Question about Canon PIXMA Pro 9500 InkJet Photo Printer
Canon PIXMA Pro 9500, (service error 9100)
Canon PIXMA Pro 9500, I have just changed an 2 ink cartages, now all I get is (service error 9100). Nothing happens but amber light and blue light flash, there is 10 flashes each with the blue light on for 2 seconds between.
SOURCE: Canon Pixma MP150 Error code E 42
Had exact same problem. Scanner light should come on at power up. Found ribbon cable connecting scanner unit to base had come unplugged from socket on circuit board. The ribbon cable is one of three found near back hinge of scanner and is hidden underneath the other two. It should drape over the edge of circuit board and then plug into small recepticle on inner side of board. I plugged it in and printer works again. Hope this helps.
Posted on Mar 11, 2008
SOURCE: e5 erron on canon pixma mp160
E5 is your problem,i also encountered that problem w/ my pixma mp 160,all you have to do change your cartridge w/ a new one,thats all...in case E5 does'nt resolve contact this no. 374-7103 to 04,coz they were the one who fix my pixma...thanx -----pilippines,antipolo city--------
Posted on Oct 11, 2008
Dipu007
  • 2110 Answers
SOURCE: reset ink level for printer canon pixma ip1980
http://indoresetter.blogspot.com/2008/12/resetter-printer-pixma-ip1980.html
go to this link and download resetter......
Posted on Jan 08, 2009
ihavsolution
  • 152 Answers
SOURCE: How to change the ink in a Canon PIXMA MX310?
  1. Make sure that the machine is turned on, lift the Scanning Unit (Printer Cover) with both hands, then pull the Scanning Unit Support (A) down into place.
  2. Take out a new cartridge from its casing and gently remove the orange protective tape in the direction of the arrow.
    Note: - Do not attempt to reattach the protective tape once you have removed it.
    - Do not touch the gold electrical contacts or the print head nozzles after removing the protective tape.
  3. Insert the ink cartridge into the ink cartridge holder.- Black: the left slot- Color: the right slot*
    *One black cartridge and one color cartridge must be installed in the machine in order for the printer to operate. It does not matter if the capacities (Standard or High) do not match.
  4. Push up on the front of the cartridge until it locks into place. (A click sound will be heard when the cartridge is locked in place.)
  5. Confirm that the ink cartridges are installed properly.
    <1> The ink cartridge is not installed properly.
    <2> The ink cartridge is installed properly.
  6. Fold the scanning unit support and close the scanning unit (printer cover).
  7. Wait until the preparatory operation is complete; it takes about one to two minutes.
Removing Ink Cartridges:
  1. After confirming that the printer is powered on, open the scanning unit (printer cover). The ink cartridge holder moves to the replacement position.
  2. Press down on the semi-circular tab to release the cartridge and then remove it.
    Note: Handle the ink cartridges carefully to avoid staining clothes and surrounding work area.
  3. Remove and replace each cartridge individually. Or, remove the second cartridge after the first has been removed.
  4. Fold the scanning unit support and close the scanning unit (printer cover).
Posted on May 27, 2009
Andrew Tung
SOURCE: printer error
How to bypass the Alarm for Cano pixma MP198
Posted on Jun 15, 2009
I have a Canon pixma pro 9500 mark 11 printer and the ink absorber is Full .. Please please help I need the reset code to reset counter on printer .. I would be so very grateful thanks
Dear
Resetting the waste ink absorber on a Canon printer can resolve some error codes that appear when turning it on. Make sure the printer is turned off. Press and hold the Resume button (triangle inside a circle). Whilst it is held down, hold down the Power button. The green led light should come on. Keep the Power button held down. Release the Resume button and then press it twice. The light should go amber, then green again. Release the Power button. Press the Resume button four times and then press the Power button straight after to confirm the selected action (Reset Counter Absorber). Turn off the printer and then turn it on again
Thanks.
Feb 07, 2015 | Canon PIXMA Office Equipment & Supplies
Canon pixma pro9500 mk2. error code b200. printhead problems. cannot access printhead, because it is locked in resting position due to error code. how do i get it to the middle? thanks!
PIXMA Pro 9500 MKII Error B200 = VH (Print Head Drive Voltage) is out of the specified value.
Need to :
- Replace print head and logic board at the same time.
or
- Replace Carriage Unit
or
- Power Supply Unit
Aug 17, 2011 | Canon PIXMA Pro 9500 InkJet Photo Printer
CANON PIXMA MP490 ERROR CODE IS 5200 AFTER INSTALLING NEW BLK INK..........
canon mp490 error 5200 solution...... turn off printer,then hold reset button(the red 1 circle with triangle in middle) for 5 sec then whilst holding reset button turn power on let go of reset button then push reset button twice whilst still having hold of power button then release power button then push reset button 4 times and then power button twice hope it works it did for me carlos:)
Jul 30, 2010 | Canon PIXMA MP490 Inkjet Photo All-In-One...
What does error code 5C00 mean (Canon Pixma 9500 Mk1)
thats code indicate that your refill ink pad full, you need to replace that pad, buy replacement from canon supplier.
Apr 09, 2010 | Canon PIXMA Pro 9500 InkJet Photo Printer
Suddenly it wont priny black, have tried to replace with i new. Paper is offcourse removed, but it wont print black. Have run all cleaning programs. Could it be under the ink tank? How can i get to it?
Maybe you need new black ink cartage, or new color if its one pint cartage. follow the procedure under the bonet to change the ink cartages,. hope this helps
Nov 30, 2009 | Canon PIXMA iP8500 InkJet Photo Printer
When printing, the only thing that prints are lines in red or blue, the black wording does not show up, help
first clean the cartage 2 or 3 times, if it still doesn't print change the cartage. its out of ink or its hardend and wont flow ..
Jul 02, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Canon Pixma 9500 suddenly starts producing light prints
I'm not sure if this is possible with the 9500 (it won't be if the 9500 uses chipped cartridges)...
But have you installed the photo version of a Magenta or Cyan in the Non-phone cartridge... ie: PM instead of M, or PC instead of C.
It's a long shot as I don't know that particular models age, etc... but it's been done (by me included *blush*).
Feb 16, 2009 | Canon PIXMA Pro 9500 InkJet Photo Printer
Ink cartage
This printer will take either the PG-30 or PG-40 (larger size) cartridges for black ink, and either the CL-31 or CL-41 (larger size) cartridges for color ink.
Jul 26, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Canon ip2000 service error 5100
I have been facing same error and this was the solution.
Canon Error 5100
Sep 08, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Canon PIXMA Pro 9500 InkJet Photo Printer Logo
817 people viewed this question
old marine
old marine
