WM1814CW Front Load Washer: my machine is leaking, i been told that that part ...
My machine is leaking i been told that that part is called water selenoid is that right?
    Guru:
  • 351 Answers
Yes that could very well be your problem . is there water leaking under the machine?
Posted on May 03, 2010
How do I put hose back in behind lower cover cap? pulled completely out when attempting to drain hose & clean the pump filter.
Go to www.youtube.com and enter
LG WM1814CW
Into search bar on youtube.
You will see various videos on How To Fix your exact model washing machine. :) x
Nov 17, 2014 | LG WM1814CW Front Load Washer
Water is all over the floor from the washing machine. What could be the problem
water pump, hose or tub.. depends when you noticed water. After it was filled? during draining or filling? Also a clogged drain will cause backwash. Holes in tub from rust will leak out water, water pump cracked can leak water or hoses to drain or to washer not sealed or cracked. Overfill from a faulty fill valve can also do that, but then you'd see lots of water all obver on that one.
Jun 16, 2010 | LG WM1814CW Front Load Washer
LG WM1814CW Front Load Washer rubber seal on front door collects water underneath and now has black mold, and a strong odor, like cigarette smoke.
Use some detergent plus baking soda and mix it in with the water--rub it around (with an old toothbrush) to loosen the mold. Let sit for a while, then wipe water, mold, and cleaner away. Finally, rinse with clean water and wipe dry. Leave the door ajar to air out after each wash. It will help to remove the standing water each time. Don't poke a hole in the seal to drain the water out, because water will then run out of the bottom of the washer.
Sep 28, 2009 | LG WM1814CW Front Load Washer
Water leak from the top rear inside
You do need to; probably one of the pipes has come loose, can be re-fitted or replaced if broken.. Simple fix.
Mar 16, 2009 | LG WM1814CW Front Load Washer
Washing machine leaks after pipes froze in room
The problem is most likely the water pump and supply hoses.
If your system froze up where the washer was located then it is possible that the pump or supply lines also froze because they always have water in them.
The repair price will vary with whoever you call to fix it.
Jan 29, 2009 | LG WM1814CW Front Load Washer
Water keeps running in
You have a jammed open water valve in the machine and it will need to be replaced.  Call a qualified LG technician to service this problem.
May 25, 2008 | LG WM1814CW Front Load Washer
Cold water will not shut off even when washer is off.We left unit unpluged over nite and still have same problem LG washer # wm1814cw overfills
You have a stuck cold water solenoid valve.
Try openning the machine and tap on the cold solenoid valve.
If this dowes not work, you may have to replace the valve.
Mar 25, 2008 | LG WM1814CW Front Load Washer
Washing machine wm1814cw
Check the wire ring that goes around the rubber seal located just inside the door - we had to call a repair person out one day because our door was leaking, and he told us it's important that the spring be at the top of the door opening to prevent leaks from happening. He had a hard time moving the spring to the top but that seemed to help.
A few months later we found a water leak from our soap tray, so we had the tray replaced under warranty, although I'm not sure that helped because the replacement looked identical to the old one. It only leaked when we used powdered Oxyclean and liquid soap in the tray at the same time; the leaking water ran behind the front cover and dripped out onto the floor all along the front of the machine, mostly near the left corner, but we stopped putting Oxyclean into the tray & the problem stopped. Hope that helps.
Feb 05, 2008 | LG WM1814CW Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
