Question about Nokia Bluetooth-Headset BH-213 2600 Classic 2630 2760 3109 Classic 3110 Classic
Nokia BH-213 unable to Pired with Nokia E-63,it stopped suddenly
My Nokia E-63 Mobile phone is unable to paired with my Nokia BH-213 bluetooth device,it was connected before but all of a sudden stopped working ,since then whenever i enter the pairing passkey 0000 in my cell phone it says unable to pair with BH-213
I did reset my cell E-63 and tried too not working yet,i couldnot find my bluetooth device in search devices.
As well as now my installations have been lost for Email set up
Its prompting me to check the insertion of memory card
All other softwares been installed in memory by me but cant find software for Email set up
Kindly help on these issue,
I also experienced the same problem. After trial and error I realized that the bluetooth device needs to be reset to fix this issue.You may reset the bluetooth device by deleting the pairings from the headset or reseting the headset. Switch off the headset, and press and hold the multifunction key for over 8 seconds. Start pairing the device again. It should work fine now with default passkey 0000
Posted on Jul 19, 2010
Try resetting your bh213....
Posted on May 13, 2010
I'm also havng the same prblm nw in pairing wit my e63 and bh-213.i tried to reset the headset bt nw wenevr i swtchon the headset,a green light is cntinously blinking quickly in it.also the headset is not detected by the phone.
Posted on Feb 11, 2011
I am trying to pair Nokia E63 with Bluetooth Headset BH-213 but my Nokia E63 is not able to search Bluetooth Headset device. I have already turned on Bluetooth of both devices. Please guide me.
Please follow the proper instructions given below to successfully pair your Nokia E63 with the Nokia BH-213 Bluetooth Headset.
1.Ensure that your phone is ON and headset is OFF.
2.Press and hold the multifunction key (for about 5 seconds) until the green indicator light starts to flash quickly.
3.Activate the Bluetooth feature on your phone, and set it to search for Bluetooth devices.
4.Select the headset from the list of found devices.
5.Enter the passcode 0000 to pair and connect the headset to your phone.In some phones,you may need to make the connection separately after pairing.
6.When the headset is connected to your phone and is ready for use,the green indicator light flashes slowly.
However if you are having problem with the Bluetooth connectivity of your phone the most probable cause may be a malware attack.It can be solved by cleaning your phone memory by entering *#7370# on your phone and restoring the default settings when prompted.Make sure you back up your contacts to the memory card or copy it to the SIM directory.
Hope you are satisfied with my solution.Thanks for choosing Fixya.
Jun 24, 2011 | Nokia Bluetooth-Headset BH-213 2600...
NOT CONNECT TO MY MOBILE PHONE
you have to check the compatiblity of this device with yout cell phone.
Connectivity Bluetooth version
  • 2.1 with enhanced data rate (EDR)
Bluetooth profiles
  • Handsfree profile (HFP) 1.5
  • Headset profile (HSP) 1.1
if your cell phone has the above features then follow the undermentioned steps.
you need to search for the device by starting a new search after switching on the bluetooth and make sure that the bluetooth headset BH-104 is switched on.
once the search is completed and your device is found then pair it.
after pairing the device you can use it.
Dec 26, 2010 | Nokia BH-104 Bluetooth Headset
I have made connection between nokia BH-503 and my laptop operating windows 7. But after that when i am trying to connect with my nokia x3 mobile and BH-503 the mobile do not able to find the head set.
Try manual connecting. If you have paired your x3 and BH-503 before, you should have your paired devices. So after you connect manually, the headphones should connect to x3 next time automaticly. :)
Nov 29, 2010 | Nokia BH-503 Bluetooth Headset
How to pair up nokia bluetooth headset BH-213 with blackberry curve 8520 ?
Hi
1.Ensure that your phone is on and the headset is off. 2. Press and hold the multifunction key (for about 5 seconds) until the green indicator light starts to flash quickly. 3. Activate the Bluetooth feature on the phone, and set it to search for Bluetooth devices. 4. Select the headset from the list of found devices. 5. Enter the passcode 0000 to pair and connect the headset to your phone. In some phones, you may need to make the connection separately after pairing. When the headset is connected to your phone and is ready for use, the green indicator light flashes slowly.
thank You
Aug 31, 2010 | Nokia Bluetooth-Headset BH-213 2600...
My nokia bh 213 bluetooth was working with nokia E63 , all of a sudden it is not , the bluetooth is charged and green light is flickering , when tried to pair thed eivce it says the device not found , what...
Thanks sleekycupid.. Even i had a same problem just followed the steps you said.
Step 1: Switch off the bluetooth device.
Step 2: Charge the bluetooth device.
Step 3: Then hold the device button till the green indicator blinks faster than normal.
Step 4: Now try to pair the device from your mobile.
Step 5: Mobile will ask you a passcode, press 0000 and enter.
You might not follow step 1 and 2. Just start from step 3.
Enjoy!
Mar 13, 2010 | Nokia Bluetooth-Headset BH-213 2600...
Got a New Nokia BH-106 bluetooth Headset, i'm
i purchase new Nokia bluetooth headset BH-106 and i want to connect my laptop ( Dell INsprion N5010) plzz give some advise who to connect it.
Sep 21, 2009 | Nokia BHF-2 Headset
Nokia Bluetooth-Headset BH-213 2600 Classic 2630 2760 3109 Classic 3110 Classic Logo
1,077 people viewed this question
Top Nokia Radio Communications Experts
shaun taylor
Computer Repairing
Computer Repairing
woodzowl307
Are you a Nokia Radio Communication Expert? Answer questions, earn points and help others
