Hi, My tub drips water slowly and constantly.This started after I had a
city water main line coming into my home repaired.
I thought I had flushed out any sand that might have gotten into the
washer intake lines.Can I clean it or do I need to replace the water inlet
valve? If I need a new valve can you supply the part number and supplier?
It is a Kenmore Elite Quiet Pak 1 topload washer Model 110.26942503.
Also, is there a website where I might download a schematic or manual in
in a pdf file?
Re: Kenmore Elite Quiet Pak 1 Model No.110.26942503
Yea if valve is leaking into machine when not on youll need to replace the valve. part number for the inlet valve 3979346 . you can find a diagram as well as a part list at sears.com.
This is symptomatic of a malfunctioning water control valve- not closing fully- the hot water one, if the washer is hot and cold fill, and the cold one if it is just cold fill!
Sorry but it needs replacing and a service call ;-0(
Good luck,
John C
You are getting moisture in the control panel buttons. After a while the panel will not function at all. The light in the dryer tub will still come on when the door is open. When you unplug your machine and it sets for awhile you are allowing the moisture to dry and the machine can reset. Some people use a hair dryer to dry out the control panel for a temporary fix. Eventually, you will have to get it replaced once it stops resetting for you.
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
