Question about Brother MFC-3240C All-In-One InkJet Printer
Magenta doesn't print
All the other cartridges seem to print (test print) except the magenta. I've tried cleaning numerous times - to no avail. There's magenta ink in the cartridge - just doesn't want to print magenta.
What's wrong? Is there a LED level indicator that could be faulty? How can it be replaced if this is the case?
I'm in Toronto Canada - suggest a supplier?
T U
Rick
    Scholar:
  • 141 Answers
Many printer have a problem with the magenta cartridge...The better way to solve your problem is to replace it again...if you know someone that have the same printer as you or a reseller who will be very nice to try one of is own!!!! After that you will be able to go futher in your search...
Posted on Mar 26, 2008
SOURCE:
I have a NX400 with just the Magenta head clogged. I have run the normal (preset maintenance numerous times to no avail. I get a clean, proper print with the other heads. I believe that a disassembly of...
Before you take drastic measures, please do things that don't damage your printer. It could be there is just a drop of air in your printer system.
Remove the Magenta cartridge as told in the manual. Then put a drop of cleaning fluid in the little pipe you see in the bottom of the cartridge holder. then try to run a cleaning stage. If it won't run without a cartridge, it would be ok to put a empty one in. After some cleaning run's and a adjustment run, you than can place the new cartridge. Be sure you removed the sticky tape under the cartridge, and always before placing a new cartridge, when it is still in he plastic bag, shake the cartridge. Never shake without the cartridge in a bag!! because the ink will be overall in your place ant clothing.
Oct 24, 2013 | Epson Stylus CX6400 All-In-One InkJet...
Doesn't print magenta?
It appears the magenta print head nozzles are blocked.
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Apr 06, 2013 | Kodak ESP Office 6150 All-in-One Printer
Brother DCP-350C magenta ink won't clean and print quality check shows multiple visible gaps
You have a blockage in the print head and/or feed line from the ink cartridge to the print head. One possible fix would be to make a pad of paper kitchen towel wet it and sit the print head on it overnight. With luck the pad will soak the blockage and draw ink through the head. Give the machine two self cleans and try a print quality test to see if you have made ANY improvement. If no improvement - forget it as the blockage has been there too long.
Oct 30, 2017 | Brother DCP-350C InkJet Printer
The lt magenta and magenta just quit printing between pages
1. Check if the cartriges are correctly installed:
Installing the Ink Cartridges
2. Print a diagnostic page and clean print heads, using the printer cleaning utility:
Color Mix or Missing Colors on the Diagnostic Page
Repeat if needed.
3. If this still doesn´t solve you problem, try resetting the printer and manually cleaning the cartrigdes as advised in this FAQ:
Ink Cartridge is Missing, Incorrectly Installed, or Not Intended for Your Device' Error Message is Displayed on the Printer
Sep 06, 2009 | HP Photosmart C6180 All-In-One InkJet...
MAGENTA NOT PRINTING
The other week I had the black print head clog up, requiring daily nozzle deep cleaning [a normal 'ocassional' maintenance function]. Thought I needed a new Print head, so anything worth a try.
I loaded up an old black cartridge [I load all my own......always have] with Isopropyl Alcohol and ran deep clean on that cartridge a couple of times, then repeat printed [6 times] a page full of the number 8 in about half inch character size, to get the alcohol through the nozzles. then Deep cleaned again 3 times, to wash it through the print head.
I reloaded the normal ink filled cartridge and ran the '8' page again till I got good black output. It has now been working without problem, daily, for over a week. Clearly if it's a Magenta only problem, the cleaning as described above would be a bit different, as the magenta is one of 4 colour cartridges.
My printer does quite a lot of work, and was bought at least a couple of years ago, being used daily for alpha numeric and photo printing work. This was the first difficulty I experienced with it.
Hope the above might help.Ken
May 21, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Will not print Magenta
it seems that your cartridge nozzle is dryed out u can try to clean via the hp tool software or via the menu on your printer if that not works try a new one and if that is not working than call hp for support
Dec 17, 2008 | HP Photosmart 3310 Printer
Magenta won't print
nope..this is a clogged line issue, and unless you have the time, technical skills, and patience, this is best done by someone that gets a charge from taking apart printers...
Jun 07, 2008 | Brother DCP 130C All-In-One InkJet Printer
My magenta will not print well
Here's what you should do. Remove all ink cartridges. Get some rubbing alcohol, preferrably 91% proof (leaves less moisture) Get a couple normal paper towels. Check each cartridge for dried ink and remove it using an alcohol wetted paper towel. (The deep cleaning procedures aren't always effective.) The gold contacts on each cartridge should be gold when you are done. Use the same procedure on the gold contacts of the ink cartridge housing inside the printer. Take your time, do it well. If that does not fix the problem, then do the following. Switch the black and magenta cartridge. Some printers won't print when you do this, other printers don't know the difference. If your printer is the later, then attempt a print job using a page that has a line of both black and magenta text. If you see a black print, then the problem is your magenta cartridge (despite having installed a new one) If the magenta prints, then you know the magenta cartridge is good. If the magenta prints but the black doesn't, then you have a printer failure. Let me know your results. ZT3000 Beta tester of "0"s and "1's"
Aug 18, 2007 | Canon i860 InkJet Photo Printer
Magenta printing as yellow
Well, first off, are the alignment, and nozzle check sheets looking good? If not, then work on that. If so, then we have a problem. Try creating a test sheet in Word. Make red, yellow blue & black text and see if anything else prints wrong. Get back to me!
Jun 19, 2007 | Canon PIXMA IP5200 InkJet Photo Printer
Brother MFC-3240C All-In-One InkJet Printer Logo
130 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
