Question about Bell & Howell Photography
Hi, I have a Bell & Howell Model LX58-TX57 with broken bushings
Hi, I have a Bell & Howell Model LX58-TX57 film projector. On the take up reel their are 3 bushings on the drive assembly. 1 on the gear shaft and 2 that guide or steady the wheel. All 3 have broken from age. Can I still get replacement parts for these? Thanks for any help you can give.
richard191
  • 691 Answers
SOURCE: Bell+Howell FILMO 8mm Projector
Hello
Thank you for using FixYa for your problem
sounds like the takeup belt is wrong or the speed motor
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Posted on Dec 01, 2009
super8sooty
SOURCE: i have a bell & howell projector 8mm silent,
I have the same model with the exact same problem. In fact I have 4 of these projectors 2 are the 1481 and the other 2 are 1462. Basically they are the same inside with the 3 cone drive set up. All of theses projector suffer with this sooner or later. I would like to find replacements too. However I can help you with getting drive working and I have repaired my 1481 successfully using converted domestic rubber tap washers drilled out and ground down to the same shape. They take a while to do and you need to make sure that they are not lumpy but smooth. I hope this helps, if you want details let me know, Rob
Posted on Nov 07, 2010
ZJLimited
  • 17970 Answers
SOURCE: The hub driving the take-uo
According with you, old jewerly piece; I suggest visit this link: 8mm16mmfilmscollectibles.com/equipment.
Hope this helps.
Posted on Aug 17, 2011
  • 159 Answers
SOURCE: looking for bulb for cine film projector Bell &
Quick way:
Enter the make and model you've described in your message, adding lamp (not bulb) into Search on Internet Browser bar, press Enter and you should soon have quite a list of suppliers.
Posted on Sep 24, 2011
  • 5 Answers
If the backside of the arm opposite the the pin holding the reel has a screw [possibly plastic] loosen it 1/2 turn at a time. First put a film reel on the pin to check each adjustment buy putting the empty reel with your finger.
Posted on Feb 23, 2013
I need a manual for Bell & Howell Lumina MX60 for an elderly person - need instructions how to load film.
Spec says it's auto-load. From what I recall of my own projector, you mount the input film reel on the front 'arm', extending it as necessary to give clearance, switch on the projector, then feed the free end of the film into the appropriate orifice at the front of the projector.
It then takes over, feeds the film through and wraps it around the take-up spool automatically. It may be necessary to cut the end of the leader on a diagonal to feed it in (not each time the film is loaded, just the first time.)
Once the film has fed through, switch on the lamp, focus and enjoy.
Dec 30, 2016 | Bell & Howell Cameras
Will the bell and Howell model 256 dhow super 8 film
No it won't.
http://store.tvedenlampmodules.com/Vintage-BELL-HOWELL-256-AB-8mm-HOME-MOVIE-FILM-PROJECTOR-w-LAMP-CONVERSION-P5123061.aspx
To be crystal clear; This is a Regular silent movie projector. It will not run, or play Super8, or Super 8mm movie films, with or without sound.
Bell howell autoload 8mm projector user manual english
Dec 05, 2016 | Cameras
How do I stop my Dad's Bell & Howell projector from "skipping" while running a film, model L, design 122.
For a projector to run right, the motor has gear teeth in it that engage with the hollow points on the film itself. The motor has to turn at a steady speed with no friction or hesitation. It is possible the motor on the inside of the projector needs to be oiled or cleaned out...or rebuilt at worse.
There is also the motor that pulls the film thru the projector and winds it onto the receiving spool. Sometimes that motor is out of synch with the projector drive motor and trys to pull the film thru to fast or turns to slow and the you get that "clicking " sound when the receiving spool isn't winding the film up fast enough and the film gets dragged on by those projector teeth and make that plastic clicking sound.
Watch the film while it is running between the two reels and the projector lens. The film should be slightly taunt going into the projector and slightly taunt coming back out of the projector. If you see the film grouping up in front of the projector drive or after, then you know your spools are needing greased up or there is a drag on the motors causing things to be unsynchronized.
This is definitely a mechanical problem and you need to watch the film being fed into the projector and how it is wound up n the receiver spool to see where the fault lies.
Feb 23, 2015 | Bell & Howell Service Manual: Model 122...
MX33 Bell & Howell collection reel does not turn
As this problem is not relevant to "Motherboards" you might like to post it in the right category. But, you might like to check for wear on the drive wheel (rubber) they become shiny over time and this will decrease the friction needed to move the film stock. Rubber is and organic compound and as such it deteriorates, my Akai reel to reel did a similar thing a few years ago and the part was no longer available, so I made one( re-engineered the old one actually). good luck
Jan 28, 2012 | Computers & Internet
How to replace a worm gear on a Bell & Howell model 2585 16mm film projector.
Replacing the worm gear on a Bell & Howell 16mm film projector is a very long and involved process requiring a complete teardown. It is similar to replacing a blown head gasket in an automobile engine. The worm gear is the heart of the mechanism and takes a lot of time consuming labor just to get to it. In the process you lose a bunch of critical adjustments which require resetting with special Bell & Howell tools/jigs/gauges. Many of these projectors are at least 30 to 40 years old and will also require re-lubrication.
The gear itself costs around $30-ish and takes 3 to 8 hours of labor to replace. Richard Patchett in Michigan and International Cinema Equipment in Miami, Florida does the worm gear replacement.
May 04, 2011 | Video Game Consoles & Games
I have Bell&Howell 16mm film projector. Clean and has worked with no problems. Turned down sound during silent movie. Played next reel with sound but could not get sound. Then the reels stopped...
If you don't know how to service this type of machine, I would contact a Bell & Howell dealer and get it repaired/serviced. It possibly needs the magnetic head cleaning.
Apr 17, 2011 | Televison & Video
Nov 30, 2009 | Bell & Howell Photography
I have a Bell and Howell Model 456 Autoload Super8/Regular 8mm Projector bought in 1969. During projection, when the very end of the advancing film is no longer engaged by the rotating teeth, the film...
The Bell and Howell Model 456 Autoload was made that way ON PURPOSE. The last foot or so must be manually pulled from the projector. As described in the manual, "this safeguard has been designed to prevent the end of your film from flapping against the projector after your movie is completed."
If the entire film was going into the take up reel at the end automatically, then THAT was a defective occurence. It is not supposed to do that.
Apr 04, 2009 | BenQ (200NSH-LAMP) Projector Lamp for...
Belle & Howell Super 8 Projector model 254RS loading problem
Don't have the motor switch in the still position when loading -make sure it is on FORWARD. Look at the little holes in the film and make sure the film is on the same side as the little grooves on the drive gear.
PS -let the bulb cool off before try to move the projector ,the bulbs are very expensive and hard to find.
If you do use the still position to view a frame do it for just a few seconds or the bulb will burn the film. Good luck- Tom.
Jun 21, 2008 | Bell & Howell Photography
Photography Logo
194 people viewed this question
Top Bell & Howell Photography Experts
pontelemon
pontelemon
Tony
Are you a Bell & Howell Photography Expert? Answer questions, earn points and help others
