- A045 Wide Format Copier Copier: i have a code sc508-00 on a gesttener a045 its bas...
I have a code sc508-00 on a gesttener a045 its basicaly the cutter unit the wire that makes the cutter go back and forth is broken i was told i have to buy a whole new cutter unit for 750.00 does anybody know if i can buy just the wire
  • 1,219 Answers
You can try to go to hardware store and take the sample with you and try to find the similar one. Its most cheapest way.
The best solution would be a new cutter assy.
Pls. rate
Posted on May 10, 2010
I think the switch on my petrol cutter is broken how do I replace the switch on my makita cutter
Dismantle the unit, taking photographs as you go and verify that the switch is actually broken (electrically or mechanically). Gain the make and model number of the switch and purchase a new one. Online is probably cheaper. Refitting is the reversal of the dismantle. Cheers Bob
Oct 16, 2016 | Makita Saws
What is a double wheeled pizza cutter?
a double wheel pizza cutter is a pizza cutter that has 2 wheels - one behind the other. The advantage of the two wheels is that they go through the pizza in one motion and you don't have to go back and forth to get a clean cut through the pizza.
Feb 28, 2013 | Home
We purchased a Gestetner A045 7 years ago. We are now upgrading to Windows 7 and we have been told that it would be best to get a new plotter because the plotter is not compatible with Windows 7 64 bit
if you search google for the plotter model and it will let you download a windows 7 driver cos i just looked and there is one, try this:
http://www.driverplatform.com/file_a045.html
Jan 23, 2013 | Gestetner A045 Wide Format Copier
Riso rz 220 the code A17 209 continues to come up
Hello
Yor cutter unit is not in the home position.
Open the front door, take out the master unit, remove the master material, lift the green handle and look to see if you can see a white plastic knob (that is the cutter) make sure it is to the front of the machine, if its to the back of the machine very carefully move it forward until it wont move anymore.
If it is in the front of the machine then the microswitch is probabally faulty and will have to replace the cutter unit.
Regards
May 18, 2011 | Riso RZ220 Duplicator
Go to start cutting and the safty light comes on and shuts the unit down. What am I doing wrong?
Make sure the ground is attatched and its completing the circuit. i had the same issue with mine and the ground wire was broken inside the rubber sheathing..
Dec 02, 2009 | Lincoln ELECTRIC K1756-1 PRO-CUT 25 PLASMA...
Miller Spectrum 375 problem
It sounds like you have a problem in the power supply input area. Make sure your voltage select switch is in the correct location. Unplug the unit and switch back and forth between the two positions to clean the contacts. Try again. If still bad check you terminal lug connections on the input lead wires. If still bad please answer these questions.
Does the power indicator come on at all? Does the fan start?
Nov 12, 2009 | Miller Spectrum 375 Cutmate Plasma Cutter...
Help my A045 Gestetner will not load paper after several short beeps
If you are changing a paper roll, make sure you can advance the paper through the "throat" using the green knob and then manually trim it. If you are loading paper in the cassette tray, make sure you adjust the green sizing guides to match the paper dimension (8.5x11", 11x17), etc.
Mar 27, 2009 | Gestetner A045 Wide Format Copier
Motor runs both forward and reverse, but cutters don't turn
How about a hidden 7th screw? If you look at the sticker on the underside where the bar code is you may see a dimple like there is a hollow space under it. If you can't see it, rub your finger over it to find the hole. Just stick your phillips screw driver through the sticker to get access to this last screw. As for the motor working both directions but the cutter doesn't turn it is most likely a broken nylon cog on the drive gears within the white plastic housing at the end of the shredder. There are 3 or 4 gears - all nylon (plastic), my unit had one tooth completely broken off and the one next to it was worn. I am looking into finding parts but I'm not having any luck so far with local service centres. I have a call into the fellowes main 1-800 number to see if they can help. On reviews I have seen this is a common problem. One reviewer was told they use nylon to reduce noise, but of course it isn't going to last long, especially if you ever jam. Nice metal cutters but the weak link is the drive gears that you can't see.
Oct 16, 2006 | Fellowes P600C-2 Shredder
107 people viewed this question
k24674
jasbo
jasbo
