Have started the heating system and it is blowing cold air constantly and will not reset. I cannot turn the heater off
  • 360 Answers
I am taking it that you are talking about a home furnace.
A home forced air furnace has safety switches in a few spots to prevent fires. When one of these safety switches trip from a problem, it will turn on the blower for the furnace but will not turn on the gas or ignite it for the heat.
The safety switches are pretty small, about the size of a penny. I would first try resetting the switch by pressing the button on it (if equipped with a reset), if there is no reset for it, replace it. Run the furnace, if it does it again...then you have a potential problem with the furnace itself and the switch is saving you from your house catching fire.
An easy way to find the switch is to look around the heat exchanger opening, there is usually one there to monitor flames that do not enter the exchanger. The heat exchanger is the part where the actual flames go into when ignited.
The safety switch will have a wire going to it.
Here is a picture of "a" switch, there are many types.
http://www.appliancedirectparts.com/image/HH11AZ180%20NEW.jpg
You can also Google the term "Furnace Safety Switch" and click no the link for "images" to get an idea of other types to look for.
If you are unsure of what you are doing, it is well worth it to have a licensed tech come out to take a look at it. If you have a cracked heat exchanger (can not see with naked eye unless unit is disassembled), it can let deadly gases get into the airflow and cause a variety of health problems...including death.
Hope this helps you out and good luck with fixing it.
Posted on May 03, 2010
Blows cold air turn heat on
Search Results
    07 Tucson heater blowing cold air - Hyundai Forum - Hyundai ...
    www.hyundaiforum.com > ... > Vehicle Line Up > Hyundai Tucson
    Dec 16, 2009 - I have a 2007 Tucson, when you turn on the heater it only blows hot air... Join Date: May 2005 ... a low coolant level will exhibit the first stated symptoms of no heat/low heat at idle and increased heat at cruise due to an air ...
    Denlors Auto Blog » Blog Archive » Car Heater Blows Cold ...
    www.denlorstools.com/autoblog/.../car-heater-blows-cold-auto-service-ti...
    Oct 10, 2009 - When a car heater blows cold air, there are several possibilities that should ...... On my Dodge Neon when I turn on the heat it blows out cold air.
    Heater blows only cool air...even w/ defroster on : Buick ...
    repairpal.com > Problems > Buick > LeSabre
    ... Cadillac, Chevrolet, Chrysler, Dodge, FIAT, Ford, Geo, GMC, Honda, Hummer,Hyundai, Infiniti, Isuzu, Jaguar ... I'll turn up the temp on the dual control to get heat,
Jan 28, 2016 | 2005 Hyundai Tucson
My 2000 grand prix blows out cold air when its on heat
Could be air in the cooling system , try an bleed the system . On top of the thermostat housing is a bleeder valve , with the engine up to temp. open valve till coolant comes out . Is the coolant full ? What color is the coolant ? Have see where coolant turns like a muddy color an clogges the heater core an engine coolant passages . Check the heater hoses going into the fire wall ,are they hot ? Does your grand prix have manual or automatic climate control ? Duel zone ! Do you hear a clicking sound behind the instrument panel ? Bad temp blend auctuator .
Feb 20, 2018 | 2000 Pontiac Grand Prix
Having trouble with the heater in my 2006 Dodge Grand Caravan. When the car is driving around the neighborhood or stopped at an intersection, only cold air blows. Only with extended constant acceleration,...
Yes . Your heater is actually not an Electrical Heater or a Separate Heating system . Actually if uses the same Radiator Line . When Radiator is heated up it is cooled down with radiator Fan and coolant . But when you use the heater function , this hot fluid is passed through a heating coil tube and blower fan is used to take that heat inside the car .
So I think now you understand , why you are not heated up in a short run . You really need to make the Engine + Radiator Warmer ( that is natuarlly happened when you run more) to get Warm air inside.
Please rate my answer fairly and Support me With Regards and Season's Greetings Deepak Richard
Dec 14, 2010 | 2006 Dodge Grand Caravan
Gas furnace is constantly blowing cold air
An indoor blower running when it is not supposed to usually indicates an overheat condition. I would guess that it has been cycling on and off for some time and finally caused the high limit to stick and not auto reset. if you tap it sometimes they reset. the real problem is that it has been overheating from lack of airflow, over sized unit, not enough return air, too many closed registers, dirty filter, dirty squirrel cage blower and or air conditioner a-coil. If you get it started again sit and watch the unit run the flames should come on and stay on for the entire heating cycle, not going on and off.
I wish I could help you more but it is difficult without seeing the problem myself. Good luck! this should get you started!
Nov 01, 2009 | Heating & Cooling
Brivis central heating problem code ''busy 40 H1
Hi, i recently had the same problem with mine and found that the inside adapter was unplugged. I plugged it back in and all is working find, so if anyone has the "Busy Hi 40" message on the control box the check the adapter :)
Apr 19, 2009 | Heating & Cooling
No rear heat
The rear vent system has a separate heater core/blower system. heater core could be plugged up or the coolant lines going to rear heater core are plugged. could also be low coolant/faulty water pump not producing enough pressure, or air in the cooling system which will need to be bled if so.
Feb 22, 2009 | 2001 Dodge Durango
Heater doesn't heat
I would start by sanding the flame sensor. It will be located in the path of the flame.
Feb 16, 2009 | Honeywell L4064B2236 Fan/Limit Control...
Heater blows cold air
With the car warmed up,feel the heater hoses,are they both warm/hot near the firewall in the engine compartment?If they are both warm/hot,then the heater core should have circulation through it and it may be a "blend door" issue in the heater a/c assembly.If they are not warm/hot then the heater core could be dirty and plugged up and needs to be flushed.
If the above does not help,a drain and vacuum of the cooling system and vacuum refill will remove any trapped air.
Sometimes,clamping off the top rad hose and holding the engine rpm at 2000 rpm will force trapped air out of the heater core.(Watch temp gauge when trying this)
Lastly,a NEW thermostat doesn't mean its working correctly.
May 18, 2017 | 2005 Lexus SC300
the electric motor that open the heat door looses electrical connection there by the door stays on cold / it is located under the a/c heater assembly / which requires removing the whole dash and heater assy// also bleed all air out of coolant system
there are three doors / 1/ a/c heat 2/ mode /defors 3/ recurculation dodgeboy6069@yahoo.com
Jul 19, 2008 | 2004 Jeep Wrangler
Heating & Cooling Logo
22 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
