Question about Harman Kardon CDR20 CD Player
Have no instructions
Hi i know its not a problem as such but how do i record a cd onto a blank disc? i have managed it once but the cd that was made would only play on my harman kardon cd player and no other.
    Brigadier General:
  • 8,546 Answers
Go to retrevo.com, register and download it for free.
You need to finalize the disc for players to read it.
Posted on May 03, 2010
Trying to record on a DVD-R , after several minutes trying to load i get a msg saying it can neither read nor play this disc , check disc,,please help
I've had this problem with trying to record on CD-Rs also. DVD and CD recorders can be very fussy. You just have to get a piece of dust or a fingerprint on the CD or DVD that's being recorded onto and it gets kicked back as a check disc or blank disc..
Another problem is some recorders will only accept certain brands. I've had problems recording onto a SONY CD-R with a SONY recorder! So, in summing up, try a different brand or make sure the disc is clean. Sometimes just taking the disc out and putting it back in in a different position will make the recorder think it's an OK disc. Hope this helps.
Jul 22, 2012 | Samsung DVDR120 DVD Recorder
I just bougth a marantz cdr 300 cd recorder,everything seems to be working fine, but I'm not able to listen what I just recordered on any other cd player.Marantz cd 72 mr 2020.Thanks
It sounds like you haven't followed the last step to the burning procedure. All you need to do once you've completed burning your disc is to Finalize the disc. Read below why you need to finalize as well as the steps to follow in order to finalize the disc.
Hope this helps ;)
How to Finalize Finalizing is writing the TOC (table of contents) on a disc so a CD player can recognize the number of tracks, the total time for each track, and their location on the disc. A recorded disc must be finalized to playback on a standard CD player. Once finalized a CD-R disc can be played on CD players that support CD-R playback. CD-RW discs can only be played on CD players that support CD-RW playback. Consult your CD player owner's manual to confirm supported formats. Finalizing is necessary to: • be able to play a recorded CD-R or CD-RW disc on a CD player • prevent further recording on a disc • avoid erasing tracks on a CD-RW disc • record text information onto a disc you record Notes: • A finalized CD-R disc can never be recorded onto again. • A finalized CD-RW disc can be unfinalized for more recording. • The CDR300 can play back unfinalized CD-R or CD-RW discs. • SYNC REC+FINAL mode automatically finalizes.
Here are the steps in order to Finalize your disk
1 Push Stop. The display shows the number of tracks and their total playing time. 2 Push FINALIZE. FINALIZE is displayed for about 3 seconds.
Jul 27, 2011 | Audio Players & Recorders
Plays fine on both decks, but does not record in any mode.when press rec, the indicator switched from saying "blanc disc" to "data disc" i got this deck used last year. not sure if it...
Check if the blank disc you are using is compatible. It sounds like the discs you are trying to record onto are not compatible with the unit OR you are trying to record in the wrong mode (Synchro v direct see below) It will only record onto CD-R or CD-RW discs. Also read the instructions for recording as there are a number of recording modes depending on menu settings.
See manual here http://www.google.co.uk/url?sa=t&source=web&cd=2&sqi=2&ved=0CCMQFjAB&url=http%3A%2F%2Fmedia.zzounds.com%2Fmedia%2FRCDW500C-be7b6d8b3a46898dae1be148e1af5402.pdf&ei=3eIsTcisNI7sOce8hakK&usg=AFQjCNGCxcLKQKViw1TVJPh_baxuXkVKQA
Jan 11, 2011 | Sony RCD-W500C 5-Disc CD Recorder
I have tried to record from Tape to CD with No result. I have followed the instructions for this task, to the letter and still nothing on CD.
First make sure yoou are using correct cds. You need CDR Audio discs not blank pc media type (Yes they are different). Once you have the disc type right, make sure you are finalizing the disc as they will not play in other machines until u do this
Oct 30, 2010 | Electro Brand Nostalgic Stereo CD Music...
For sony rcd-w500c/w100 won't go to record mode.
Make sure you're using CD-R AUDIO or MUSIC blank discs. It won't record onto data discs.
Jul 20, 2010 | Sony RCD-W500C 5-Disc CD Recorder
I can't get the high or normal speed sychro feature on my sony RCD-W500C recorder to record anything onto a blank disc. I have the proper disc format for music only, so I know it's not that. The burner...
Could it be that you THINK there is no audio recorded because you can't hear it, but there may be a setting preventing the audio from emerging to a reciever or whatever you're listening through?
IOW: there is more to this than just the Sony. What happens if you take the CD somewhere else and try to play it?
Jun 19, 2010 | Sony RCD-W500C 5-Disc CD Recorder
My cd recorder wont read blank cds help me please
Do as it asks, insert blank CD-Audio or CD-Music media.
Discs for recording
For recording, make sure to use special audio discs only.
These discs are marked with “Digital Audio” and the logos shown below.
There are two different types of audio discs for the use on this CD recorder:
– CD-Audio Recordable (CDR) discs
These discs can be recorded on once and
play in all standard CD players and CD
recorders, when they are finalized.
– CD-Audio ReWritable (CDRW) discs
These discs can be recorded on, erased and
re-recorded many times and play in CDRW
compatible CD players and CD recorders,
– All Philips CD players and CD recorders
with the sticker shown here are CDRW
compatible.
To ensure proper working of the set we recommend the use of Philips audio CDR and audio CDRW discs only.
Note: Do not use a computer CDR or CDRW as recording will not work!
Go here and download the manual. You'll need it.
http://www.p4c.philips.com/files/c/cdr602_00s/cdr602_00s_dfu_eng.pdf
Mar 04, 2010 | Philips CDR602 CD Recorder
I get a "Data Disc" message when I press record.
have you purchased the correct blank discs? sounds like you've inserted discs that can only be used on a PC. these players can only record onto blanks bearing the "compact disc digital audio" mark. these are for use on home audio recorders. hope this helps?
May 02, 2009 | Sony RCD-W500C 5-Disc CD Recorder
Wont record on blank pc disks!
I had the same problem and found that I was using the wrong type of CDs. If you look on the CD you have to use the CD that says Compact disc digital audio Recordable or Compact disc digital audio Rewrittable. After I used the Digital ones I could record on it. I then tried the CD on the PC and it worked. You can look on the top of the unit and see the information if you still have it. Hope this helps you.
Feb 23, 2009 | Pioneer PD-RW839 4-Disc CD Recorder
Harman Kardon CDR20 CD Player Logo
78 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
