Question about LG M2094D 20 in. LCD TV
TV switches on, stays on for 5 seconds then switches itself off
  • 1 more comment
  • kevin989 May 03, 2010
    Hi thanks for your help. I have noticed that sound is not lost, only picture disappears so not in stand by. If I look very carefully I can see a vague outline of picture....
    TV switches on, after 5 seconds picture disappears (you can see a very faint outline) and sound continues.
    The TV has randomly started working normally again. So the problem is intermittent. Happened last year as well then worked normally for about 6 months before today.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. From what you have described it seems that you might have a backlight and/or an inverter board issue with this TV set. It could also be due to the inverter circuits for the backlights. The inverter is the power supply source for the backlights. There could also be a screen driver problem; if it is then you have to change the entire inverter board. All this is only recommended if you have some kind of expertise for checking the internal circuitry of the TV as these units have high voltages running even when the set is switched off. The cost to change the inverter board including labor would be around $250, if you get this done by a professional. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on May 03, 2010
  • Rylee Smith
    Rylee Smith May 03, 2010
    Right, as I said earlier that the issue could be with the inverter circuits. You can open up the back of the unit the blow the dust off and also check for the bad components. Please do accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
  • LG Master
  • 19,396 Answers
Hi.
The TV is probably going in standby. In that case a fault is detected and the power supply is forced to shut down all lines apart the +5V. This is called protect mode, it is explained in Sit.2 below. Among common causes, faulty PSU, inverter or controller board. Troubleshooting explained below.
Situation 1 - Power off
If the TV is shutting down completely,with no led on and no power at all, then the problem is thePSU board. Power cord and on-off switch must be tested before replacingPSU.
If there is no led on, test using a different main socket,check power cord, and check fuse if the power cord is fused. There isno fuse that the user can check on TV.
Situation 2 - Standby
If the TV goes suddenlyin standby instead, that means that the main controller board detecteda fault condition (eg. a wrong voltage or a short), and turned the TVin standby to prevent further damage to internal component.
In this case is said that the TV goes in protect mode (forced standby).
If you have not turned the TV back on yet, follow the troubleshooting on article below.
My television does not start up
Ifyour TV turns back on, and fail again at random time, it can be afaulty PSU, a faulty controller board , or less frequently and inverterfailing.
Here a broad description of how a technician must test the TV:
How to test an LCD TV or monitor PSU and...
Repair is suitable only for a trained person.
Ifyour TV is going in standby at random times, that means that the TV isfaulty. In that case call the manufacturer at the number listed on the owners manual to arrange the repair.
If you are in situation 2 (standby), and you manage to get the TV on and steady, there may also be the possibility of doing a firmware upgrade.
In this conditions the operation is quite risky. If TV shuts down while upgrading you need to replace controller board. Call GE at the number listed on the owners manual, ask if manufacturer reports firmware issues of this kind (there is nothing online), and perform the upgrade followed by the tech support. Here the upgrade:LG Product Support for M2094D-PZ.
If a firmware upgrade procedure gets interrupted, the TV will not start anymore.
If TV is staying on only 5 seconds it is unlikely the firmware, and it may not be possible to perform the upgrade.
Ask GE tech before doing the upgrade.In this case I would test the TV at component level rather then going for a risky upgrade.
Regards.
  • Ginko
    Ginko May 03, 2010
    If the TV is working, check first all cables, then call LG and report the problem.
    A defective cable can in fact cause the TV shut down.
    If the cables are OK, call LG and ask if they thing it is the case to do a firmware upgrade.
    Regards.
3 Suggested Answers
budmrtn
  • 11361 Answers
SOURCE: my tv switches itself to standby
It may be sensing shorts circuits.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Posted on Jun 28, 2010
  • 119 Answers
SOURCE: 42 LG plasma no picture
Power supply is probably bad. You can check the capacitors inside the power supply for bulging on the ends. Very inexpensive repair.
Posted on Feb 25, 2011
I have a Samsung Plasma PN63A650 that has worked 4 8 years, until today. I turned it on, stays on for 14 seconds, then turns off for 8 seconds. Would not respond to remote commands either
Easy fix for new Samsung TV switching on and off power ...
? 4:41
https://www.youtube.com/watch?v=H0cG3lzjuw8
Sep 15, 2012 - Uploaded by alwaysafix
My tv turns on and off by itself the minute I plug in the cable. ....Samsung E6030 led tv hv blinkin red light issue ... capacitors are looking good ...
Help PLEASE! Samsung Plasma Turning On/Off Repeatedly.
michiganstate.247sports.com > Topics
247Sports.comMy Samsung Plasma HDTV (approx 3.5years old) has some issues as of late. When Iturn the tv on, invariably, it starts to turn off and back on repeatedly.
Samsung Smart TV turning off - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I have a Samsung plasma 60 inch model number PN60E6500EFXZA TV. It began to turn itself off every 5 minutes, for the past few days. I was able to factory ... Samsung TV Keeps turning off and on.
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
Samsung Plasma TV turns off by itself
Jun 22, 2011
My Samsung 50 in PN50B650 turns off by itself then on again ...
Apr 30, 2010
More results from www.cnet.com
Jan 13, 2016 | Samsung Televison & Video
Lg lst 5402p switching off
Failed/Failing Hard Drive I'm afraid. Contact LG.
May 05, 2009 | Televison & Video
LG TV Turns itself off
Sounds like it could be a poor connection in the power plug or a ' dry joint ' on the power board, if it's the latter, it will respond to light thumping at the side of the tv. If that's the case it needs resoldering by a technician..
good luck !
Mar 30, 2017 | LG 32LG30 32 in. LCD HDTV
On off switch
clean front panel contact switches on/off vol- vol+ use contact cleaner .
Dec 03, 2008 | RCA D52W19 52" Rear Projection Television
Tv won't stay on
MY SAMSUNG 27# MODEL TXT27820 ONLY NINE MONTHS OLD SHUTS OFF BY ITSELF AND WILL NOT START AGAIN
May 10, 2008 | Samsung TXJ2754 27" TV
36 magnavox tv shuts off by itself
MAGNAVOX TV ONLY. 5-10 SECONDS AFTER TURN ON AUTO TURNS OFF-NO LIGHT STAYS ON-I AM FRUSTRATED BUT IT SEEMS LIKE THE OFF ON SWITCH JUST CLICKS BACK TO OFF-ALSO DOES SAME THING BY REMOTE
Jan 16, 2008 | Philips Magnavox MS3652S 36" TV
IS-TVDVD20 turns off by itself
Many possibilities, suggest send it to the agent if it is under warranty.(less then one year)
Rdgs
alan
Dec 16, 2007 | Insignia IS 20" TV040919 TV
LG M2094D 20 in. LCD TV Logo
164 people viewed this question
Computer Repairing
Computer Repairing
