Question about Radio Communications
Reset security code on AU Falcon
I changed the battery on my Au falcon
and entered the wrong security code on the radio
It is now flashing Err continually
I tried disconnecting the battery but it is still showing Err
Any tips
  • 3 more comments
  • Anonymous Mar 30, 2008
    Any tips
  • bozo1 Apr 15, 2008
    how do i set code on radio
  • Kenny 2 Jul 29, 2008
    Ditto,cut power to radio,still flashing err.Been like it for two days now.
  • Anonymous Dec 01, 2008
    took out fuse ,now err appears on stereo 2002 ford falcon forte au 3
    please reply with codes ............
  • kamal87 Jan 21, 2009
    i forget radio security code of ford falcon au(2001)model
Turn key to <acc> turn radio will blink err. leave on for at least half hour.err will be replaced by enter code.
Posted on Sep 26, 2008
Need radio code for 2006 suzuki FORENZA
A local dealer can help. They will have a code based on your VIN. Also, you can try this: The audio security system is activated whenever the audio system circuit is disconnected from the battery. A four-digit security code must be entered in order for the audio system to resume functioning. The security code is stamped on a card located in the vehicle (usually in the glove box). The following security code entering procedure must be used to deactivate the audio security system:
After connecting the audio security system to the battery, "CODE" will flash on the display.
Enter the proper security number into the unit, using the preset buttons No. 1 through 8.
For example, if the security number is "1234":
Press the preset button No. 1. "CODE" will disappear and "1 --- " will appear on the display.
Press the preset button No. 2, and "12 -- " will appear.
Press the preset button No. 3, and "123- " will appear.
Press the preset button No. 4, and "1234" will appear and flash three times.
The audio system will function and will transfer to the radio. If the incorrect security number is XXXXX into the unit, "Err" will appear followed by "CODE" and there will be several audible beeps. If this happens, repeat the security entering procedure beginning with Step 2.
If, after repeated entry of the wrong code, unit will enter "lockup" & will need to be repaired
Oct 07, 2015 | Suzuki Cars & Trucks
How to remove error code on ford falcon radio
Read the operators manual and it will tell you what to do
Jul 14, 2014 | 1999 Ford Falcon
How do i enter the radio code for 2002 ford falcon au 111
If a standard ford type radio as in the escort and focus then the first number is reached by touching the first button so many times ,then the same for the second ,third and fourth number then when showing the correct number in the screen you push button no5 and this locks the code in and it works ?? hopefully
Dec 09, 2012 | Cars & Trucks
I need a code number of radio Honda Accord 1998 serial no.M97A189067
Nobody is supposed to have the complete database of codes, only authorised dealers. As a security measure, any time the battery is disconnected, the radio is Locked Out, and will not function until the security code is entered on the radio itself. Furthermore, after 3 tries, it wont even accept the code on the radio display, showing the ERR condition. Check for a sticker with the radio code inside the glove box. Some dealers fixed a second sticker in the owners manual. If not available, get the code from a Honda dealer, and be prepared to show VIN number, and proof of vehicle ownership.When you get hold of the code, disconnect the battery for 15 min. This will erase the ERR condition, and allow you to introduce the reactivation code.
Aug 03, 2011 | 1998 Honda Accord
My 98 accords radio is reading err7 and will not turn on or play or anything
Jul 22, 2011 | 1998 Honda Accord
I have lost my radio code
Jul 15, 2011 | 1998 Honda Accord
The battery on our Ford Falcon was drained and the radio display stated 'code'. After a couple of failed attempts at entering the correct code the display now just states 'err' flashing on the display. ...
Radio code is specific for each and every car. It is specific like anti theft code. You can get it by providing your VIN# and registration details in authorized dealership. Nobody else can provide you. If anybody can provide you that , then there is no meaning of security for your car.
Apr 02, 2011 | Car Audio & Video
Nissan stereo sy702 with constant err flashing after flat battery
WRONG! Leave the radio on for 1 hour using the key and accessories to reset then enter the pin. You get the pin from nissan customer service in your area but you need to supply your vin/chassis number.
To enter the pin you press buttons 1-4 corresponding to the number of the pin eg. pin is 1023, press button 1 once, 2 ten times, 3 two times, 4 three times
Jan 03, 2009 | 1992 Nissan Pickup
Hi, My BOSE cd 6 changer was working fine on Sunday in my 2004 Mazda6. Yesterday however it wanted a code entering, which is odd because the battery has never been disconnected. I entered the correct 4...
The need to enter the code could be because of a brief loss of power to the unit, this could even be due to jump starting/ low battery power while starting or bad battery earth connection!
The err message is because you entered the wrong code more than once.......to get back to the screen to enter the correct code you will have to leave the power to the unit on for anything from half an hour to a few hours! But you will need to make sure you have the correct security code or you will block the radio and it can only be unlocked by an audio specialist and will probably cost more than the unit itself.
You can get the correct code for a small fee by contacting this link: Car radio codes in Uxbridge London Gumtree
Mar 24, 2017 | Car Audio & Video
Resetting the radio code in a 1998 falcon
The dealer has to send the radio out to their authorized service rep to hve the EPROM in the radio re-flashed with a new code.
These radios have no master key code. They were designed to be very secure.
Jerry G.
Jul 11, 2008 | Ford Futura Cars & Trucks
Radio Communications Logo
4,572 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
