Question about Kodak EASYSHARE 5100 All-In-One Printer
Power supply failure
Got up this morning and had an electrical heat-up smell in my computer area. The power light on the 5100 was out, the power cable light was slickering, and the power supply side of the printer was hot to the touch. The power would not come on. Cooked..My compyter and all the other electrical items are on a excellent surge protector. However, there was no surge as all my equipment was still in full power-up and no problems other than the printer.
Will retunr the printer to WalMart, but you need to be aware that this could be a geneeral parts issue. I'm glad it did not catch fire as I had lots of paper material around it.
    Problem Solver:
  • 14 Answers
Might be a defective one, must contact the manufacturer.. no good on this one
Posted on Apr 14, 2008
Sharp ar-501 Code H3-00
Heat roller abnormally high
temperThermistor defect
MCU PWB defect
Fusing connector connection failure
atureCheck the heater lamp blinking
with SIM 5-2.
When the lamp blinks normally:
Check the thermistor and the
harness. Check the MCU PWB
thermistor input circuit.
When the lamp lights up instead
of blinking:
Check the lamp control circuit of
the power supply PWB and the
MCU PWB.
Clear the trouble with SIM 14
Jun 18, 2014 | Sharp AR-5316 Advanced Digital Imager...
HP DeskJet 3745 Printer , My Printer Cant Turn ON , Tested PW Adapter OK , How To FIx It .....Help Me!!!
Some products require time to turn on. These products might or might not give feedback in the form of blinking light(s). Wait a minute for the power light to turn on before proceeding to the solution.If your product does not respond when you try to print, press any button on the product to wake it from power save mode. Wait for the product to initialize, and then try to print again.
Try the following solutions in the order presented to resolve the issue. When one of the solutions resolves the issue, there is no need to continue troubleshooting.Solution one: Press and quickly release the Power button Press and quickly release the Power button (c01602202.gif ) to start a Power On/Off cycle. Do not hold down the button Figure 1: Press and quickly release the Power button If you press and hold the Power button too long, the product might turn on and then off without restarting. If this happens, press and quickly release the Power button (c01602202.gif ) again.If these steps resolved the issue , you do not need to continue troubleshooting.If the issue persists , continue to the next solution Solution two: Check the electrical connections and outlet Unplug the power cord from the electrical outlet, or the power strip or surge suppressor Carefully inspect the power cord for visible damage.If the power cord or power module shows any damage, contact HP to replace the power supply. Disconnect the power supply from the rear of the product.Wait at least 30 seconds, and then plug the disconnected power supply into an electrical outlet. Do not use a power strip or surge suppressor.If the green light (LED) on the power supply does not light up, contact HP to replace the power supply.Reconnect the power module to the product. Press and quickly release the Power button (c01602202.gif ) to turn the product on.If the product still does not turn on, connect the product to an electrical outlet in another room, and then quickly press and release the Power button (c01602202.gif ) to turn the product on.If the product turns on , the electrical outlet in the original room caused the issue.If the product still does not turn on , continue with the next solution.Solution three: Check the USB cable Disconnect the USB cable from the rear of the product.Figure 2: Disconnect the USB cable from the HP product Press the Power button (c01602202.gif ) to turn on the product.If the product turns on with the USB cable disconnected , replace the USB cable If the product still does not turn on , continue to the next solution.Solution four: Check the battery If your HP product has a battery, follow these steps:Check the battery light. If the light is red,recharge the battery.If the battery light is still red after recharge, replace the battery.Figure 3: Removing a battery (example only) 1 - Slide the battery release slider in the direction of the arrow 2 - Remove the battery Instructions for recharging and replacing a battery are available on the HP Web site.Solution five: Replace the power supply If you have completed all of the troubleshooting steps and are still experiencing a problem, contact HP to replace the power supply for your product Solution six: Service the product If you have completed all the preceding steps and are still experiencing a problem, service the product
Oct 03, 2011 | HP DeskJet 3745 Printer
After completing a print project the power light went out and now it will not turn on. I cannot see where there might be a fuse to check. Do you have any suggestions? Thanks, Jim
Try the following solutions in the order presented to resolve the issue. When one of the solutions resolves the issue, there is no need to continue troubleshooting. 1) Press and quickly release the Power button (c01602202.gif ) to start a Power On/Off cycle. Do not hold down the button c01733891.gif If you press and hold the Power button too long, the product might turn on and then off without restarting. If this happens, press and quickly release the Power button (c01602202.gif ) again.
  • If these steps resolved the issue , you do not need to continue troubleshooting.
  • If the issue persists , continue to the next solution.
2) Unplug the power cord from the electrical outlet, or the power strip or surge suppressor.
  1. Carefully inspect the power cord for visible damage. c01733891.gif If the power cord or power module shows any damage, contact HP to replace the power supply.
  2. Disconnect the power supply from the rear of the product.
  3. Wait at least 30 seconds, and then plug the disconnected power supply into an electrical outlet. Do not use a power strip or surge suppressor. c01733891.gif If the green light (LED) on the power supply does not light up, contact HP to replace the power supply.
  4. Reconnect the power module to the product.
  5. Press and quickly release the Power button (c01602202.gif ) to turn the product on.
  6. If the product still does not turn on, connect the product to an electrical outlet in another room, and then quickly press and release the Power button (c01602202.gif ) to turn the product on
  7. If the product turns on , the electrical outlet in the original room caused the issue.
  • If the product still does not turn on , continue with the next solution.
3) Disconnect the USB cable from the rear of the product
  1. Press the Power button (c01602202.gif ) to turn on the product.
  2. If the product turns on with the USB cable disconnected , replace the USB cable
  3. If the product still does not turn on , continue to the next solution.
4) If your HP product has a battery, follow these steps:
  1. Check the battery light. If the light is red, recharge the battery.
  2. If the battery light is still red after recharge, replace the battery
5) If you have completed all of the troubleshooting steps and are still experiencing a problem, contact HP to replace the power supply for your product
6) If you have completed all the preceding steps and are still experiencing a problem, service the product
Mar 26, 2011 | HP Deskjet 460 InkJet Printer
My printer will not turn on
First, try pressing and quickly releasing the Power button to start a Power On/Off cycle. Do not hold down the button. If this resolves the problem your done; if not continue on.
Inspect the power cord for visible damage; if damaged will need to contact HP to replace.
Disconnect the power supply (power module and cord) from the power source (wall socket) and the printer.
Test the power source, wall socket with or without your power bar or surge protector in place, with a small appliance you know works to confirm you have power. You may want to test the wall socket first and then test the power bar, etc. to make sure each component is not the problem.
If the appliance works then need to investigate the power supply. If the small appliance does not work you may need to check your electrical panel for a tripped breaker and possibly consult an electrician to check your electrical wiring.
To test the power supply plug in to the working power source; if the green light on the power supply does not light up you will need to contact HP to replace the power supply.
If the green light on the power supply lights up; reconnect to the printer.
Press and quickly release the Power button to turn the printer on. if the printer does not turn on you will need to check the USB cable.
Disconnect the USB cable from the printer.
Press the Power button to turn on the printer; if the printer turns on you will need to replace the USB cable.
If printer does not turn on, check the battery if your printer has one. A red light means the battery requires recharging; if it is still red after recharging, replace the battery.
If none of these steps resolve your issue before replacing the power supply try plugging the power supply directly in to a different working wall socket with no power bar or surge suppressor.; Press the power button.
If still no power to the printer you need to replace the power supply.
I
Dec 22, 2010 | HP Photosmart 8050 InkJet Printer
Printern will power on Ok, calibrates itself. After a couple of minutes the printer powers off, screen blank, no response, I have to power off and on again to get any use, then it powers off again after...
Are you using a power surge device or uninterruptible power supply(UPS) to plug printer in to? Bypass any of these as these devices can interfere with the electrical flow which cause power failure to the printer. Disconnect any data cables (parallel, USB, ethernet) behind the printer. Possible defects on these cables can cause electrical short circuit that could result to loss of power.
Jun 19, 2010 | Lexmark C543DN Laser Printer
My printer will not turn on. We had a storm
Solution one: Press and quickly release the Power button Press and quickly release the Power button (c01602202.gif ) to start a Power On/Off cycle. Do not hold down the button . Figure 1: Press and quickly release the Power buttonc01896071.gif c01733891.gif If you press and hold the Power button too long, the product might turn on and then off without restarting. If this happens, press and quickly release the Power button (c01602202.gif ) again.
  1. Unplug the power cord from the electrical outlet, or the power strip or surge suppressor. Power module Power cord c00745315.gif c00057913.jpg
    NOTE: The power cord detaches from the power module. The term power supply refers to both the power module and the power cord.
  2. Carefully inspect the power cord for visible damage. c01733891.gif If the power cord or power module shows any damage, contact HP to replace the power supply.
  3. Disconnect the power supply from the back of the product.
  4. Wait at least 30 seconds, and then plug the disconnected power supply into an electrical outlet. Do not use a power strip or surge suppressor. c01733891.gif If the green light (LED) on the power supply does not light up, contact HP to replace the power supply.
  5. Reconnect the power module to the product.
  6. Press and quickly release the Power button (c01602202.gif ) to turn the product on.
  7. If the product still does not turn on, connect the product to an electrical outlet in another room, and then quickly press and release the Power button (c01602202.gif ) to turn on the product.
    • If the product turns on , the electrical outlet in the original room caused the issue.
  1. Disconnect the USB cable from the back of the product. Figure 2: Disconnect the USB cable from the HP productc01896072.gif
  2. Press the Power button (c01602202.gif ) to turn on the product.
    • If the product turns on with the USB cable disconnected , replace the USB cable.
    • If the product still does not turn on , continue to the next solution.
Solution four: Check the batteryIf your HP product has a battery, follow these steps:
  2. If the battery light is still red after recharge, replace the battery. Figure 3: Removing a battery (example only)c01468528.jpg 1 - Slide the battery release slider in the direction of the arrow 2 - Remove the battery
Instructions for recharging and replacing a battery are available on the HP Web site. Solution five: Replace the power supplyIf you have completed all of the troubleshooting steps and are still experiencing a problem, contact HP to replace the power supply for your product. Solution six: Service the printer If you have completed all the steps listed above and are still experiencing a problem, service the product.
Nov 25, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Hey, my dell all in one printer 810 will not power on at all. I have measured the traffo into the printer and it reads 30vDV so it has power but will not start
Hi
Disconnect the unit completely from the AC outlet for 5 or 10 minutes, then plug it back again.It will works.
Also I suspect it may be a loose power switch, or a problem with the power supply.
If it is a USB printer that derives power through the USB cable and not from a seperate power cable, then check the USB cable. That may be the source of the problem if the cable is bad.
Try the following solutions in the order presented to resolve the issue...
Press and quickly release the Power button ( ) to start a Power On/Off cycle. Do not hold down the button .
If you press and hold the Power button too long, the product might turn on and then off without restarting. If this happens, press and quickly release the Power button ( ) again.
Press and quickly release the Power button ( ) to turn the product on.
If the product still does not turn on, connect the product to an electrical outlet in another room, and then quickly press and release the Power button ( ) to turn on the product.
http://h10025.www1.hp.com/ewfrf-JAVA/Doc/images/c01896072.gif( chek the figure)
Press the Power button ( ) to turn on the product.
http://h10025.www1.hp.com/ewfrf-JAVA/Doc/images/c01468528.jpg( chek the figure)
Thanks for contacting fixya.com
Oct 18, 2009 | Dell 810 All-In-One InkJet Printer
I need a replacemant power supply for my printer. Where can I get one?
HP doesn't have a replacement power supply available, and to my knowledge there is no replacement power supply available.
The power supply itself would have to be rebuilt.
More than likely if it's the power supply, and not the fuse in the power supply area, (Behind the plate with the two Number 10 Torx screws. BE SURE, the printer is unplugged from power!), it's an Electrolytic Capacitor, or two that have gone bad.
Electrolytic Capacitors are Filters used in a power supply.
In the Input stage of the power supply, they filter the incoming AC electricity, before it reaches the rectifier.
In the Output stage of the power supply, they filter the rectified DC electricity into true DC electricity.
Look to see if you have any bulging, or leaking 'Caps'. You have to use the same voltage, but you can go slightly higher with the Microfarad's. (mf)
Example: I replaced two 16 volt, 330mf 'caps' with two 16 volt, 430mf 'caps'.
('Caps' = Electrolytic Capacitors)
More info to help identify bad 'Caps'.
http://www.capacitorlab.com/visible-failures/index.htm
Jul 07, 2009 | HP PSC 2210 All-In-One InkJet Printer
Scanner failure
The "Scanner System Failure" error occurs if the scanner bulb is not heating to the correct temperature or there is some other issue with
the scanner hardware. Perform the following steps to resolve the error:
1. Verify that the scanner bulb is lit. If the scanner bulb will not
light up, the all-in-one will require to be serviced.
2. Perform a Power Cycle on the all-in-one as listed below:
a. Verify that the unit is switched on.
b. Remove the power cable from the back of the machine.
c. Wait for 20 seconds.
d. Reinsert the power cable in the backside of the unit.
3. If the error continues to persist, remove the power cord from any power strip and plug it directly into a wall power outlet. The power strip may not be supplying enough power to the product.
4. Cold ambient room temperatures may also cause this error. Move the all-in-one to a warmer room and see if the error reoccurs.
May 22, 2009 | HP PSC 750 All-In-One InkJet Printer
Printer will not turn on
Possible cause may be the power supply fuse. When power failures happen usually the fuse is the first to go.
Dec 01, 2008 | HP - HP Photosmart 8250 printer
Kodak EASYSHARE 5100 All-In-One Printer Logo
64 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Michel Smith
Sajid Najmi
Sajid Najmi
Level 1 Expert
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
