Question about JVC AV-48WP30 48" Rear Projection Television
JVC HD-70FH97 cobwebs behind screen
    Problem Solver:
  • 4 Answers
Take it apart and clean it....the screws are all easily located - avoid using any ammonia based cleaners and paper towel. Ideally - score some cleaner for glasses and the silk-like "hankie" to clean everything up. I bet the lenses are dusty and gross too....
Posted on Apr 10, 2008
SOURCE:
I have a JVC HD-70FH97 hooked to my digital box, via HDMI cable, and connected to the TV HDMI input 1. I cant get my surround system to work - any ideas what im doing wrong?
Check your HDMI audio settings. It may be trying to send a signal that is incorrect. How is the wiring setup? cable box to stereo, then to Tv?
Sep 21, 2016 | JVC HD-70FH97 70 in. HDTV Television
JVC HD-52Z575 tv shows only a grey picture screen. I was watching a channel and tried to change channels and new channel won't come up, only grey screen.
JVC HD-52Z575 52" HD-ILA HDTV-ready rear-projection TV
www.amazon.com/JVC-HD-52Z575-HD...HDTV.../B...
Amazon.com, Inc.JVC HD-52Z575 52" HD-ILA HDTV-ready rear-projection TV ... The picture was artifacted and the color was good, but not great. ... From 5' some minor issues could be seen and the MPEG2 format did show its limitations, but at 10', it was a truly great experience! ... There is no true gray temperature, only high and low.
HOW TO FIX A JVC HD BIG SCREEN TV - YouTube
? 6:38
https://www.youtube.com/watch?v=r4v-xzUpQDM
Apr 11, 2012 - Uploaded by kyle dubb
Did your HD D.L.P. t.v. stop working? This movie clip will showyou step by step how to easily fix your big ...Missing: grey
JVC HD-52Z575 HD-ready rear-projection D-ILA monitor ...
Jan 10, 2016 | JVC Televison & Video
Jvc television no sound
There are to components to be suspected. Its speaker, and audio output IC. If speaker has any internal disconnection occurs, to its voice coil connection braid wire, the said fault can occur intermittently. If the audio output IC's contact between its heat sink has a screw loose, it will overheat after some time, and will shut down. It will work, after some time the set has been switched OFF. If there is any loose solder terminals to the audio output IC, this fault can occur. Just check these.
May 28, 2013 | Televison & Video
Cobweb behind the screen.
You can try and use a air compressor or canned air and blow inbetween screen and protective cover and see if that removes the cobweb. Give that a try and let me know if that works for you.
Good luck... HDTV GURU JAY
Mar 14, 2011 | Televison & Video
LENS CLEANING
A warm soft cloth like a t-shirt. Not soaked and wipe gently up/down. Slow process but cheaper than the screen..
Nov 26, 2010 | JVC HD-70FH97 70 in. HDTV Television
Mitsubishi VS50609 has cobwebs behind the ribbed screen and I need to know how to remove the ribbed screen, I already removed the clear cover smooth cover. Sandy
set should have the clear screen cover (protective) and two more screens behind that. Easy way is to unplug set and remove back cover--cobwebs are usually behind on inner screen.
With the back off I use a swiffer like duster and reach up and get them all out--gently on the inside of the inner screen so you do not scratch or mar it.
If this helped you rate this solution as I do this here for free.
SD TECH
Dec 09, 2009 | Mitsubishi VS-50609 50" Rear Projection...
Fuzzy blob on JVC Model # HD-56G787
my bulb went out in my 56" jvc hd-56g787 and i need to change it! i have a new buld how do i get to the bulb to change it?????????? thx jimmy
May 26, 2008 | JVC HD56FH96 56" Television
Cleaning JVC rear projection screen (behind cover)
You will have to do some dissassembling of the cabinet to remove the screen and bezel assembly. If you are will to do this I can give you the directions.
Mar 22, 2008 | JVC AV-48WP30 48" Rear Projection...
JVC AV-48WP30 48" Rear Projection Television Logo
189 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
