1166A).
• Replace battery cap and re-tighten the
encapsulated screw.
http://www.idealindustries.com/media/pdfs/products/instructions/nd-3401-2_61-085-086_instructions.pdf
Feb 10, 2011 | IDEAL Industries #61-085 Vol-Test Voltage...
Nesecito comprar un tester ideal No.61-076 presio y como lo actengo pleas
Tu puede comprar lo a Amazon.com:
http://www.amazon.com/Ideal-61-076-Vol-Con-Tester/dp/B000BVKUSA
Questa cincuenta y cinco dollars.
Buenas suerte!
Jan 19, 2011 | IDEAL Vol-Con Xl Voltage/Continuity Tester
I cant find where the batteries are located on my IDEAL voltage tester #61-085
The #61-085 does not have batteries. (It does not test for continuity) The #61-086 does have batteries.
1. Replace batteries when touching the leads together no longer lights the continuity LED or produces an audible sound. 2. Remove test leads from tester. 3. Loosen the encapsulated screw from the bottom of the case. 4. Remove battery cap. 5. Replace the batteries with (4) new 1.5V button-type batteries (IDEAL# 61-201, IEC #LR44, or NEOA# 1166A). 6. Replace battery cap and re-tighten the encapsulated screw.
Here is the link to the complete manual. http://www.idealindustries.com/media/pdfs/products/instructions/nd-3401-2_61-085-086_instructions.pdf
If you have any other questions, just ask. Don't forget to rate this answer.
Jan 10, 2011 | IDEAL Industries #61-085 Vol-Test Voltage...
Need to change a motor. The leads are not marked . How do determine which leads go where on the new motor ?
Without motor info, Brand, hp, voltage i could not say for sure, but white wire is neutral, black is hot and 220 volt red is hot also. should be wiring diagram on motor or back of connection plate
Dec 23, 2010 | IDEAL Vol-Con Xl Voltage/Continuity Tester
How do u change the batteries On a vole-test xl
there is a small clip at the back push both side in at ounce and the back will come away
best of luck
merry christmas
Dec 07, 2010 | IDEAL Vol-Con Xl Voltage/Continuity Tester
Voltmeter trips GFCI
I think this is normal for a GFCI.
May 01, 2009 | IDEAL 61-086 Vol-Con XL Solenoid Voltage...
Measuring Tools & Sensors Logo
149 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
