Question about Saniflo 013/003/005 Sanibest Toilet with Grinder Series Pump in White Round
Pump murmers now excessivley noisy
Have check all pipe work for blockage and cleared
have stripped down unit and cleaned tested pumping action outside and works
replace unit in confined space, pumps but excessivley noisy
would this just be a pump fault that now cleared is just ready for replacement is there oil storgae for the motor
  • 43,501 Answers
The best thing would be to just replace the whole pump... once they start giving trouble you will always have trouble...
the noise is either something bent or the motor has a bad spot in the windings...
heatman101
Posted on May 04, 2010
Our Proline Logic dishwashers arms (rotars, whatever you want to call them) aren't spinning, therefore nothing is coming out clean.
Hi I should check the waste filter in the washer first to see its not blocked as the water pressure pump cannot spring into action unless the water sump is empty first there's a sensor that tells weather there's still water in the system that has to be expelled first, also check the water outlet pipe to make Shure its not blocked, try blowing down the pipe to see if its free, if you cant blow down it then there's a blockage, possibly a blockage in the expel water pump that needs to be put write first or maybe the pump has failed(burnt out)then if you are competent replace the pump. I hope that helps don't forget to unplug the mains lead first
Nov 15, 2017 | Dishwashers
Coffee won't come out of the machine, tried cleaning out the tubes but that just made it worse
You need to advise the model .. but assuming its the CVA 40XX series ... the frist thing to check is the dispenser which has the two pipes comming out of the bottom. This can get coffee residue build up which usually causes 1 or both pipes to have reduced coffee flow. Indication that this is at fault are if the flow is uneven between the pipes or if coffee flows down the outside of dispenser. You can chck this pipework for blocages by openeing door and blowing air though the pipe extending on inside of door. The the dispenser is blocked you need to remove from rear of door and then clean out thoroughly in running water. If this pipework is not and
You need to advise the model .. but assuming its the CVA 40XX series ... here is what I would do;
1. First check is the coffee dispenser on front which has the two pipes coming out of the bottom. This can get coffee residue build up which usually causes one or both pipes to have reduced coffee flow. The indication that this is at fault is if the coffee flow is uneven between the pipes or if coffee flows down the outside of dispenser. You can also check the dispenser for blockages by opening door and blowing air though the pipe extending on inside of the door. The air should flow through easily. If the dispenser is blocked you need to remove from rear of door and then clean out thoroughly in running water.
2. Next check the pump and water path. The pump for the coffee is also used for producing hot water. So if the hot water is working normally then you can rule out the pump. If you not getting hot water then its likely to be the pump or a blockage in the flow through water heater.
3. If above OK then it's a fault with Brew Unit. Follow procedure to remove the brew unit, clean unit and test the air path through both pipes by blowing. Note: When you take out brew unit it not possible to access one of the pipes because its protected by a plastic shield. There is a manual procedure to manipulate the brew unit to expose this pipe so you can blow through it. However the likely cause is not a blockage in these two pipes but the stainless steel filter that the coffee must pass through. You will need an Allen key to remove the bolt holding this in place. Once removed you need to check all holes are free of blockage by inserting a very small wire in each hole. Alternately you can replace this part. If the filter is clogged then you should consider using a different type of coffee as some types coffees cause this problem and others do not.
I hope this helps. regards
Mar 24, 2014 | Miele Coffee System
Indesit pwde 8148 s display f05
take out plug????
take off rear panel
look for the pump
then take of the pipes to it and clean them
allso take the pump apart (3 screws)
and clean it
Jan 13, 2014 | Washing Machines
DRAIN PUMP DOESN'T COME ON. WATER WILL NOT DRAIN ON ALL CYCLES.
Hi.
The drain pump does not fail very often. If you are sure that the pump does not start check first the pressure switch and the lid switch. The pressure switch is the sensor that determines when to start stop the drain pump. The switch is difficult to test. Try first cleaning the pressure hose connected to the switch. The lid switch is checked before entering in the last part of the cycle. Lid switch can be tested reading impedance at its contacts or jumping it. Check it just in case. If all that is OK check pump motor and control unit.
If you are not sure if pump is starting or not check for drain blockage at pump and at drain nose. Blockage is the most common cause for drain problems.
Regards.
Ginko
Sep 20, 2011 | Frigidaire GLWS1349A Top Load Washer
Its an old inglis superb dishwasher model UD-23081, after I run the cycle, the dishes have an awful white film on and its hard to wash off (have to scrub & rewash all the dishes by hand). Also can the...
Hi I would look in your user manual in the section filters and remove and clean if found to be blocked in any way also check your waste outlet pipe to see if there is a blockage of any kind by blowing down the pipe sometimes a little piece of debris prevents the pump working to its full potential, maybe this will help, if necessary strip pump down to clear being careful to remove the mains lead first I hope this helps cheers eric
Nov 16, 2017 | Dishwashers
WATER LEAKING
Water should come out of the back of a wind unit when it is humid out, usually a drain hole. If water is leaking inside from a window unit, check that the outside drail hole is not clogged or maybe it is not tilted downward enough outside (Usually a very slight tilt down toward the outside to help the water drasin out the back outside). Also, if you have excess water forming, you may need to clean the coil. For central air units water should be drippng outside the home via a pipe or tubing and if the drain tube or pipe is clogged with scum that forms inside the pipe water will back up and overflow in the house near the heater/air conditioning unit. Also, some units have a pump to pump the water out and it may not be working.
Aug 07, 2010 | Heating & Cooling
Whirlpool washing machine "clean pump" error light.
take top off machine. look down right side and you will see a disc about 50 mm in diameter, attached to this is a small flexible rubber pipe, take this off at the disc and blow through it,( you will need some type of pipe to connect to the rubber pipe).this worked for me with the very same problem.
Mar 09, 2010 | Whirlpool Washing Machines
Bosch washing m/c wf2000 pump not working
it may be as simple as a blocked pipe. Check the outlet under the sink it may be full of hair/fluff etc. If you can disconnect the outflow pipe from the u-bend under the sink, first check that the end of the outflow pipe is not blocked, then check the u-bend for blockages. If these are both clear then the pump itself may have a blockage. If you know how to get to the pump, then ask someone to help you take the outflow pipe away from the pump so you can check the pump and pipe for blockages. Be prepared for plenty of gushing water if you remove the pipe away from the pump, and have a pot or something ready under the sink for when you check the pipe at that end. I hope this helps.
Oct 23, 2008 | Washing Machines
Bosch wlf2260
I had a similar problem and found that the holes above the softner section were blocked by black mold. All I had to do was push a small wire into the holes to clear the blockage
Mar 11, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Saniflo 013/003/005 Sanibest Toilet with Grinder Series Pump in White Round Logo
280 people viewed this question
Top Saniflo Home Experts
Paul Carew
Tim Whalen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
