Question about Western Digital WD Passport 250GB Portable Drive 250 GB Hard Drive
If the disk drive of my WD portable drive failed, can I recover the data?
    Sniper:
  • 64 Answers
Yes, you can connect disk drive to another computer, and then use some data recovery program to recover your files. you can download this file recovery software called asoftech data recovery that helped me before
http://www.softpedia.com/get/System/Back-Up-and-Recovery/Asoftech-Data-Recovery.shtml
Posted on Dec 30, 2012
  • 10 Answers
Yes, probably. Take a try this software to recover data from WD firstly. If it doesn't help, then take the device for data recovery services if the data is really important to you.
Remember - DO keep the deivice safe from data overritten or physical damage. Regards.
Posted on Sep 17, 2011
    Problem Solver:
  • 14 Answers
Try finding a software for recovering data here...
  • www.kioskea.com
  • www.fileguru.com
thay provide some applications or some solution regarding your problem..
hope this helps!!!
Posted on May 03, 2010
Recover data from wd 500 gb which is not working
You should use easy data recover software because this software support "raw" type of bad drive file system .
visit here
Apr 04, 2013 | Computers & Internet
Wd passport not recognised after transferring files to another hard drive
I think the hard drive has failed to initialize for mac os .The best suggestion is connect the drive with some other Mac PC and start recovering the drive with the help of a good recovery tool .To recover failed hard drive mac i used this tool.It is so quick than the other and recovered almost all of my drive completely.It also recovers data from a partitioned mac hard drive completely.first try the demo if good results reached go for the full version as i did ..
Jan 16, 2013 | Western Digital Passport WDXML800UE...
WD Elements SE 500 GB/Go not detect in my computer
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use asoftech data recovery software to recover files.
http://www.asoftech.com/adr/
Aug 31, 2011 | Western Digital Wd Elements Se 1tb...
I Have WD Passport Hard Drive in Side More Data But I Will Connect the HD Ask Format? How Can I Recover My Data Pls Help Me
you can try some data recovery software. You can see
It tells the steps how to perform data recovery.
If above does not work, you may have to format the hard drive (use quick format), and then use above mentioned software to scan again the hard drive and recover your files.
Apr 28, 2011 | Western Digital WD Passport 250GB Portable...
Western digital 250 external - not opening
Nov 11, 2010 | Western Digital WD Passport 250GB Portable...
Lost pictures
Depending on the exact failure, you have a couple of options. A friend of mine had a similar drive with important photos an it turned out the drive itself was OK, the enclosure had failed. I removed the drive from the enclosure, and connected it to another system with a drive adapter, and recovered the data.
If the actual HDD in the enclosure failed, you can contact a data recovery company like www.drivesavers.com and get an estimate on data recovery (Generally very expensive, just depends on the importance of the data)
May 25, 2010 | Western Digital WD Passport 250GB Portable...
I have XP and my WD hard drive will not recognize?
Try a different "data" cable between the computer and the WD unit.
Try connecting the unit to a different computer.
If it still does not work, then either:
* the USB-to-disk-drive adapter, inside the casing, has failed,
* the disk-drive, inside the casing, has failed.
Disassemble the unit, and remove the disk-drive.
Connect the disk-drive as a "slave" disk-drive to a computer, to see if the disk-drive is OK, i.e., the USB-interface is the problem.
Copy the serial-number of the disk-drive, and use it to "check warranty status" on WD's web-site. If the drive is still under warranty, WD will replace it.
If not under warranty, WD has a "Customer Loyalty Program", i.e., buy another MyBook through their web-site, and get about a 20% discount, as a current WD customer.
Apr 08, 2010 | Western Digital My Book Essential Edition...
How to recover WD passport250 Data
you can recover files from hard drive with data recovery program, recommended asoftech data recovery that helped me before, you can download it from
Mar 10, 2009 | Western Digital WD Passport 250GB Portable...
Western Digital WD Passport 250GB Portable Drive 250 GB Hard Drive Logo
223 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
