Question about Canon imageRUNNER 2000 Copier
Toner fixing massage
How can solve toner fixing problem canon ir2000 photocoper machine
  • 1,219 Answers
If you mean " toner mixing ", you should check the toner ( if the toner is hardened, replace toner) and toner unit, remove toner unit shake it ( verry well ). If you havve skills and good will, carefully dismantle the toner unit and vacume it, then put it back, put fresh toner and then after auto initialization when message "toner mixing" stops you can use it again.
If the copier was without toner for a long time yust let her do the toner mixing, eventually turn it off and on for better toner dosing.
Pls. rate
Posted on May 10, 2010
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Oct 29, 2016 | Canon Office Equipment & Supplies
In canon copier ir2000 copy comes very light
2 problems: 1. check da tonne, 2. check da scanning unit, worst check the dc board
Apr 06, 2014 | Canon Office Equipment & Supplies
We have canon ir2000 Once when we switch on the machine, the scanner was below the reader glass but scanner was not moving while reader motor (scanner motor) was trying to move the scanner. After that we...
i cant get ur problem .it might be due to home sensor problem.try to use a air blower to blow the optics unit for dust . if that doesn't solve the prob then u have to call a tech as ur scanner may be out of home position and a tech will be needed to solve that
Jun 01, 2011 | Canon imageRUNNER 2000 Copier
My canon ir2000 copier says: System Error E000!!! what can i do for this kind of error. my exact copier model is Canon IR2000. sorry for product identification i didn't get my model from the list thus why...
That means that you have fixing error.Try next:
press MENU and #, with cursors go to clear, press ok, select err or all and ok.
If the problem was only fluctuaction in temperature the machine would work normally.
If not call service, because you have problem with heating lamp, or thermistors, or...
hope that helped
May 13, 2010 | Canon iR 1600 Laser Photo Printer
I have a massage in my canon mf8181c replace k cartriadge
Try to remove the toner cartridge, shake it and reinstall it.
Aug 30, 2009 | Canon MF8180C Color Laser MFC Printer
Error code
Under service mode ( MENU and # ) find clear, select err, and OK. Turn off and on.
If after that you still have this message, you need to find the problem in fixing assy. Its probably bad thermistor or heating lamp.
Call service.
Nov 26, 2008 | Canon PIXMA iP1600 Printer
Copies are not clean since i have put in a new toner
clean small amouts of toner with a vacuum and canned air,
( small bursts), if on mirrors further service will be needed.
May 11, 2008 | Office Equipment & Supplies
Canon imageRUNNER 2000 Copier Logo
392 people viewed this question
old marine
old marine
