Question about Dell Dimension 5100 (D51L1) PC Desktop
CD Drive problems
About a month ago when they would click on the cd drive d they would get the message D:\is not accessible, and I can click on e drive and it comes up with a blank white screen, but doesn't see the information. I thought it was spyware / virus, but after I removed all of them it still has the problem. I even tried replacing the cd drive and cable. That did not fix it. I booted in safe mode and d drive worked and e drive gave me the error message. I rebooted and was looking at the properties and then I clicked on the drive and it worked. So I put a different cd in it and it did not work. Now when I put a cd in the other drive and click on it, it will come up with a blank screen like it does not see anything, but it might show up as seeing something after 5 minutes 30 minutes or an hour. One thing I notices when I replace the cd drive was on the motherboard it had several capacitors that had a slight bulge to them like I have seen when the motherboard was going out, but this doesn't act like that. I was looking at the properties on d drive and I clicked on the volume tab and clicked on populate and I hear the drive start to spin. I clicked the drive and it works I can see the information and open up the file, but when I put a different cd in or reboot I have to go through the same process. It works on both drives. Now I need to figure out how to fix it where I don't have to do that and it works normal. I can receive CD information but I can not send to CD or "A" drive to a disk. I get an message saying it is not accessible. How do I fix it. I have tried to reset my drivers and it goes to the C drive. In the settings, I have a check mark by auto network notification and DMA. Should I check the sync data transfer also?
  • 2 more comments
  • Otisandme Mar 26, 2008
    Please give me step by step instructions on how to fix my cd and a drive problem. I checked in device manager and updated driver and it shows a path to the d drive but excepts it in the c drive. It shows the hardware version not available but is working properly. What does that mean? I can get info from these drives but can not send anything to the drives.
  • Otisandme Mar 27, 2008
    CDROM - cd-Rrom drive and floppy disk controllers - standard floppy disk controller. I have a dell dimension resource CD to run a diagnostics on my system but I don't know enough about it to run the test. However, I did read that drives can be pushed from one drive to another and is fixable. It sounds like if I werre smart enough to run the test, I could fix the problem. Please help with exact step by step instructions and maybe I can fix it. Thanks.
  • Dave MacPhee
    Dave MacPhee May 11, 2010
    In device manager, and in the driver file details, what is listed? Please be specific.
  • Dave MacPhee
    if you disable one of the drives in the bios, does the other work ok? Also, make sure all drivers are up to date. Does the device status in the properties dialogue box show any errors? In the device manager, are there any errors beside the drives?
  • 236 Answers
To run the dell diagnostic from CD, do the following:
Insert your Dell Resource CD into the CD or DVD drive.
Turn the computer off.
Press the Power Button to turn the computer back on.
Press F12 once every three seconds until the message Preparing one-time boot menu or the Boot Device Menu appears.
Press the Down arrow until CD/DVD/CD-RW Drive is highlighted, then press Enter.
Press the Down Arrow until Dell Diagnostics is highlighted, then press Enter.
Press the Down Arrow until 32-bit diagnostics is highlighted, then press Enter.
Posted on Mar 28, 2008
    Master:
  • 518 Answers
I'm wondering about the Master/Slave jumpers on the 2 units. On any ide cable that has 2 drives (CD, DVD, HD)... one must be jumpered as Master and the other as Slave.
Hope that helps...
Geno
Posted on Mar 26, 2008
D drive is my CD writer drive. when I try to access the D drive I get the following message. D:\ is not accessable. The drive is not ready
make sure that the cd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
Nov 19, 2010 | Gateway (5500381) CD-ROM Drive
This is crazy.. i am copying songs from cd's to my daughters mp3 player..all of a sudden i put in cd then went to my computer and doubled clicked on the cd player and i get this message "windows...
why not try it some other way? :-)
1. put the cd in the drive and go to My Computer and right-click on it & select the Open or Explore option. you should be able to see the contents of the drive and you can copy and paste wherever you lke.
2. if that does not work - create a temp folder on the desktop. now go to Start -> Run and type in"cmd" and hit <enter>.
now type in "C:\" and hit <enter>
if the cd drive in your computer is, say D drive - then type in "D:" and hit <enter>
you should be able to see the contents of the drive and use the "Copy" command to copy it to the temp folder in the desktop from where you can copy it to your daughters mp3 player.
Nov 19, 2010 | HP Pavilion dv4000 Notebook
Computer does not recognize it as a CD RW drive
When you try to write data to an optical disc, you may experience any of the following symptoms:
* You receive various disc write error messages.
* You experience issues with the drive and the built-in recording feature of Windows XP.
* You experience issues with third-party programs that you use to write data to the disc.
* You cannot read the disc in all versions of Windows.
* You cannot read the disc, or some files on the disk, by using an MP3 player.
* When you add files or folders to a disc that already contains data, some files are lost.
* Recording files to the disc is inconsistent.
* The disc recording operation is consistently unsuccessful.
TROUBLESHOOTING
Troubleshooting specific errors
If you experience one of the following errors, follow the appropriate steps to resolve the error.
* There is no disc in the drive. Please insert a writable CD into drive.
This error can occur if the CD-R drive or CD-RW drive is not recognized as a recordable device. This error can also occur if the device driver has been corrupted. To resolve this issue, see Method 3 in the "General troubleshooting" section and Method 1 in the "Advanced troubleshooting" section.
* Drive not accessible, incorrect function
This error message typically occurs when you try to write to a CD-R or a CD-RW, and the Windows XP built-in disc recording feature does not recognize the CD drive as a recordable drive. This error message may also occur if specific third-party programs are installed. For more information about how to troubleshoot this error,
when you access the CD-ROM drive, the DVD-ROM drive, or the CD-RW drive
* Error Deleting File or Folder.
Cannot delete file name. Files on this CD-ROM drive are read-only. You cannot copy or move files over to this CD-ROM drive.
This error message can occur because individual files cannot be deleted from the CD-RW. You cannot use the CD disc recording feature of Windows XP for random-access storage while you are writing to disc.
To set the service to Automatic, follow these steps:
1. Click Start, click Run, type services.msc /s, and then click OK.
2. Double-click IMAPI CD-Burning COM Service.
3. Under Service Status, click Start.
4. Try to write data to a CD.
Jan 28, 2010 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
How to do a system recovery when my cd rom drive doesnt work?
got to have a new cd-rom drive mate, most practical approach.
other options are network boot (done in offices with many computers), USB boot (if your BIOS supports it & you need to have a USB device with the bootable image of the system disk), etc.
Jan 26, 2009 | Computers & Internet
"D:\ is not accessible" message
If the cd is in the drive then you have a problem with the drive itself. It might work on a cd but won;t on a dvd. That indicates the heads have gone out of alignment.
Usually means you need to replace the drive.
Jan 06, 2009 | Toshiba Satellite R25-S3503 Tablet PC
Laptop CD/DVD Drive
I think buying a USB DVD drive is a very sensible idea as internal drives on laptops can be a pain to remove and fit and they are more prone to failure than their desktop brothers because of their flimsy construction.
Jan 01, 2009 | HP Compaq Presario V6000T Notebook
Laptop CD/DVD Drive
Hi RC2935
Try this and see if it will help you
Here is what you do  Click on start and then go to run type in regedt32 For Vista Click start and search for regedt32 and click on it
Go to the following HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Delete the upper and lower Filter or witch is available close window and restart the PC it will work
This is common on the Acer, HP,Toshiba etc,etc
if you need help let me know
kind regards mervin
Sep 24, 2008 | Computers & Internet
Computer says cd blank but it has data
try cleaning your cd or dvd drive and then clean your CD with brasso or shampoo without scraching it with soft hand.
wipe the cd in outwards direction from the center
gud luck
bye
Nov 20, 2007 | Compaq Presario Notebook
DVD/CD combo only reads DVDs
The virus and the Disck drive problem are not related. The disk drive has two lasers- one for CD one for DVD- one of the appears to have failed. Get hold of a CD drive cleaner. - this is a disk with a little brush on the underside and a bottle of fluid. try thats first. If that does not work then it is a new drive- unless you are happy to read only DVD's
Sep 20, 2007 | HP Refurb HP Pentium M 1.7GHz 512MB 40GB...
Dell Dimension 5100 (D51L1) PC Desktop Logo
87 people viewed this question
Alun Cox
